M2 Technical Topics > Track / Autocross / Dragstrip > Max rubber on the M2?
      03-01-2024, 11:24 AM   #463
ZM2
2840
Drives: 2017 LBB M2
Originally Posted by AmuroRay View Post
Are you running the stock spring rates, and do you know what they are?
Stock springs rates, not sure what they are. They are a bit stiff for around town, but excellent on track.
      03-01-2024, 11:43 AM   #464
AmuroRay
AmuroRay's Avatar
2379
Drives: M235i
See, I have a set of PSS springs here - they said (back in the E46 days) the rates between the PSS/10 were the same. Now I don't think that's the same between a M and non M (IE a M3's PSS spring rates aren't going to be the same as a 330i's PSS10)
I wonder what the spring rate differences are between them?
Anyhow while I was writing this, I found what I was looking for:
https://f87.bimmerpost.com/forums/sh...8&postcount=14
PSS10 M2 are supposedly 514F/800R Progressive?
I have PSS with Linear 350F/900/R for flat ride frequency.
I'll have less power and tire, and likely less total grip - and less race pace. How far off is all of this worth?
Mods: Yes.
      03-01-2024, 12:30 PM   #465
medphysdave
medphysdave's Avatar
4638
Drives: M2 CS | 85 of 592
From a road and track feel I'm in love with the 295 square setup. I did upgrade the front sway and it really fits my driving style. It also helped with weight transition in corners.
      03-01-2024, 01:01 PM   #466
ZM2
2840
Drives: 2017 LBB M2
I've seen this test a while ago, but wanted to get actual road feel perspectives. Thank you!
265 on a 9.5” will certainly be a noticeable grip increase. 265 on a 9” will kill initial turn in and make the steering feel sloppy.
      03-01-2024, 01:29 PM   #467
RugbyBro
RugbyBro's Avatar
7609
Drives: M3
I'm liking 295 on a 10.5in rim (albeit I'm running a 35 sidewall). Turn in is very sharp and I've got a lot of steering feeedback. Still, I do wonder if it would be even better on a 11in wheel which is hard to fit in front on any F8X.
Current: F80
Prior: F82, F32
      03-02-2024, 07:06 AM   #468
medphysdave
4638
I do get on the sidewalk more than I'd like. Even with significant front camber. I assume it's my suspension giving up and car rolling over. Would a wider wheel also help with this? I don't think I could go 11" wide at the moment. Maybe with an aftermarket suspension. Having an adjustable LCA helps. Increasing ride height a little, and playing with spacers, etc
      03-04-2024, 04:32 AM   #469
GasBurnlife(landapanda)
576
Drives: BMW M2
Great conversation and I appreciate everyone’s feedback. Sounds like a 10.5” square will be doable given my camber settings with a larger spacer, and running a 275/35 tire on the wider rim should continue to enhance traction and feel.
Sounds like the 295/30 tire will potentially result in slower time as that tire would be better fitted on an 11” wheel. A 285/35 may be a good compromise on 10.5” wheels. I switched to Toyo RRs (275/35), and would like to try the R7 Hoosiers next. Both of them come in the 275 and 285 sizes.
      03-04-2024, 09:59 AM   #470
GJMills
Drives: BMW
Has anyone here directly compared a 275/40/18 with a 295/35/18 in the rear?
      03-19-2024, 09:47 AM   #471
Juice ///M
Juice ///M's Avatar
28
Drives: RaceCars and Stuff
275/305 30 profile 19" on M2C working.
      03-19-2024, 10:56 AM   #472
ThreeStripes
778
Drives: X3M
What tire? What width and offset on the wheels?
      03-19-2024, 10:58 AM   #473
Juice ///M
Juice ///M's Avatar
28
RT660
Apex 19"s for M2C Brakes. running 12MM spacer from Bimmerworld in the front on extended lugs.
m2
