BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      04-01-2011, 02:45 PM   #45
slimflem
get driving!
10
Drives: M3
If anyone has 15/12 spacers on a stock E92 with OEM 19" wheels, please post some pics. I'd love to see how this looks. thx.
      04-01-2011, 03:27 PM   #46
anthony @ eas
BimmerPost Supporting Vendor
anthony @ eas's Avatar
310
Drives: R56 Cooper S
Here's a link to some before and after photos of that exact set-up:
http://www.m3post.com/forums/showpos...79&postcount=6
      04-09-2011, 09:42 AM   #47
Sandye90m3
Sandye90m3's Avatar
167
Drives: M3
What do you personally believe in the looks of a spacers added to a stock M3 without it being dropped? Right now I'm in the current position of purchasing spacers, however I don't want to drop the car. Do think Spacers + stock ride height looks weird/bad?
Do you have any picture of a sedan + spacers + 18" rims?
Thanks!
M3.E90 JZB Coded.GTSDCT.BomizValved.TurnerTestPipes.ResDelete .EurochargedTune.AAFilter.HRER40s
      04-27-2011, 09:58 PM   #48
acuteperformance
acuteperformance's Avatar
92
Drives: 09 Audi R8 V8 | 15 BMW M4 YMB
Great info on spacers. TMS definitely is the leader in my mind. It took me a very long time to decide which spacers to carry.
Michael
Owner
Acute Performance
      05-31-2011, 07:35 AM   #49
ImportCarPartsPlus
Drives: Mitsu. Eclipse
Just don't go with the cheap $10 aluminum spacers, they have a record of failing.
      06-19-2011, 11:05 PM   #50
shake&bake
OZ
Drives: 10' E92 M3
Spacers with larger tires and wheels - ?
Just purchased a new set of BBS CH-R 20" x9 +24 and 20X 10.5 +24 running on 255/30/20 and 285/30/20. The fit is good, but I feel like the front wheels need to come out a few mm, and maybe even the rears. I was running the stock OEM 19" on a 2010 coupe with 12 mm and 15mm, which seemed to have a better stance. Can I add a 3" spacer in the front and no spacer in the rear with out problems? One recommendation was a 3mm and 5mm spacer. But there was also mention of potential problems with the larger CH-R wheels. Any advice would be greatly appreciated.
Originally Posted by rzm3 View Post
A great article by TMS... copied from http://www.turnermotorsport.com/html...cer_tech.shtml
This is a thread that we've been thinking of for a long time. We also created a page on our website with the same information (more to come!). It consists of everything Turner Motorsport has learned about wheel spacers for BMWs. A lot of this info also applies to other makes as well. It's a very long and comprehensive collection of data, tips, and technical info and it's a bit Turner-centric but should prove useful to everyone. If you should have any further questions, please call or e-mail us.
Why Use Wheel Spacers?
  • Appearance. You want to push the wheels out for a better stance and more aggressive look. This is totally subjective to your personal tastes. And we can't tell you what to like...
  • Clearance. Many wheels are not compatible with big brake kits. The spoke of the wheel will scrape the new brake caliper and you need a wheel spacer to push the wheel spoke away from the caliper.
  • Correction. You may have bought a set of wheels that don't have the correct offset for your car. The offset may be too high, resulting in the wheels sitting too far inward. This is both ugly and incorrect as the tire can now rub on the inside wheel well, or on suspension components, etc. A wheel spacer will push the wheel out and 'correct' the offset.
  • Handling. By spacing the wheels further apart, you can make the car more stable and corner better. You can gain a similar effect as adding a wider wheel without the added weight and expense.
Once you know WHY you need spacers, you can figure out what size to use...
'10 M3 E92 | Alpine White| DCT| BBS CH-R 20" & Eibach Springs| Dinan Stage 1|M.S. Key Hole Delete|Angel iBright V3.0| LED upgrades
Others:10' Landcruiser|09' Ducati 848|10' Tundra 5.7| 97' 993 Cab
      07-10-2011, 10:13 AM   #51
stefan
stefan's Avatar
No_Country
2362
Drives: M2 Comp
Any reason not to run 12,5mm front and 12.5mm rear?
Did I read correctly in that a 12.5mm spacer will not fit (or just barely) with the TMS 75mm stud kit?
///M Power
      08-02-2011, 05:25 PM   #52
tlr
tlr's Avatar
69
Drives: 2011 M3 E93
Originally Posted by tlr View Post
FYI I noticed occasional rubbing with 15mm rear spacers on my E93 + 19" when going over large bumps with 2 or 3 passengers, all EDC settings, top up or down. Front 18mm's seem to be fine so far.
Update: this only occurs for me with my original Pirelli PZero's, not my new Michelin PS2s.
      08-07-2011, 11:00 PM   #53
JK89
Drives: 2007 335i
Bump for a very good and informative post.
      10-13-2011, 03:05 PM   #54
Budge
Professional Trophy Husband
25
Drives: '09 M3 Sedan DCT
Need some help with spacers
I just got some Vredestein tires in 255/35-19 and 275/35-19 to go with my stock M3 wheels (E90).
I want to get spacers, but my measurements seem wrong. I am measuring 14mm in the front and 17 in the rear. I used the tape and the ruler method and was only 1mm off between the two.
Does that souund right or am I doing this wrong?
I expected to need smaller spacers because each of my tires is 10mm wider than stock. But that doesn't explain why I might need larger spacers in the rear when it seems almost everyone else uses larger spacers in the front.
      10-14-2011, 12:11 AM   #55
rzm3
Moderator
rzm3's Avatar
675
Drives: E92 M3
Should be no problem going 15 front, 10 rear based on what others have tried.
      10-14-2011, 10:23 AM   #56
Budge
25
Why would I do that when I have more space in the rear than in the front? That's why I'm concerned. I can't figure out why my car seems different from everyone else's.
      01-30-2012, 04:24 PM   #57
y2_dyc
15
Drives: SG F10 M5
i'm will also be using the same tyres (in the future) 255/35-19 and 275/35-19 to go with my stock 19" 220 M3 alloys (E92). has anyone had experience with this set up using spacers? would like to know what sizes you guys are using front and rear.....
budge, did you find out what sizes you needed for yours? i think my e92 may be slightly different to your e90!
      01-30-2012, 04:53 PM   #58
Budge
25
Sorry, I never ordered spacers like I wanted. I didn't trust my measurements and I didn't want to get stuck with some oddball-sized spacers that no one would buy from me if they didn't work out.
      03-04-2012, 08:46 PM   #59
keepitsteady
Drives: 2011 ZCP M3
great thread thanks for the info.
      03-25-2012, 01:13 AM   #60
druheezy
Peon and General Shoveabout
Drives: 2008 E90 M3
Just had Aleks @ Alekshop do my Ground Control Sleeve-Over on my E90 M3 on 19" 220's with stock PS2 rubber with Macht Schnell 15mm Front and 12mm Rear. No issues rubbing so far, and no fender roll required. Picked up the spacers from EAS.
      04-06-2012, 09:47 AM   #61
utah_ee
Drives: '08 M3 Sedan 6M
Thank you very much for this thread!!
      06-20-2012, 01:29 PM   #62
4corners
4corners's Avatar
391
Drives: 2008 Jet Black M3 Coupe
There is nothing wrong with spacers, BUT, since I took mine off I am happier with the handling and feel. The geometry of the suspension is altered when you add spacers. The wheel is swinging, arching, 12mm, 10mm, or whatever you use, more than the car was designed for. No big deal but don't be surprised if every change you make calls for even more changes like camber plates, etc, to correct things. Better wheels and tires is the way to go, sans spacers.
      09-03-2012, 10:24 PM   #63
M Pulse
M Pulse's Avatar
101
Drives: '17 F82
I own a 2012 E92 M3 with the comp package. I just bought a set of OEM Style 270M wheels for the winter. Do I need spacers? I'm in love with the look and stance of the ZCP wheels and I want to maintain a similar stance with the 270M wheels.
Do these wheels fill the fenders or should I get some spacers?
      09-04-2012, 01:09 AM   #64
rzm3
Moderator
rzm3's Avatar
675
Drives: E92 M3
I believe the 270M are 8"X18" ET20.
Your ZCP wheels are 9"X19" ET31 front, 10"X19" ET25 rear.
This tool should help you decide: http://www.e90post.com/forums/forumdisplay.php?f=12
      12-01-2012, 12:00 AM   #65
oct1285
54
Drives: Out of warranty
Would it be ill advised to run 20/25mm adapter/spacers on the track?
      01-25-2013, 02:03 PM   #66
jrse92m3
Drives: white E92 M3
The 10mm Spacer Dilemma
10mm wheel spacers are one of the most common spacer sizes out there. However, what a lot of people don't realize is that a 10mm size is not a true fitment on any BMW. It's considered a "tuner" fitment, meaning some extra thought is usually required to correctly install them. Only with the right combination of parts will a 10mm spacer fit without a vibration or other fitment issues.
Factory Hub Lips Are Greater Than 10mm
The depth of the lip on the car where the spacer will rest will vary. The available lip space may be 11mm and a 10mm spacer with its own hubcentric lip cannot physically fit. The spacer will bottom out on the lip instead of on the brake hat, leaving a gap between the spacer and the rotor hat. The biggest reason for this is the thickness of the rotor hat. The thickness varies by manufacturer and design. A thinner hat (such as used with aluminum Euro Floating rotors) will leave more lip protruding and make the problem worse. Most spacer manufacturers add an extra chamfer, or shoulder, to push the hubcentric lip further out. The extra chamfer clears any extra part of the stock lip. The other way to get the spacer to fit is to shave the stock lip with a metal file. While not the most elegant solution, it works.
Wheels With Incorrect Beveled Edge
Some wheels (Kosei in particular) have a beveled mounting surface that is at a different angle than on the spacer. Think of really precise puzzle pieces fitting together - if the pieces are not precisely machined to match, the parts don't fit together very well. The wheel will vibrate since enough of the wheel bore is not resting on the spacer lip.
Note that all of this only occurs when using a 10mm spacer with its own hubcentric lip. Any spacer over 10mm is not affected by this. The TMS 10mm spacers with Hub Extender is also exempt from this as the spacer has a flush outer face and will not interfere with the mounting surface of the wheel.
What's the solution? You could shave the stock lip on the car so its depth is under 10mm... Or you could just use a 12mm spacer and be done with it. The difference between a 10mm spacer and a 12mm spacer is the thickness of a nickel! The 2mm difference is smaller than the thickness of a CF memory card or your typical cardboard box. Trust us - 12mm is the way to go. The TMS Hub Extender/10mm Spacer set also works well and allows you to swap spacers in and out for different setups.
so is safe to use the 12MM spacers all around on a 09 ZCP oem wheels ??
thanks for the help
m3post
