08-23-2021, 10:25 AM | #23 | |
3081
Rep 5,580
In my brothers old home the central air with dehumidifier need special cleaning to prevent growth. Many refrigerator ice-makers and water dispensers have growth. Well water compared to municipality water. I know my friends well water is high maintenance I think due to calcium deposits. It seems anytime you use water for HVAC or refrigeration then there will be certain regimens for maintenance. |
DETRoadster11484.00 |
08-23-2021, 10:46 AM | #24 | ||
Weirdo
433
Rep 182
Cleaning them isn't incredibly difficult, they are pretty easy to take apart when needed. Like a regular furnace, keeping the filters clean helps prevent dirt from getting on the coils and eventually clogging the condensate drain. The fungus build up would vary depending on use and climate. |
DETRoadster11484.00 vreihen1615637.00 |
08-23-2021, 10:59 AM | #25 |
8951
Rep 2,010
I had two ductless AC systems installed 5 years ago and we are very happy with the results. They cool the house well (2-story) and are very quiet. Zero problems.
The primary reason we went with ductless is because our existing ducting was inadequate (4" uninsulated) and would've had to be replaced if we went with a conventional AC system. All of our heating ducting is located in the ceiling of the first floor and it would've been a move-out-until-completed mess, not to mention very expensive. If I were building a new home I would definitely have conventional HVAC system installed with appropriate ducting.
2014 BMW M235i
2024 Mercedes Benz GLC300 When writing your life's plan, use a pencil with an eraser[/SIZE] Last edited by 3.0L; 08-23-2021 at 11:07 AM.. |
08-23-2021, 11:35 AM | #26 | |
Space Force - 4 Star General
11484
Rep 3,265
vreihen1615637.00 |
08-23-2021, 11:46 AM | #27 | |
3081
Rep 5,580
But the Mitsubishi instructions said not to run a ceiling fan in close proximity or in the same space as the indoor ductless wall unit. Obviously I'm assuming a fan will ill effect the temperature sensor. I'm in a condo now with a heat-pump HVAC and I liked life better with the ductless unit. |
08-23-2021, 11:52 AM | #28 | |
8951
Rep 2,010
During heat waves of 105+ days we run both units on fan settings of 1 to 3 (out of 5 steps) and the house temps hover around 80. And since cool air tends to descend, the downstairs stays about the same temp. During less fierce hot spells, it is easy to keep the house temps around 75 with low fan settings. We have never had to run the units on fan 4 or 5. And oh yeah, both units are reversible for heat if needed. We have natural gas for heating, but it's nice to know we have back up. Another thing to consider is that we had to hire an electrician to run the required 220 AC power to each of the outdoor portions of the units.
2014 BMW M235i
2024 Mercedes Benz GLC300 When writing your life's plan, use a pencil with an eraser[/SIZE] |
08-23-2021, 12:31 PM | #29 |
931
Rep 5,538
I heard Mitsubishi and Bosch central systems are the best. They were all special order so I had to settle with cheap stuff, but I don't have much regrets. It works and it's super quite.
One thing many people don't consider and I think it's way more important then brand names, it's dehumidifier if you need one and ERV is a must have for any house. Best decision I made was ERV. Last year with all inflated prices it cost me $18k to install 2 new systems for $2500 sqft (attic and basement). As I remember Bosch units were around 25k, but did have a pretty big rebate Last edited by Kolyan2k; 08-23-2021 at 12:54 PM.. |
08-23-2021, 12:38 PM | #30 |
931
Rep 5,538
Ps I also have solar panels from previous owner. I haven't paid a single electric bill in over a year. I forgot what SER units are, I think it's minimal what's considered energy efficient just enough
08-23-2021, 12:38 PM | #31 | |
11484
Rep 3,265
08-23-2021, 12:42 PM | #32 |
931
Rep 5,538
08-23-2021, 12:59 PM | #33 |
11484
Rep 3,265
Thanks! I'll look into that. Sounds like a cool benefit in the mini-split category.
08-23-2021, 01:03 PM | #34 | |
931
Rep 5,538
Zehnder makes the best ones, but expensive, they come with all ducts etc. Read it's a nice DIY if all walls/ceilings are open Last edited by Kolyan2k; 08-23-2021 at 01:09 PM.. |
08-23-2021, 01:44 PM | #35 |
Slow.
3782
Rep 7,152
Drives: Single Turbo N54 on Meth!
At least solar has a payback period and then you start to actually make money off of your investment after 7 years or so depending on what state you are in. Unless you do one of those no money down leases which I DO NOT recommend.
08-23-2021, 01:49 PM | #36 | |
11484
Rep 3,265
vreihen1615637.00 |
08-23-2021, 04:31 PM | #37 |
11484
Rep 3,265
Speaking of mini split systems, my neighbor (house on the left) is having one retrofitted into his house right now. The jackass installer seems to think my roof is an acceptable place to stretch the refrigerant line out onto. What a jackass. Who does that?! :
Torgus3781.50 |
