03-27-2009, 03:44 PM | #23 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
When I had my car aligned at stock height, I asked to have the pin removed and when the service was done I had 1.3 degrees negative camber in front.
03-27-2009, 05:10 PM | #24 |
376
Rep 8,033
Thanks for the info. I guess that means you'll get the max 2 degrees with the Dinan camber plates only if you have the pin pulled.
03-27-2009, 08:16 PM | #25 |
Veni Vidi Vici
89
Rep 2,750
I ran 2.25 negative on my e46 with no problems for several years. No abnormal wear. I ran -1.5 in the rear and still wore out the insides first. Got a little less than 10k miles out of the rears and around 20k out of the fronts. Pretty normal for these cars I think. This is why I'm running 265s on four corners now. So I can rotate the tires.
03-28-2009, 12:49 PM | #28 |
376
Rep 8,033
I made over 5000 posts, but still do not have a sticky-worthy thread.
Anyway, good idea to stick this thread. I'll post more info on the Dinan springs + camber plates after I get them installed. Currently scheduled for 4/14.
07-01-2009, 04:43 AM | #29 | |
Rep 160
The dealer wants to know what set up I want and I have no idea what to tell them. Can I get some help? What camber are you running up front and rear for track and street? Does anything else change (toe, etc) or does everything else remain stock? Thanks so much!
Certified High Performance Driving Instructor - BMW of North America, Porsche Club of America / Chief In-Vehicle Instructor - Fleet Safety International
Gone but not forgotten: 2008 E92 M3; Eisenmann Race Exhaust / Dinan 3.62 Limited Slip Differential / Dinan Software / Dinan High-Flow Intake / Dinan Camber Plates / Dinan Lowering Springs / Dinan Sway-Bars |
07-12-2009, 10:42 PM | #31 |
108
Rep 697
Here is a handy conversion chart for converting minutes to inches for those that like to check alignments at home. It looks like the 10' toe that BMW lists is approx 1/16" toe in.
03-25-2010, 04:18 PM | #32 |
169
Rep 3,833
Can we get members to post their alignment specs here as well, especially those that are lowered or with more aggressive non factory specs.
Thanks.
05-11-2010, 09:09 AM | #33 |
36
Rep 1,043
here are my alignment specs, before is after eibach pro-kit install, after is after alignment:
here are my alignment specs: BEFORE: LF -1.2deg camber, 0.0mm toe, 6.9deg caster RF -1.7deg camber, 1.9mm toe, 6.5deg caster LR -1.7deg camber, 4.3mm toe RR -2.0deg camber, 4.3mm toe AFTER: LF -1.2deg camber, 0.6mm toe, 6.9deg caster RF -1.7deg camber, 1.2mm toe, 6.5deg caster LR -1.7deg camber, 1.2mm toe RR -1.9deg camber, 1.2mm toe Do these looks normal to those who know something about this? thx |
06-21-2010, 01:00 AM | #34 |
#thatsanicemovebro
202
Rep 3,920
Drives: E92 M3 LSB/Black 6MT
Sorry I am new to this - and have 2 questions:
1- wouldn't you want to have the same amount of everything on both sides? or because of the driver's weight you would need less neg camber up front or something? 2- what are these pins everyone is referring to? |
06-21-2010, 01:15 PM | #35 |
117
Rep 275
There are specified tolerances for each setting, so they don't have to match exactly to be good. Also I'm assuming that the settings differ from L/R to take into account driver weight. For example, camber on the left side will increase with someone in the drivers seat. I think a good alignment shop will take this into account.
08-09-2010, 02:39 AM | #36 |
10
Rep 106
Can anyone post the ZCP alignment specs?
2004 Acura TL (Current)
2000 E46 323i (Sold 2007) "Some say, he has a stripy top, just like mine" - James May |
12-26-2010, 02:01 PM | #37 |
Law Enforcer
25302
Rep 22,324
Drives: '22 Chalk Gray Porsche C2S
Great thread! I'd like to see more alignment specs before/after lowering. What is the OEM M3 camber adjustment range? I want to make sure that I can stay within spec with H&R or GC springs.
06-03-2011, 12:02 PM | #38 |
Rep 3
to echo prior questions:
1) what are those pins everyone is talking about 2) what is the factory comp package suspension/camber settings, and what is the max you can get of the factory suspension... and by factory I am talking about the competition package -10mm suspension Thanks ! |
06-24-2011, 04:00 PM | #39 |
4th down; 4th quarter? Renegade.
87
Rep 3,850
It's not that I don't trust rzm3, it's that I don't trust BMW : ) Has anyone confirmed these specs again? Reason I ask is that the computer printout the dealer handed me showed a totally different range for the M3.
The TIS scan in the first post shows the following: F Camber 0.9-1.3 R Camber 1.33-1.57 The dealer printout shows: F Camber -0.8 to -1.5 R Camber -1.6 to -2.0 I think the rear camber on the above TIS is incorrect. Can anyone confirm? I think I just screwed up my alignment as a result. TIA! Last edited by Singletrack; 06-24-2011 at 11:06 PM.. |
01-26-2012, 10:49 PM | #41 | |
Moderator
675
Rep 4,737
01-26-2012, 11:05 PM | #42 | |
BimmerPost Supporting Vendor
732
Rep 3,735
68kg on each of the front seats, 20kg luggage in trunk and 40kg of weight on the center of the rear seats. If aligning with ONLY a driver in the car, then the alignment settings will not be the same without a driver inside the car when static. Alignments should be performed with a decent amount of fuel inside the car.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
03-08-2012, 06:46 PM | #44 |
Rep 77
If I just want to do the OEM spec, can I just let any shops to perform the wheel alignment if I show them the OEM spec's print out or I should take the car to the shop who is specialize in after market suspension and wheel alignment field.
I heard some shops near my area has good rating for their wheel alignment work but the charge is high compares to firestone's life time wheel alignment. How much does everyone paid for your wheel alignment for E90-E93 here? |
