12-12-2023, 05:07 PM | #45 |
5645
Rep 4,540
Drives: 2022 iX xDrive50, DGM
Add this one to the list - vent cover for the wide open rear floor vents:
Seems not to restrict air flow significantly and protects the ventilation system from the random marble, coin, rock or jelly bean dropped on the rear floor by...whomever. Far cheaper than ripping up the carpet to find that rattle.... https://www.aliexpress.us/item/32568...yAdapt=glo2usa |
12-14-2023, 12:01 AM | #48 |
5645
Rep 4,540
That was my post and photo of my floor (driver's side). Super easy to install (peel-off sticky on the back), metal covers, perfect fit. Reversing install should also be easy - just peel-off. I can't tell that they've affected ventilation at all, and no rattles or vent noise (the peel-off backing is rubber cushion). Not sure if SS or Al, but the finish seems pretty durable (although unknown how they would hold up to muddy boots - I suspect as well as the plastic). Of course made in China, but overall impressed with the quality.
02-03-2024, 07:08 PM | #50 | |
Generalissimo
691
Rep 1,468
Paladin1 , these are not available on AliExpress anymore. Someone mentioned that you found some vent covers on ebay. Do you have the link? |
02-03-2024, 07:39 PM | #51 |
5645
Rep 4,540
Similar items are apparently available on Ali, but I haven't tried these:
https://www.aliexpress.us/item/32568...Cquery_from%3A https://www.aliexpress.us/item/32568...2usa4itemAdapt https://www.aliexpress.us/item/32568...40001719086_48 |
02-03-2024, 08:15 PM | #52 | |
Generalissimo
691
Rep 1,468
02-03-2024, 09:14 PM | #53 |
5645
Rep 4,540
I don't find any on eBay - you might try a search
02-03-2024, 11:37 PM | #55 |
5645
Rep 4,540
Nope. Never found anything on eBay - just the AliExpress links, but they look similar or identical. For some reason the original vendor stopped shipping, but there appears to be several others.
02-04-2024, 04:36 AM | #56 |
In a world of my own
212
Rep 225
Drives: 2024 BMW iX xDrive50
I ended up with some from AliExpress. Worked fine, took about 15 days to arrive.
Current: 2024 iX xDrive50
Previous BMWs: 2014 (US) F10 535i xDrive MSport, 2002/3 (UK) E46 330ci Convertible, 1994/5 (UK) E36 318i |
Paladin15644.50 |
02-06-2024, 11:13 PM | #57 |
1011
Rep 791
Inspired by Paladin1 I found these on AliExpress for $25 shipped to the US.
https://a.aliexpress.com/_mLj6RVY They came well-packed, and had a sticky plastic layer to protect the shiny top surface, and was pre-lined with double-sided tape for a simple installation. I also quite like the blue “i” logo at the corner. Easy and sweet mod! |
Paladin15644.50 |
02-07-2024, 12:54 AM | #58 | |
Generalissimo
691
Rep 1,468
02-12-2024, 05:57 AM | #59 | |
Generalissimo
691
Rep 1,468
Paladin15644.50 therealkenc1011.00 |
02-26-2024, 10:05 AM | #60 | |
Generalissimo
691
Rep 1,468
https://www.shopbmwusa.com/product/1...S-STEEL-PEDALS |
02-26-2024, 11:05 AM | #61 |
5645
Rep 4,540
Same part #, but they appear to be different covers (I suspect your link shows generic OEM installed M covers), and could depend on car model which must be specified on your link - which will tell you they don't fit the iX. And yes, according to installation instructions both pedals must be drilled and screwed. And neither set includes the dead pedal, which wouldn't fit in any case.
02-26-2024, 11:20 AM | #62 | |
Generalissimo
691
Rep 1,468
Thanks for the confirmation. |
Paladin15644.50 |
03-03-2024, 09:28 PM | #63 |
Generalissimo
691
Rep 1,468
Same Etsy seller that sells the door sills has these pedal covers including the dead pedal one that appears to be of the right size:
https://www.etsy.com/listing/1649115...ctive_17&sts=1 Or just the dead pedal cover by itself: https://www.etsy.com/listing/1663300...11&crt=1&sts=1 |
Paladin15644.50 |
03-03-2024, 10:38 PM | #64 |
5645
Rep 4,540
Three things would give me pause with the Etsy offerings:
1) The price - fairly expensive for a trial run, although they are advertised as stainless steel, so maybe justified. 2) The dead pedal and throttle look like overlays with adhesive. OK for dead pedal, not so much for throttle. Hard to tell, but none of these look like they have a flange of any kind. 3) The brake pedal is definitely pre-drilled, and looks oversized - I'm guessing the "no drilling" thing is because the screws engage the "washers" in the back which somehow clamp the plate to the pedal from the back, an arrangement I'd have to see to give me confidence in its stability on something as critical as the brake. Would be interested in a user review if anyone installs them, but I'm not eager to volunteer as the first. |
03-04-2024, 03:43 PM | #65 |
1165
Rep 1,154
My rear vent covers that I ordered a few weeks ago using that same link as above finally arrived, however they misprinted them as iM. Not even one that looks similar in the listing pictures, or as an option to choose, so looks like they just sent whatever they felt like. Probably wouldn’t mind it if I had the M60 lol.
