XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
Register FAQ Calendar Today's Posts
      07-26-2012, 12:25 PM   #23
investor27
23
Drives: 2023 BMW X3 M40i
No. Not yet. You would have to change out the entire steering column apparatus if you want to retrofit it with the EPS, not to mention if there is enough space in there to do so if your car is an all-wheel-drive.
      06-12-2016, 04:05 PM   #24
f007
Drives: 2013 x1 2.8ix
Old thread, but just wanted to share that I had succesfully retrofitted servotronic in my X1 xdrive
      06-12-2016, 09:37 PM   #25
vstolpner
25
Drives: 2019 F39 X2 m35i
Congrats! Would you mind to share the details? What did you have to start, what it took to change, and how do you like it? Oh and how much? Lol
      06-13-2016, 02:54 AM   #26
GrantE83
GrantE83's Avatar
34
Drives: BMW X3 E83
I'm intrigued, although I only have S Drive.
Not a fan of the steering at all!
      06-13-2016, 05:12 AM   #27
AndrewMBaines
Drives: BMW X1 Black
Heavy? After driving my Land Rover Defender, the X1 stearing seems ludicrously light!!!
      06-14-2016, 02:27 PM   #28
f007
This retrofit is for X1 Xdrive only as it always comes with hydraulic steering only. Non servotronic version have extremely low power assist at low speeds making parking maneuvers very uncomfortable. At high speeds power assist is OK.
To retrofit Servotronic You need to:
- exchange steering rack to ZF version with Servotronic valve,
- prepare the wiring - about 5 meters of 2 line 0.75mm cable with 2 pin plug on the one end and 2 pins on second end
- connect wiring between servotronic valve and JBE module X14270 plug- pin 5(+) ang pin 6(-) - You have to pass the cables from SV valve trough front wall grommets up to Junction Box Electronics
- do some coding with adding servotronic option SA216 to Vechicle Order
In some cases there is a need of special coding to launch this option.
For me the total retrofit cost was about $1000. I did the wiring myself.
Expected time to retrofit is about 2 days of work.
Servotronic makes steering light at parking speeds, and firm and heavy at high speeds.
Definitely worth of any dollar.
PS. Sdrive versions have Electric Power Steering. To activate servotronic in EPS you need to buy or generate FSC code and use it to activate this option in EPS module. Piece of cake
      05-31-2018, 12:29 PM   #29
captainplanet
Drives: e46 M3 2003, e84 x1 2013
As a new owner of a 2013 X1 xdrive model, I too felt the different steering feel with cars test driven.
For United States cars built July 2014 and after, the servotronic option was no longer optional, it was standard. We were able to find an early build 2013 x1 xdrive without servotronic and we absolutely love the steering. Honestly, it feels just about as good as my e46 M3.
We love this x1.
I may be wrong, but it is my understanding that the e84 (up to 2015 model year) cars had hydraulic steering, at least in the US. The new X1, 2016 and later, has electronic instead of hydraulic.
      05-31-2018, 12:54 PM   #30
LevinBR
40
Drives: 2013 BMW X1 xDrive 35i
It depends on your model. The 35i here in the US has always had servotronic. It is really nice because it offers the best of both worlds (tight response at high speeds and buttery smooth at low speeds/stopped)
      05-31-2018, 06:23 PM   #31
captainplanet
Ahh, so the xdrive35i came standard with servotronic? Got it.
Honestly, after driving both, the fiance and I much preferred no servotronic. Night and day difference (for us) for low speed driving. It is heavy, weighted, and what BMW steering should be. Ain't no one-fingering the steering wheel for parking lot maneuvers here!
      06-01-2018, 07:36 AM   #32
AndrewMBaines
My other vehicle is a Land Rover Defender 110. Makes the X1 steering appear light as a feather
      06-02-2018, 05:48 PM   #33
Ja Gio
23
Drives: X1 xDrive28i, 2013
You said that 2 years ago.
      06-03-2018, 02:23 PM   #34
themishmosh
36
Drives: BMW X1 xDrive35i
X1 35i, H&R springs, Bilstein HD shocks, BMS JB4, BMS chargepipe, xHP trans flash
      06-04-2018, 08:04 AM   #35
AndrewMBaines
Originally Posted by themishmosh View Post
Glad you're all paying attention!
      01-29-2019, 10:08 PM   #36
nny528i
Drives: X1 xdrive35i
1965 R Model Mack tractor with non power steering makes your land rover feel like you can drive it with your mind.
Kid you not there was a scuffed area on the door and on the dash where you had to brace your foot in order to get enough leverage to force the wheel around if you needed to turn while not moving.
Tags
bmw x1, city, power steering, s18 drive, wheels
