F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > DIY 6.5 to 8.8 L7 display retrofit swap for 2014+ f2x f3x
ARMA SPEED
      07-10-2016, 07:36 AM   #23
Jdmdc5teg06
20
Drives: '15 328i
You have to have factory nav for this to work correct? If you have HU_Entry it won't work?
      07-19-2016, 04:09 PM   #24
catharsis
Drives: e60
code 609 instead of 606 - result
Anderw have you tried VO coding 609 to your car?
would be very interested to know the results
      07-20-2016, 07:14 AM   #25
TePee
67
Drives: F34 LCI MY2019
@Jmdmc5teg06:
With HU Entry the 8,8" screen doesn't work. You need either new Radio Professional from 7/2014 on or Nav Business from 3/2014 on, both HU Entrynav.
@catharsis:
609 is Nav Professional which uses a completely different HU (NBT or NBT Evo). You can't just VO code it if you have HU Entrynav. I have tried to VO code 606 (Business Nav) and even this doesn't work.
      07-20-2016, 07:30 AM   #26
1N54E92
1N54E92's Avatar
81
Drives: BSM F30 M-Sport
TePee, nice write up. appreciate it. Too bad mine is a 2013.
"Join the BMWCCA today! referral member # is 423910"
F30 328i M-Sport (current), F30 328i Luxury (retired), E92 335i Sports ( retired), E30 325 ( retired)
      07-22-2016, 11:12 AM   #27
catharsis
Drives: e60
Originally Posted by TePee View Post
@catharsis:
Well apparently at least in some markets 'nav professional' 609 is NOT NBT EVO but entrynav with extra bits.... I think this is true in the UK and some other places - and I had heard that vo coding an entrynav with 8.8 screen to 609 was successful in unlocking 609 features on another 'festive' site, so was looking to check.
have you first-hand knowledge of what you posted above?
just for the record my car is one of many with 606 business nav running on entrynav so I'm not 100% sure what you mean by "I have tried to code 606 and even this doesn't work"
What I'm really interested in trying to figure out (as it would be a great coding 'coup' if possible) is whether after adding an 8.8 screen and VO coding to 609 to 'unlock' 609 features, whether it would then be possible to change
HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display
and the resolution value
and thus change BACK to an 6.5. screen while retaining the 609 features :-)
even just doing a comparison of all of the before and after .ncd files might provide some interesting insights into how to unlock 'professional' features on the entrynav box.
      07-22-2016, 01:24 PM   #28
TePee
67
I don't know all markets but in F30 series I'm not aware of Entrynav based Nav Prof /609. Maybe in other series like F45 or so, but then it won't be the same I guess. But you just have to check online parts catalog to make sure. Instead of read or hear something
I have new Radio Prof which uses also Entrynav HU but without nav. Coding to 8,8" CID was no problem. But when I was trying to VO code 606 nav, it didn't work and the HU even lost its CAFD file.
So if you want to VO code 609 at Entrynav I can't imagine how it is supposed to work.
But if you are sceptical, just try it. Then you will see and have your first hand knowledge
      08-18-2016, 05:47 AM   #29
Smee
Smee's Avatar
508
Drives: BMW M4 F83
hello sorry to ask but i have just bought a 64 plate 435d. it has Business Nav but i want to upgrade to the 8.8 screen. how do i find out if my car has the HU_Champ2 or HU_entrynav
      08-18-2016, 09:36 AM   #30
Smee
Smee's Avatar
508
Drives: BMW M4 F83
teaston
this is another post aswell
      08-20-2016, 12:58 AM   #31
freespirit
freespirit's Avatar
83
Drives: f30 2016 BMW 328i
Hi Guys ... Can some one help me here .. i am also trying to upgrade my 6.5 inch screen to 8.8 in 2015 f30 328xi base model without business or professional navigation... got the 8.8 inch screen with part number 65509292248 and did the below 2 coding changes .. but its not working
HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480
Is there any other coding changes i should do ? Or am I missing any hardware parts ?
Regards,
Kishore.
      08-20-2016, 08:00 AM   #32
MarkoSK
123
Drives: BMW G20 330eX
Regards,
Kishore.
You probably got the older non-LCI screen. If you have LCI (which I assume you have, given your car is 2015), the screen you need is 65509387453:
Here's the link for the older screen (see the "Superseded by" note)
Halfb8d97.00
      08-20-2016, 10:16 AM   #33
freespirit
freespirit's Avatar
83
Thanks marko and everyone contributed to this thread ... I could successfully upgrade to 8.8 .... One thing I was missing earlier was that the display from my head unit was going through Bimmertech mmi HD unit to 8.8 and there is one toggle switch I should put to off for 8.8 to work.
Only problem I see now is the display brightness... Its dim and have blue tint ... My 6.5 display was so sharp bright and crisp ... Any reasons for this?
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop
      08-20-2016, 05:53 PM   #34
Smee
Smee's Avatar
508
Drives: BMW M4 F83
hello i want to give this upgrade a try but i have a few questions.
what is LCI and how do i know if i have LCI or not? my car is a 64 plate 435d
65509292248 is the part number on here. i have checked Ebay and here is a link to one. http://www.ebay.co.uk/itm/1621638321...%3AMEBIDX%3AIT
when checking the pictures i can see the 9292248 as the part number but where is the 6550 part in front of it?
      08-20-2016, 05:55 PM   #35
Smee
Smee's Avatar
508
Drives: BMW M4 F83
i see this part number alot
Part No. BM 9292248 02 9 is that the same as 65509292248
      08-22-2016, 08:24 PM   #36
Postie6e
Panama
Drives: 2018 X5/MPPK MPE Msport 35i
I do have the same problem after swapping to the 8.8. The screen seems to be dimmer and has a blueish tint compared to the 6.5. I have full brightness on the display menu and on the left control panel. Seems it lacking brightness at day, but at night is ok. I just got used to it...
      08-22-2016, 09:29 PM   #37
freespirit
freespirit's Avatar
83
The main reason for me to upgrade to 8.8 is to enjoy the Apple TV ... i have bimmer-tech smartview HD ... but after looking at the display brightness little disappointed.
One more hint to you ... whats the resolution you have set ? are u using 8.8_1280 by xxx as said in this forum ? reason i am asking is .. after watching few videos i felt very disappointed with this resolution ... so as a try i used 10.25_1600x600 resolution and it feels way better.
trying to see if there is any temperature related FDL ... so brightness can be increased ... let me know if you come across any.
      09-19-2016, 05:16 PM   #38
catharsis
Drives: e60
So, based upon first hand knowledge...
Coding 609 instead of 606 appears to have worked for me in terms of resetting the screen resolution to drive the 8.8 screen (model 9292248, so pre-LCI screens WILL work in LCI cars).
However not all of the features so 'unlocked' appear to work.
Specifically nothing which involves 'local storage' such as 'music collection' or 'voice memo' seems to work correctly.
I'm not sure which other features are supposed to be '609-only' but I'm happy to check out anything anyone specifically wants investigated.
      09-20-2016, 05:30 PM   #39
MarkoSK
123
Lightbulb
I may have figured out the problem with the blue tint. I have an F34 without nav and I've tried both the pre-LCI and LCI screen:
Pre-LCI screen (part no. 9292248):
LCI screen (part no. 9387453):
As you can see:
- both screens work ,
- the pre-LCI screen has a blue tint whereas the LCI one doesn't
EDIT: As a side note - my F34 with a 6.5" screen had the DISPLAY_SIZE_RESOLUTION value set to "10.25_1280x480" by default... and the 6.5" screen worked okay . The 8.8" screen also works okay without having to change this setting, so all you really need to change is EXBOX > DISPLAY_VARIANTE -> "breites_display"
Appreciate 2
      09-20-2016, 07:38 PM   #40
FeelinBlessed
FeelinBlessed's Avatar
227
Drives: 2017 340i AW MPPSK/Track
2017 BMW  [0.00]
dang can't find any good ones on ebay...
      09-20-2016, 08:26 PM   #41
Anderw
Anderw's Avatar
660
Drives: F80 m3
Gotta try and search a few different ways part number , 2 series nav screen , partial part number etc... also eBay.uk and ebay.de may be a good place to look. Other members have gotten sellers of full nav kits to separate the screen from the head unit and controller and get it cheap that way also!
Don't give up there are plenty out there !
      09-20-2016, 11:47 PM   #42
FeelinBlessed
227
2017 BMW  [0.00]
Is this the right lci screen model?
///MPPSK///MP FRONT SPLITTER///MP KIDNEY GRILLS///CF MIRRORS///CF SPOILER///CF TIPS///HUPER OPTIK 20%///NBT///AC SCHNITZER///M4 437M///ZMP///ZTR///iND///
      09-21-2016, 06:40 AM   #43
MarkoSK
123
That's the LCI model (part no. 9387453). It worked in my car. What model and build date do you have?
      09-21-2016, 10:01 AM   #44
FeelinBlessed
227
2017 BMW  [0.00]
I have the 17' 340i with the 6.5" screen
f30post
