BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      08-02-2017, 08:33 AM   #45
Rudy@tirerack
Moderator
123
Drives: rudy@tirerack.com
Originally Posted by Razif View Post
Hello Keith.
I am considering 245/40/18 on my 9.5 and 265/40/18 on 10.5 but I have a few questions. You have a lot of experience with tyres and wheel, so I want to ask you these.
1. How does a stretched tyre (245 on a 9.5 for example) affects performance and handling generally. Particularly in high speed cornering?
* to make it easier for me to understand, lets go extreme a lil. Lets say I put a 225 on a 9.5 and stretch it, how does this effect performance particularly high speed cornering?
2. What difference will it be for rubbing issues when say using 245 on a 9.5" vs 245 on a 9"?. Will the most upper part of the tyre be equal to as if I put it on a 9"?
Let me make myself more clear, lets say I use a 245 on a 9 inch wheel and 245 on a 9.5 wheels inch, the rubbing issues will be similar or has a lot of difference?
Thanks a ton for your time here.
Razif
Razif,
If these wheels are specifically designed for the M3 and they are not fitting correctly, I would first check with the manufacturer of wheel to see what size they recommend for their wheel. They should know exactly what tire size is best for their wheel if the wheel was designed to be used on the M3.
1. 245/40/18 is the narrowest we would recommend on a 9.5" width wheel. The rim edge will poke out a little, but it would not be consider stretched because it is withing the rim width range of the tire. 245/40/18 has a rim width range of 8.0-9.5". Using 245/40/18 on a 9.5" width rim will cause the sidewall to flex very little under corning, this will make the turn in feel extremely precise.
225 would be stretched and would be unsafe. Stretching a tire beyond it's designed rim width will add stress to the sidewall and the bead of the tire. Using anything smaller than 245, you run the risk of the tire coming off the wheel.
2. Rubbing would be less on a 9" than the 9.5"... But that's dependent on the exact tire and wheel and offset being used. If all things are equal, then one would expect rubbing to be less on a 9".
If you have any further questions, please email me directly.
Thank you.
      08-02-2017, 08:49 AM   #46
Razif
Malaysia
29
Drives: Bmw e92 m3
Thanks a ton. That answers all my question as precise as the turn in with flexed tire . Thanks.
      10-04-2017, 08:33 AM   #47
JRV-F82-M4
Proud Father of a Univ. of Mich. Chemical Engineer
JRV-F82-M4's Avatar
193
Drives: 2016 F82 M4
When will Tire Rack be getting in your inventory of Winter Tires for our M3s? Specifically, I want to put winters on my 19" OEM style 359 zcps. What will be available and when (Michelin Alpin 4s, Blizzak LM-001s, etc.)? And what sizes do you recommend OEM 245/265 or minus 1 235/255? Please do not suggest going to 18" because I have a BBK which will not accommodate 18" wheels so I am stuck using my 19" wheels.
Current: '16 F82 M4, Avus Blue, DCT, BavSound, Winters-19" 437s, Summers-19” BBS FI-Rs Past: '13 E92 M3-Jet Black, '12 E92 335is-Space Gray, '06 E90 330i-Jet Black, '99 E46-328i-Green, '96 E36 328is-Jet Black
      10-04-2017, 09:59 AM   #48
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11517
Drives: E90M/E92M/M4GTS/M4GT4/X5M
Welcome to the forum Keith!
      10-28-2022, 09:26 PM   #49
Matt Fojtik
133
Drives: 2012 E92 M3 ZCP
2012 E92 M3  [9.00]
Originally Posted by Rudy@tirerack View Post
I wanted to take a moment to introduce myself. I am excited to be given the opportunity to be your Tire and Wheel forum moderator! I have worked with Tire Rack for nearly 12 years with various departments. Owning many BMW's over the years, they have been my passion for as long as I can remember. I hope my extensive knowledge of wheels, tires and BMW's will be a helpful resource to the forum. My goal is to provide our forum members the highest level of service possible. I will do my best to reply to all your questions and inquiries in a timely manner. Please feel free to contact me directly at Keith@tirerack.com or calling me directly at 800-428-8355 ext. 4799 if I can be of assistance.
When you order online with TireRack, please click this link: http://www.tirerack.com/a.jsp?a=AW8&url=index.jsp and/or reference "Keith/M3 post" as your previous contact.
This helps pay for the server and related maintenance through the commissions received from TireRack sales. It costs you nothing, but M3Post.com will receive a small % back from the sale which is used to directly pay for bandwidth.
Hello, I was just wondering what you would think of a Michelin Pilot Sport All Season 4 on an e92 m3. How would this preform in the winter? And how would it preform to a full snow tire?
Would it be totally screwed as soon as I encountered any type of snow?
Thanks
DrFerry6734.50
      11-27-2022, 03:14 AM   #50
spammysammich
spammysammich's Avatar
1629
Drives: 2009 E92 M3 Dakar Yellow II
2009 BMW M3  [10.00]
Depending on how much faith you put in this guy's reviews
DrFerry6734.50
      11-27-2022, 06:34 PM   #51
DrFerry
Field Marshal
DrFerry's Avatar
6735
Drives: '08 E92 M3
2008 BMW M3  [5.25]
2015 BMW X5  [4.50]
Thanks
Don't hold your breath waiting for a response from the Tire Rack. Even on this thread over a 6.5 year time period only 19 posts were ever made. That's about 3 per year by @Rudy@tirerack
You asked:
1) Michelin Pilot Sport All Season 4 on an e92 m3. Answer: They work great and deliver about 95% of the PS4S peak grip in dry and wet but with better deep water hydroplaning performance and wear life. They come with a 45K mileage warranty.
2) How would this preform in the winter? Answer: The PSAS4 is NOT a dedicated winter or snow tire but it still delivers decent snow mobility to get around in mild snow covered winter road conditions. Think snow depths of 1 to 3 inches.
3) And how would it preform to a full snow tire? Answer: PSAS4 delivers about 70% to 75% of peak grip of a dedicated winter snow and ice tire depending upon the test vehicle and conditions. IF you live in areas where certified "snow flake" winter tires are required such as Canada then buy a Winter Snow tire instead. If you want snow performance slightly higher than PSAS4 but below a dedicated winter tire then buy the Cross Climate (which has lower wet and dry grip than the PSAS4). See chart below.
4) Would it be totally screwed as soon as I encountered any type of snow? Answer: No
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
Appreciate 2
      11-28-2022, 06:01 AM   #52
///M Power-Belgium
General
///M Power-Belgium's Avatar
Belgium
64713
Drives: ///M3-E92-DCT Silverstone II
You asked:
Great post !
Speaking about tires ,
3 weeks ago I've put the new "Michelin's CrossClimate 2" at my Mini .
My findings :
In the wet , the grip of these tires is "Phenomenal" !
There is no competition for this tires in the rain ..
In the tests they show also a great grip in the snow .
Because It's actually a 4 seasons tire .
Downside :
They make more road noise by the extreme grip , but it's never annoying .
The tire tread (big V-profile) looks ugly.
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod.
DrFerry6734.50
m3post
