Carly - Automatic headLight sensitivity setting
10-25-2016, 07:46 PM | #23 |
403
Rep 1,425
10-25-2016, 08:00 PM | #24 |
265
Rep 1,173
My take on these settings... It's neat for someone to think they can control the sensitivity setting, but the results I've seen have been little to no change in all settings. I think the variance is either too small to make a noticeable difference, or those settings actually do nothing at all.
10-25-2016, 08:37 PM | #25 | |
403
Rep 1,425
10-25-2016, 08:44 PM | #26 |
265
Rep 1,173
There is a setting in FRM2 and FRM3 that sets the AEs as DRLs (VERHALTEN_DRL_TFL = drl_s). That's probably what you need if your headlights are part of your DRL.
10-26-2016, 11:59 AM | #27 | |
242
Rep 1,353
However I "reset" my modules after doing so via coding, while I was also enabling "variable light distribution" and adding High Beam Assist. The OP posted that his lights stay on all day long when set to auto. Mine NEVER do, even when overcast, with or without daytime driving lights turned on (Angel Eyes only). I leave my lights set to "auto" all the time. The only time I see them come on during the day is when I enter an unlit tunnel or an underground parking garage. It also seems that the RLS is able to determine the difference between sunlight and artificial light, since my lights do not come on if I park in an above ground facility that has outdoor openings at similar light levels to an underground. I did notice RLS parameters for color temp sensitivities btw. Since the RLS is the primary control trigger for all of this, I suspect that the OP's RLS module is not working properly given his results and prior postings. |
