BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > How to replace LCD on BMW Professional radio
      06-26-2013, 01:47 PM   #45
GoRomeo
GoRomeo's Avatar
1015
Drives: 330i, 135i
2008 BMW 135i  [9.50]
2006 330i  [6.75]
Wow great to know. Mine has a few pixels that go dark when hot. Doesnt really bother me since I can still read most of the display. But great to know this info about the fix. Thanks BeakerBoy!
      06-26-2013, 02:16 PM   #46
Nexus7
Drives: 2008 BMW 335i Coupe
I already re-installed my head unit, so no pictures taken. So, basically the 5 screws that you remove after removing the heat sink have no slots for a screwdriver or hex for allen wrench or torx. They almost look like rivets, but I can see they have threads. Very strange.
6MT, short shift kit, JB4, BMS Dual Core Intake, Mtech rear bumper
      10-02-2013, 12:26 AM   #47
BeeMuh
12
Drives: 2007 335i
Thank you for this awesome guide! Installation was a breeze.
      12-29-2013, 09:55 PM   #48
wanna325i
24
Drives: 2011 E92
Where can I buy the screen in the state?
      12-29-2013, 11:04 PM   #49
ctuna
1926
Drives: 325xi 06 wagon MT
google bmw cd 73 display
This is just one of the things that come up
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
If you scroll down on this one at least 5 or 6 repair or part sources show up.
      01-25-2014, 09:11 PM   #50
astroboi0
Drives: 2005 E90 320i
Just wanted to say thanks for these instructions. I just used them to replace the LCD in my 2005 320i
      02-18-2014, 01:44 PM   #51
Jackswan
Drives: BMW 320D E90
Good instructions. Replaced a LCD that was getting muddled after 30 minutes. Bought LCD from Pixelfix based in Budapest. Excellent service, item took 4 days to arrive in the UK. Car is a 320D 2006 model.
      03-29-2014, 10:19 AM   #52
Ken27
Mystic Blue 2006 325i
Drives: 2006 BMW 325i
Thanks
thanks to the OP I just replaced my display
A couple of things to add.
When you remove the little circuit board on the circuit panel there is also a screw on the other side to remove
Also there was clear tape on the connections that held the LCD cable to the circuit board connection. If you dont remove that clear tape you will pull all day on the cable and it wont come out of the connector.
I did run into one small problem, so be prepared. One of the screws holding the heat sink was stuck pretty well. I ended up stripping the head. So I had to break out my easy out set to get the screw out. And then of course had to hunt for a metric screw to replace it. Lucky for me I had both the easy out set and a screw that fit.
The detailed instructions really helped
Thanks again
      04-14-2014, 11:53 AM   #53
PIXLFIX
Drives: E70
Thanks again
That's probably an exception. I did repair more than a 100 of those - never had the screw stuck so much so I would strip the head. Just use quality and (most important) right size screwdriver.
      06-01-2014, 07:26 PM   #54
335i Bubblehead
Fabricator
335i Bubblehead's Avatar
Drives: 2007 BMW 335i Coupe
I just performed the DIY and the instructions and photos were superb. Thank you and now I have a nice display again.
It took about 1.5 hrs to complete from removal of radio to re-install.
      07-06-2014, 05:50 PM   #55
tclippinger
tclippinger's Avatar
Drives: 2006 325xi Sedan Jet Black
Post UPDATE - place to purchase pixel board in USA
Just wanted to update all about where to purchase in USA market.
http://cgi.ebay.com/ws/eBayISAPI.dll...tchlink:top:en
direct link to ebay seller
http://www.ebay.com/sch/i.html?_saca...c&LH_PrefLoc=1
ebay listings.
2014 BMW X3 Mineral Silver (auto)
      08-22-2014, 01:50 PM   #56
jboban
jboban's Avatar
Serbia
Drives: 2006 BMW e90 320d
I just replaced LCD from HU and I have a problem with backlight. Sometimes it's dark then normal, then too bright etc. There are no rules! Everything is done by DIY. Any solutions, please?
      11-09-2014, 10:51 AM   #57
bmwg84
Drives: 2006 330i
Really common issue. My radio's screen would fade out with heat. Luckily there is a fix for it, otherwise BMW wants $600
      02-13-2015, 03:30 PM   #58
Big Jim
Drives: 2006 330i SP/PP/CWP
Can I replace the entire front panel assembly?
I know this is a common problem and there are a lot of threads about this. Wondering if anyone has a quick answer here.
I picked up two salvage radios with working displays and I'm wondering if I can simply replace the entire front assembly and avoid taking apart the assembly to change just the glass.
The only thing I am concerned about is where is the radio's anti-theft serial number stored in the circuity. If it's in the front assembly, then I'll have a radio with no security code. If the serial number and anti-theft circuitry is on the circuit board under the CD drive, then I'm fine swapping our the whole front assembly.
      02-13-2015, 04:05 PM   #59
ctuna
1926
I don't think there are any anti theft codes for a BMW radio
If you disconnect the battery it doesn't ask you for one.
Besides who would use it anyway.
There is programming for options contained in the radio such
PDC , ipod ,usb , Sos and Hi Fi or L7 or stereo output,
so you can't just swap a radio into another
car if it has different options and expect them to work or not
throw error codes. The following file is an example of
Hi Fi with SOS and Bluetooth phone.
CODIERUNG_ERFOLGT
codierung_erfolgt
CDC
nicht_aktiv
AUDIO_SYSTEM
pl2_hifi
pl3_hifi
SDARS
nicht_aktiv
PDC
nicht_aktiv
ACC
nicht_aktiv
STANDHEIZUNG
nicht_aktiv
AUX_RAD
aux
BAUREIHEX
e9x
COUNTRYCODE_RADIO
us
IBOC
nicht_aktiv
KEY_MEMORY_R
aktiv
MUTE_TIMES
pl2
NACHLAUF_INT_R
pl2
RIGHTHAND
nicht_aktiv
SOFTEN_ENTERTAINMENT_PDC
nicht_aktiv
TCU_ECE
nicht_aktiv
TIMEOUT_INT_R
pl2
ULF_ECE
nicht_aktiv
BMW_AKD
nicht_aktiv
BMW_HOME_DEALER
aktiv
BMW_INITIALIZE
aktiv
BMW_MOBILE_SERVICE
aktiv
BMW_PHONE_SERVICES
nicht_aktiv
BMW_ROAMING
nicht_aktiv
BMW_TELESERVICE_ONLY
nicht_aktiv
RING_STATUS
aktiv
BLUETOOTH_RAD2
aktiv
DISPLAY_LOGIC7
nicht_aktiv
HI_TEMP_VOL_CTRL
pl2_hifi
pl3_hifi
SMS_RAD2
nicht_aktiv
PHONE_BUSINESS_R2
nicht_aktiv
SVS_LOW_RAD2
aktiv
BMW_ASSIST_RAD2
aktiv
BMW_HOTLINE_RAD2
aktiv
DAB
nicht_aktiv
CAR_COMP_ACTIVE
aktiv
TCU_JAP
nicht_aktiv
CONTACT_NR_DEALER
aktiv
CONTACT_NR_HOTLINE
aktiv
CONTACT_NR_MOBILE_SRVC
aktiv
ABS_VOL_GONG
e91_hifi
CROSSOVER
pl2_hifi
e90_hifi
r56_stereo
r56_hifi
DELTA_GONG_ENT
wert_0
DELTA_PDC_ENT
wert_0
RATIO_AUDIO_SOURCES
ece
us
VEHICLE_FILTERS
e81_stereo
e82_stereo
e87_stereo
e88_stereo
e90_stereo
e91_stereo
e92_stereo
e93_stereo
pl2_hifi
r56_hifi
VOL_TEL_MAX
stereo_mulf_e87
hifi_mulf_e87
top_hifi_mulf_e87
stereo_mulf_e90
hifi_mulf_e90
top_hifi_mulf_e90
stereo_mulf_e91
hifi_mulf_e91
top_hifi_mulf_e91
stereo_tcu
hifi_tcu
top_hifi_tcu
VOL_TEL_MIN
wert_0
VOLUME_TABLE
e91_hifi
MY_INFO_RAD2
nicht_aktiv
V_INFO_RAD2
nicht_aktiv
PHONE_PROF_RAD2
aktiv
      02-14-2015, 01:24 PM   #60
Big Jim
Well. it worked! I got a second radio and swapped the whole front panel assembly. Really easy to do. A few screws and only one ribbon cable that was easy to manage. my radio call history, bluetooth connections were all still there and working, so none of that was stored in the front panel. Now i need to wait for a hot day to see how the new panel holds up.
Hardest part was getting the HVAC panel to pop out.
      02-14-2015, 02:35 PM   #61
SohoE93
#topdownS65
SohoE93's Avatar
67
Drives: 2011 E93 M3
So this is what happened when I plugged it in....what did I do wrong?
      02-18-2015, 05:49 AM   #62
hugus311
Titanium silver + Sport + Premium
hugus311's Avatar
32
Drives: 2006 330i (E90)
^^^^ i think you put the plastic piece that goes behind it backwards
      02-18-2015, 07:44 AM   #63
Pete.J
Pete.J's Avatar
Australia
323
Drives: BMW M4 DCT (F82)
Question Prying tool?
Originally Posted by BeakerBoy View Post
First remove the heater controls by prying out the left and right sides.
Attachment 631224
Hey BeakerBoy, what's the name of that tool you're using to pry out the heater controls? Where did you get it from? eBay?
I have bad experiences with scratching cars' dashboards using flathead screwdrivers, so I am gonna invest in a proper tool this time
cheers
      05-15-2015, 01:32 PM   #64
hoopvillian
hoopvillian's Avatar
21
Drives: 335i
Thanks for this DIY. Took me about an hour going slow. Display hasn't worked right since I purchased the car, I should have done this a long time ago.
      06-10-2015, 05:17 AM   #65
BMW_fun
Drives: E90_320d
Hi! I have also tried to replace the LCD but have a problem. There is a white/orange film behind the LCD that has to be reinstalled to a new screen. Unfortunatelly my plastic film was stuck to the old LCD and got ripped while trying to remove it. Does somebody know where I could get a replacement film? What replacement should I use? A simple orange plastic film or what? Maybe it's possible to repaint the old one, but what paint should I use?
Currently I put the white paper instead, LCD works fine bus the screen has a very blue tint in direct sunlight, so I believe that film behind the screen is used to remove the bluish tint. Any help would be appreciated!
      06-10-2015, 12:56 PM   #66
Soul_Glo
Soul_Glo's Avatar
13398
Drives: G20
Very informative thanks for sharing
Tags
cd73, lcd replacement, pixel fade
