      08-06-2019, 09:36 PM   #23
davidwarren
davidwarren's Avatar
188
Drives: 328,325, 325, 335, X5, 640 GC
Surprised you didn’t try the SyncroDesignWorks bearing.
G0FNDM3750.00
      08-10-2019, 09:49 AM   #24
Angel67
Angel67's Avatar
44
Drives: E92 335xi
Just a quick note to say I have just installed meyle balljoints (part number 314-710-0005-INT, at Pelican Parts) for the trailing arm and toe. They looked quite good with negligible bind.
a
Stay tuned!
Appreciate 4
gmx166.00
fe1rx1438.00
      08-24-2019, 10:17 AM   #25
Just Apex It
Euro Haus Founder
Just Apex It's Avatar
138
Drives: '04 E46 330Ci ZHP
a
Stay tuned!
Good to hear! I’ve been debating contacting Bimmerworld to see if they made an update after OP’s complaint or buying some TRW/Meyle/Lemforder Arms to get the spherical bearings. Keep us updated!
      08-25-2019, 03:10 PM   #26
fe1rx
1438
Drives: 135i, 328i, Cayman S
a
Stay tuned!
That is a good find. Much cheaper than my convoluted experience!
      08-29-2019, 05:47 AM   #27
Angel67
Angel67's Avatar
44
Drives: E92 335xi
Yes, but we have you to thank for that.
Also, did you see the toe arms we have made, as posted on a few boards (see https://www.e90post.com/forums/showthread.php?t=768710&page=2), with the following note:
Hey guys.
We have manufactured rear toe arms for the e82 and e9x non-M. The design principle is a curved arm, but with dimensions better suited to the non-M suspension.
These are made of billet 6061-T6 aluminum and have been precision CNC machined to accept either balljoints or bushings (which can be either stock bushings or much stiffer Group N bushings, or even some polyurethane bushings), or any combination of balljoints and bushings depending on individual preferences. They can be anodized in any colour. They can also be made either in the standard length (412 mm) or +3 mm for extra toe.
Because you can select balljoints or bushings, or any combination, you can tweak your effective spring rates in increments (measured in lb/in). So, for example, on effective spring rates:
- 2 balljoints: 0
- 1 balljoint and 1 regular bushing: 15
- 2 regular bushings: 30
- 1 balljoint and 1 Group N: 56
- 1 regular bushing and 1 Group N: 71
- 2 Group N: 112
Assuming the contribution of a full set of stock bushings is an equivalent of 109 lb/in, then that can be fully compensated with a set of MRP toe arms with 2 Group N bushings, and the other 4 arms can be only balljoints...
Just trying to gauge interest at this point so please reply if you might be interested in this product...
      08-29-2019, 05:59 AM   #28
Angel67
Angel67's Avatar
44
Drives: E92 335xi
I would also note that so far I quite like my setup which uses 3 Group N bushings - one each in the toe and trailing arms, plus one on the inboard side of the lower camber arm (the rest being balljoints except for the normal bushings on the outboard side of the M3 upper arms). Since the Group N bushings are very stiff, they provide not only additional spring on compression but also additional rebound, below normal or static height. Above static height, they work against the metal spring, pulling the suspension back to static height. I have a 521 lb spring and say about 180 lb equivalent spring rate from all the bushings. So on compression, below static height, together they add up to about 700 lb, but above static height the effective spring becomes around 340 lb. This helps the sway bar do its job and the car levels very quickly...
So there is a reason besides rules to use Group N...
a
Stay tuned
      08-29-2019, 09:30 AM   #29
ajsmithvmi
Professional Hack
96
Drives: 2009 135i
a
Stay tuned!
Have you, or anyone else, found a similar style ball joint that will work for the rear upper arms?
MCS 1WNR Dampers | Ground Control Camber Plates | E90 M3 front control arms| E90 M3 front tension arm w/ Turner monoball bearings | E90 M3 Steering rack conversion | SPL Adjustable Outer Tie Rod Ends | M3 Rear Camber Arms | SPL Adjustable Rear Toe Arms | M3 Front Caliper Conversion | 275/35/18 Toyo RA1s | 18x9.5ET22 Apex EC-7’s | mFactory LSD | AIM EVO4S with GS Dash | New for 2020: LS1 Swap!
      08-29-2019, 12:11 PM   #30
Angel67
Angel67's Avatar
44
Drives: E92 335xi
You probably know that the guide rod balljoint is the same. That's what Fe1rx used and that's what the Meyle balljoints I used are made for. I have not looked into whether the upper camber arm bushing is the same dimensions but I suspect it would be since the bolts are the same. I will check later. I have an arm in my garage. But that is only on the inboard side. The outboard side, which connects to the knuckle, has a tapered shape not a flat shape, so it would not work without either some machining or some sort of washer.
a
Stay tuned
      08-29-2019, 01:44 PM   #31
fe1rx
1438
a
Stay tuned
The rules of springs in parallel say that you add spring rates together, so the total spring rate is the steel spring rate plus the sum of all the rubber spring rates. That is true at all compression or extension positions. The fact that the rubber is at zero force at static ride height and the steel spring is compressed does cause some confusion, but doesn't change that rule. It just changes the ride height at which the total spring force would be zero - a position that generally will be beyond the maximum droop permitted by the shock.
Stiff, short rear springs could potentially come unseated under full droop as set by the shock. Potentially rubber bushings could keep the springs seated by preventing the suspension from getting to this mechanical limit.
      08-29-2019, 01:48 PM   #32
fe1rx
1438
Also, did you see the toe arms we have made, as posted on a few boards (see https://www.e90post.com/forums/showt...=768710&page=2),
You are welcome! They look good.
With respect to the toe arm I ultimately replaced my machined/ball-jointed toe arm with an SPL part. The only real benefit in doing this was to gain the ability to adjust toe with a turnbuckle rather than the eccentric bolt. I do my own string alignments on hub stands, and I find that the turnbuckle really makes my life easier when aligning.
      08-29-2019, 03:13 PM   #33
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2336
Drives: 2013 128i LMB 6MT ZMP Slicktop
2013 128i  [9.58]
Your machined toe, like most of your work, are pieces of art. If you no longer want them I would be happy to take them off of your hands.
I have 39k street miles on my Rogue toe arms and they're still tight. The rod ends they use aren't FKs strongest but the original NJM series are holding up just fine. I even bought (higher spec) replacements but they just sit in a drawer, waiting. I've replaced the Seals-it WS series rod end seals twice due to rubber cracking, however. I'm thinking of switching to the RERS series boots, but why fix it if it isn't really broken?
FWIW, I just installed Lemforder 3067901 spherical bearings in the hubs for the trailing arms. A bit of initial stiction, but once overcome the movement is smooth and easy.
Inertia is the enemy!
My car's photo history: https://www.1addicts.com/forums/show....php?t=1570551
      08-29-2019, 03:29 PM   #34
fe1rx
1438
Thanks for the compliment. Someone else had the same idea, so they went to another forum member. Sorry!
Suprgnat2336.00
      08-29-2019, 04:06 PM   #35
Angel67
Angel67's Avatar
44
Drives: E92 335xi
Two things. First, I second the motion that your work is work of art. I have been very inspired by you.
Second, on the above, I hear you, but consider this: if I have a 521 lb spring and bushings that equate to 180 lb, while the spring is pushing toward droop with a force of 521 (below static height), won't the bushing be pushing toward static with a force of 180, so shouldn't that be subtracted from the force of the steel spring at positions below static (droop positions) just as it is added to the force of the steel spring at positions of compression. It's an opposing force at positions of droop. I think it has to be subtracted at those positions. If that's true, then I effectively have different spring rates depending on whether the wheel is at compression (add bushing) or droop (subtract bushing) which helps the sway bar do its job....
a
Stay tuned
      08-29-2019, 04:12 PM   #36
Angel67
Angel67's Avatar
44
Drives: E92 335xi
From what I've seen and tried, adjustable arms tend to come loose depending on how they are constructed. Those with lock nuts like rogue and dinan tend to come loose, while those with clamps like spl maybe would be less likely to come loose. And the rogue look better than dinan because the hex in the dinan is in the middle of the shaft not at the ends closer to the lock nut, so harder to get good leverage on it. I ended up using epoxy to glue my dinan nuts in place, rendering adjustability irrelevant. I then decided to machine my own ...
      08-29-2019, 07:20 PM   #37
Angel67
Angel67's Avatar
44
Drives: E92 335xi
Although I think the right calc has to also take into account the unsprung weight of the corner, which represents additional work (besides fighting the spring) the bushing has to do at droop to pull the wheel back to static.
a
Stay tuned
      09-11-2019, 09:10 PM   #38
Angel67
Angel67's Avatar
44
Drives: E92 335xi
a
Stay tuned
I took a look at my OE upper camber arm and the dimensions of the bushing with the flat edges is the same so I would think interchangeable with the balljoint in the guide rod or equivalent. However, they are not identical to the toe/trailing arm bushings because the shell is a bit wider on the upper camber arm bushing (33.5 vs 25 mm). The bushings in these two arms on the outboard side with the tapered edges seem to be a couple of mm wider but probably doesn't matter if replacing with a balljoints, although the edge will have to be machined to a taper.
a
Stay tuned!
      09-11-2019, 09:27 PM   #39
Angel67
Angel67's Avatar
44
Drives: E92 335xi
a
Stay tuned
The other point to keep in mind is that the very stiff Group N bushings seem to provide anti-pitching benefits. Since they work against the spring above static height, they tend to pull down the rear end on braking, which fights against pitching. Sway bars do nothing in this context and stiffer metal springs only make it worse - they contribute to pitching. My current setup gets about 35% of its effective spring from Group N (and other) bushings, so that adds about 50% to the effective spring on compression below static height, and removes about 50% above static height. At the equivalent of 180lb per corner, it's like throwing 360lb in the trunk as soon as the rear end lifts by one inch on braking. It's a very nice effect. 35% feels very good. Would be interesting to test higher percentages. I would think one could get at or above 65% with a fuller set of Group N (I have 3 per corner, and can easily go to 6 per corner, and possibly 9 per corner - the parts are available so it's just a question of finding the right balance between metal spring and bushings).
a
Stay tuned!
      09-13-2019, 09:38 AM   #40
davidwarren
188
Fe1rx- have you looked into the affect the adjustable rear guide arm may have on rear caster angle?
2010 335i e90 Le Mans Blue/Chestnut Brown | M-Sport | 6MT
      09-25-2019, 02:36 PM   #41
fe1rx
1438
The rear caster varies very dynamically with suspension travel. Typical values would be -4° at full droop to -11° at full compression. I can't see any benefit in making a small change in rear caster by adjusting the guide arm, and I suspect any such change would have a detrimental effect on rear bump steer (although I have no numbers to prove it). To minimize that possibility my opinion is that the trailing, guide and upper arms should remain OE length.
      09-25-2019, 03:33 PM   #42
fe1rx
1438
The Benefits - Measured
I have data from 2018 (pre-spherical) to compare to 2019 (spherical). In both cases the car has a wing and a splitter, but the 2019 splitter is "improved". The track is the Mosport GP (AKA CTMP GP) and the lap times are comparable at 1:34. 2018 was cooler so had more power, but 2019 corner speeds were a bit higher, giving about the same lap time.
Plotting steering angle against lap distance reveals that the spherical car requires less total steering input, despite the fact that the cornering speeds are generally higher. Lower trace is GPS speed vs distance.
Name:  GP Steering Input 2.jpg
Another way to plot the same data is as an x-y plot of steering wheel angle vs. lateral acceleration. Once again it is clear that less steering angle is required for the spherical car to produce the same lateral acceleration.
Name:  GP Steer vs Lat 2.jpg
Actual understeer can be estimated by calculating corner radius from lateral g and speed, calculating ackermann angle from wheelbase (2.66 m) and corner radius, and comparing the ackermann to the actual steered angle at the tire by dividing the logged steering wheel input by the steering ratio (16.36 near center). The method is mentioned in Bob Knox's "A Practical Guide to Race Car Data Analysis" if you want to chase down the details and the limitations of the method. Whatever its limitations, it is probably good for comparing two setups of the same car, as we have here. This method shows a reduction of understeer mid corner of up to 1°.
Name:  GP Understeer 2.jpg
My hypothesis is that going spherical (and solid RSFBs) reduces compliance steer effects and loss of camber. This reduction provides greater total grip, reduced understeer, and thus less total steering input being required.
Appreciate 5
gmx166.00
Snertz85.50
ornicar136.00
      09-26-2019, 01:16 PM   #43
ajsmithvmi
Professional Hack
96
Drives: 2009 135i
Great use of data! Spherical is in blue?
It seems there is a noticeable improvement, but where would you rank this upgrade relative to others?
      09-26-2019, 01:50 PM   #44
fe1rx
1438
Yes, spherical is blue.
As to rating the mod, most mods don't show up so decisively in the data, so that is satisfying. And one never has enough data ...
From the driver's seat, I would call the change subtle (vs M3 arms all around and M3 RSFBs), but of course there was no possiblilty of testing before and after back-to-back.
The absolute best bang for the buck in terms of feel would be replacing the RSFBs with M3 bushings. Now they are solid, but I have no idea how much just that mod changed things from the M3 bushings.
In a perfect world I would do one change at a time and have data from each change. Of course, I didn't and don't.
1addicts
