BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > Road Map North America PREMIUM (USB) 2022
      09-18-2022, 08:19 PM   #23
SaturnX
Drives: 2014 X5
I'll add to this... changing from Transmission to qBitTorrent fixed the issue for me. Strange that Transmission had an issue with the magnet/torrent.
Thanks Right2Repair!
Really appreciate it.
      09-19-2022, 08:43 AM   #24
N8N
N8N's Avatar
170
Drives: 2009 E92 335i 6MT
It is frustrating that it is the default program installed with Mint, and doesn't work... Last time I downloaded a torrent was several PCs ago so I can't even tell you what I used. I must have used the Mega download for last year's map updates.
      09-21-2022, 01:37 PM   #25
derbo
Derbo Tuning
derbo's Avatar
3613
Drives: BMW M3
Unfortunately Rutorrent doesnt like the new torrent/magnet either. I can't seem to be able to seed anymore.
DHT doesn't find anything when I use the torrent file, and the magnet link fails to download the metadata for the torrent files. Bummer!
Right2Repair what are you using to make the fileS?
IG:ruhrohz_m3
Journal: Link
E9x ZCP Suspension Info: Link
Track Chat Discord: https://discord.gg/VsKbTyqBVj
SF Bay Area: DM For coding services
      09-22-2022, 07:20 AM   #26
smass
401
Drives: 06 325i - 10 335i
2010 E90 335i  [0.00]
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
2006 E90 325i  [0.00]
I was able to successfully download but I can't seem to get the nav to pop up the update message when the USB is inserted. I have tried several different USB drives and no luck yet. This update is slightly bigger than 32 GB so I had to switch to 64GB which uses exFAT rather than FAT32. Which brand thumb drives have been working?
thanks
      09-22-2022, 07:40 PM   #27
Mike K
Mike K's Avatar
332
Drives: 2011 e91 328i RWD
Thanks so much OP Right2Repair! I’m primarily a Mac user but I have an old Thinkpad T420 for e90 BMW Standard Tools, etc.
I torrented and seeded the Map OP Magnet link on the Mac which is faster. I also downloaded the 1b hex code tool on the Mac as well.
After failing to pull the hex code with several Fat 32 thumb drives with my Mac, I then used an empty Fat32 formatted thumb and placed the hex code tool via the Windows Thinkpad. It worked the first time! The thumb drive blinked rapidly and then just steady letting me know it was done pulling the hex.
I then used the Thinkpad to run the much appreciated FSC generator and pulled a “Lifetime” code and filled in the associated drop downs.
Inserting the other large 64gb containing the OPs kind Map update, it then took a bit of time before the Nav system finally prompted me for the installation. Maybe a minute. I entered my lifetime code and the update only took about an hour.
Rebooting nav takes a few minutes too so I just let it cook. Eventually, the nav version showed the new Map!
So I downloaded every needed file with the Mac, but did the processing of the FSC stuff with the Windows clunktop. I also understand that 64 gb thumb drives can’t be formatted Fat32 on Windows without a certain app. I’ve read that the thumbs must be Fat32 to work. My Memorex 64gb from Target was preformatted Fat32. Thanks all!
      09-23-2022, 02:28 AM   #28
BIOHazard87
Drives: 2012 535i F10 / 2008 550i E60
thanks
Use the app in the original post to convert from exFAT to FAT32, should work then.
      09-23-2022, 12:43 PM   #29
derbo
Derbo Tuning
derbo's Avatar
3613
Drives: BMW M3
I'll be seeding as long as I can for this one..Already uploaded 1TB..hah
IG:ruhrohz_m3
Journal: Link
      09-28-2022, 03:26 PM   #30
slbsema
Drives: 2013 328i Xdrive
derbo many thanks. I'm one of the leeches
      09-28-2022, 06:13 PM   #31
N8N
N8N's Avatar
170
How are you folks generating your FSCs? I finally pulled everything together to load this and NA Premium USB 2022 is not an option. I'm going to try generating a lifetime FSC for 2021 and see if that works...
Update: the NA Premium USB 2021 lifetime code appears to be working. I will let you all know in an hour or so if it's 100%.
derbo3612.50
      09-28-2022, 08:05 PM   #32
N8N
N8N's Avatar
170
All good. At first I was worried because when I restarted the car and went to check nav version I got a blank screen, but after a few minutes it reports the correct map version.
derbo3612.50
      09-28-2022, 10:23 PM   #33
slbsema
After sitting in the car for almost an hour, the map has been upgraded successfully. Thanks a lot!
      10-02-2022, 06:14 AM   #34
9mmkungfu
201
Drives: 335d, 535d, 750i, X5 35d
Is anyone still seeding this? Haven't seen anything for days now.
      10-05-2022, 04:06 PM   #35
opjose
opjose's Avatar
242
Drives: 335xi
thanks
It needs to be FAT32 not exFAT.
There are various ways of formatting larger drives as FAT32. Youtube has various videos on this.
      10-07-2022, 04:32 PM   #36
doru
doru's Avatar
130
Drives: e92, f25, e46, e83
Update question
I downloaded and extracted the file. Thank you. I also have a formatted 128Gb USB stick.
The last time I updated my nav systems (I have 2 cars with CIC) it was in 2018 or 2019, so I'm bit rusty, hence my question.
I just copy/paste the extracted files on my USB stick now, and insert in the car(s) to update the maps? (I used the lifetime FSB code the last time, so I don't think I need to use the code again?)
Is there anything I should be wary before I could potentially screw up something?
Thanks
Stable:
e92is
f25 N52
e83 N52
e46ci M54B25 (e53 N62 - sold, R.I.P. e39 M54B30)
      10-08-2022, 01:28 PM   #37
Right2Repair
90
Drives: E90 328i
I used qBittorrent to create the file and the magnet link. I will update the post to have qBittorrent as the preferred torrenting program. I am unsure of what could be causing compatibility issues.
      10-08-2022, 09:40 PM   #38
doru
doru's Avatar
130
I just used utorrent yesterday to download from the link/magnet provided. No issues. Installed updated map version on both my cars.
Thanks
Stable:
e92is
f25 N52
e83 N52
      10-08-2022, 10:01 PM   #39
golfer29
Drives: 335i e90
I was able to download successfully. Many thanks. I will try to help to seed over the next several days
      10-09-2022, 12:00 AM   #40
derbo
Derbo Tuning
derbo's Avatar
3613
Drives: BMW M3
Odd. Either way I'm seeding since you posted with my 10gbit connection 24/7. For the foreseeable future
IG:ruhrohz_m3
Journal: Link
      10-21-2022, 05:58 AM   #41
Rezinator
38
Drives: 335is
Could not download. Tried qbittorrent, windows would not allow qbittorrent to open, said it contained a virus. Could not open or download maps.
      10-21-2022, 10:20 AM   #42
lnxguy
358
Drives: 2009 335D
Use a different client.
'09 335D
      10-21-2022, 10:38 AM   #43
Rezinator
38
Drives: 335is
Any suggestions?
Tried utorrent as well, would not open map file.
Don’t want to download a virus on my computer.
      11-07-2022, 08:39 AM   #44
Rober84m
16
Drives: E92 M3
I have a 256MB flash drive. I formatted it to FAT32, but I picked 32K cluster at first. When I went down to try it on the car, nothing popped up like it used to in previous years. USB in glow compartment is working fine, because I uploaded some music prior to it. My memory stick is fine too. I believe it is something to do with how I formatted it. This time I picked 64K cluster to format again since it is recommended for 256MB flash drives. I will try again today or tomorrow when I get a chance. If it does not work I will download it again; perhaps there is a corrupt file or something. Any suggestions?
