07-03-2023, 11:59 AM | #23 | |
2379
Rep 4,218
Mods: Yes.
07-03-2023, 12:48 PM | #24 | |
2379
Rep 4,218
I told Pal the ER should outcool the CSF - based on the logs shared here, it's about 10F cooler than the CSF in the same temps (I know, different cars, different tracks, different days) We're able to deduce that based on the information given. So if it works on another car, there isn't a reason it shouldn't work on yours. That said, your turbo is more efficient, so you should be generating less heat anyhow.
Mods: Yes.
07-03-2023, 01:23 PM | #25 | |
2840
Rep 3,715
Track layout- This has a huge effect on if you’ll see temp issues or not. Longer straights and more hard braking zones (vs more flowy tracks), will generate more heat with less opportunity for airflow to shed it. Tune- Pal is either running no tune or Level 1. 15psi is very stock like for boost on the M2. Turbo- A more efficient turbo only generates less heat at a similar tune level. I’m generally on large, fast, hard braking tracks, am running a pretty high state of tune for the OG M2, and am using the turbo more than the OTS tunes. That’s three strikes against my setup. I also know an M2 guy that runs similar tracks as I do with the CSF radiator & oil cooler, ER IC, Stg 2 93, and has coolant temp issues. So, moving to the ER def won’t be a fix for my situ. As for ducting, the Evo3 requires all ducting to be removed for it to fit. Prob not the best thing for getting air to the right places. Overall, I think the best thing I can do is get an IC with the least amount of frontal area that has just enough cooling capacity to get by, add the stock ducting back in, and see what IATs and cooling temps look like. Then, we’ll have two potential outcomes: 1. If IATs are high and coolant temps are good, add simple non-tune based water injection. 2. If engine temps are still too high, lower on track power levels bc there’s no way to add more oil & coolant cooling capacity without major custom work. I lowered power with the Evo3 and still had coolant temp issues on hot days, which leads me to believe it’s all about getting maximum airflow to the radiator and having an IC that does its job just “good enough”. Last edited by ZM2; 07-03-2023 at 01:34 PM.. |
07-03-2023, 01:47 PM | #26 | |
4392
Rep 7,634
Also have you tried flash options to lower coolant target temps? It probably wont do anything if your issue is exceeding cooling system capacity, but curious if you experimented with them. Similarly, have you tried something like the lower oil temp thermostat? If coolant temps are fighting stock oil temps that could help |
AmuroRay2379.00 |
07-03-2023, 02:50 PM | #27 | |
2840
Rep 3,715
The Race options are shorter than the Evo3, but as I mentioned, my buddy with an ER and Stg 2 93 still has coolant temp issues on hot days that seems airflow related. I do run BM3 MaxCool on track. A lower oil temp thermostat wouldn’t fix the airflow/system capacity issue. It would just buy a little more time (1-2-laps?) before engine temps get too high. I’m essentially achieving the same by running BM3 MaxCool and running in Sport/DSC off settings. Oil temps on my car will get up to 270F as the heat from my cooling system cascades over onto the oil system via the coolant/oil cross flow exchanger. I definitely didn’t want to build another version of my thread https://f87.bimmerpost.com/forums/sh...hlight=Extreme in this one, but with all the data I have it seems very likely it’s an IC/radiator airflow issue, so I wanted to focus on that here and mention my experiences to date while folks are looking for certain IC’s for their track setups. Bottom line there are always trade offs to certain upgrades (more power, stickier tires, etc.) that don’t get exposed until a car is pushed hard on track in the summer. Last edited by ZM2; 07-04-2023 at 11:13 AM.. |
M2guru425.50 |
07-03-2023, 03:17 PM | #28 | |
4392
Rep 7,634
Understood RE oil, didnt realize you were exceeding oil cooling capacity as well - in that case yeah, lower thermostat wont do anything except make the starting point a little lower. I'll post in your other thread so as to keep this one IC focused. |
07-03-2023, 06:15 PM | #29 |
2379
Rep 4,218
I’m starting toe believe the cooling issue isn’t an intercooler issue - it’s an oil cooler issue.
I’ve seen this issue before - it’s actually the oil that’s heating the coolant. I think the VRSF Race is the best choices but going with a smaller frontal area isn’t going to help. Check the cars above. PAL reaches higher maximum speeds (130mph) and again, never reaches the peaks the CSF and in fact has lower lows (iats drop into the 11x vs the CSF which stays over 12xF in each session) PALs car also is pushing 16psi throughout multiple areas and above 13 near partial throttle. Again - I’ve been watching the videos - the ER car’s coolant temps are in line with the CSF car as well. So it’s offering better cooling, lower weight, it’s achieving higher maximum speeds and still keeping everything else in range of the shorter core. The CSF and VRSF COMP are the same height. The only difference between the Comp and Race is the total height. |
07-04-2023, 04:50 AM | #30 |
426
Rep 598
Drives: 2018 M2
07-04-2023, 11:26 AM | #32 | |
2840
Rep 3,715
The higher tune level for M2guru is why I mentioned in the beginning that he may very well run into coolant temp issues by switching from the CSF to the ER IC (even tho IATs would be better under control), b/c of higher cooling demand and potentially more restricted air flow to the radiator bc of the larger IC. He's already hitting 235F coolant temps (the car will pull power at 242F coolant) in his log. Granted more cooling mods may bring coolant/oil temps down, but as I've mentioned, my buddy that runs Stg 2 93 with the CSF cooling pack and ER IC has coolant temp issues on hot days. The thought is what I've been saying--larger IC + less clean air to the radiator = coolant temp issues. My issue could be oil temp/cooler related. F87source and I have had many side conversations about this situ. I'll follow up regarding on my N55 cooling thread: https://f87.bimmerpost.com/forums/sh...hlight=Extreme Last edited by ZM2; 07-04-2023 at 01:20 PM.. |
07-04-2023, 10:54 PM | #33 |
437
Rep 753
Great discussion, and it’s clear that there are many variables at play to get to a conclusive outcome. That being said, here’s some more info on my car setup:
Dinan Stage 1 tune (harness) ER intercooler ER charge pipe Akra 300 cell downpipe Akra catback exhaust K&N panel filter in airbox Here is a dyno comparison of my car (Dinantronics car), and two of my buddies’ M2’s with CSF intercoolers - one of them is stock tune and the other is VF Stage 2. Both have high flow downpipes too. https://media.fotki.com/2v2euYjnGxu6LVA.png And some anecdotal information. I was at THill a while ago on stock tune and 100°F+ ambient conditions and recall my peak IATs being around 126°F. |
M2guru425.50 |
07-05-2023, 04:38 AM | #34 |
426
Rep 598
Drives: 2018 M2
For the first two year of my car's life, the oil cooler got a bit beat up. The fins are not straight after snow, sand, etc from MN roads - that has got to affect cooling very negatively as air can no longer easily make it through. I no longer drive it on the road much (and no longer in winter) and I have added guards for junk (e.g., track rubber) up front. I think my winter downtime mods this year will be oil and coolant related.
07-05-2023, 04:47 AM | #35 |
426
Rep 598
Drives: 2018 M2
Stage 2 91 octane (used 93 octane fuel)
Note the ambient temps at or near 86 degrees. Humidity was high, too. https://www.bootmod3.net/log?id=64a4...729bb107d77f83 Best time at the track was 1:41.5. A month ago on Stage 2+ with 93 octane, it was 1:39.8. |
07-05-2023, 08:52 AM | #36 |
437
Rep 753
Your oil and coolant temps in that chart looks nominal to me. Going back to your original question, you asked about a “efficient” intercooler. Is there some metric you want to make better or are you having a drivability issue? Or both perhaps?
07-05-2023, 10:04 AM | #37 | |
426
Rep 598
Drives: 2018 M2
I am still learning how to read the logs to determine what the car is doing based on IAT, coolant and oil temps (e.g., reducing timing or boost). |
pal437.00 |
07-05-2023, 09:37 PM | #38 | |
2379
Rep 4,218
The VRSF and MAD Race intercoolers are only about 5lbs more than your CSF and will outcool basically anything else. I've gotten as close as 3F over ambient with my intercooler on pulls. The comments here about the intercooler blocking the radiator also don't hold up. PAL is hitting about the same PSI as you and higher MPH with Sessions just as long (if not longer) M2Guru observations: Short shifts under 6000RPM often - I counted about 13 time at 6000RPM or over Max engine Speed is around 6500RPM About 1:55 seconds in, IATs reach 130F IATs reach a maximum of 140F IATs never drop below 121F Maximum speed 128MPH Coolant temps 225 Maximum oil temp 245F Run two Short shifts OVER 6000RPM often - I counted about I think 20 times at 6000RPM or over (I was interrupted while I was counting) Max engine Speed is around 6800RPM 6:480 (weird way to track time?) about 1.5 mins in the car hits 131F IATs reach a maximum of 148F IATs never drop below 119F Maximum speed 126MPH Coolant temps 235 Maximum oil temp 258F PAL observations: Shifts over 6000RPM - First lap I counted 5 times I believe X 4 laps - that's 20 times? Max engine speed is around 6800RPM Maximum speed is 127mph (Lap 3?) IATs reach a maximum of 134.6F IATs get as low as 116 - but it's more common to see 118F Maximum coolant temps 228F Oil temp not recorded If the frontal area is impacting radiator flow (and I don't think it is) I would expect there to be a steady increase in the Coolant temps, and there is not. Actually, often times the temps would decrease during the lap - and this is despite having 2 back to back 100mph+ straightaways. PAL is driving about as aggressively as driver 2 based on his shift points and speeds, and his intercooler does shed heat more efficiently. It should be noted M2Guru's car pushes more boost - however car 1 does have about 1-1.5PSI advantage at around 6000RPM where Driver 1 is consistently shifts at. If OP is looking for a better intercooler, the ER is an upgrade but not by a huge margin - a race core would be better. They will be the same height as the ER, and have similar depth in front of the radiator (3") and more thermal capacity so they'll take longer to heat up.
Mods: Yes.
07-05-2023, 10:19 PM | #39 |
2840
Rep 3,715
There’s 50whp difference bn these two cars/tunes. But sure, M2guru bolt on a bigger/taller IC, hit the longer track version, record the data, and let’s see how it goes.
I’m sure AmuroRay log interpretation is spot on. |
pal437.00 |
07-05-2023, 10:26 PM | #40 |
437
Rep 753
How did you get to 50whp? I’m at around 365whp (SAE corrected on a Dynojet), a Stage 2 car is at 378whp on the same dyno and same day. Is M2guru running close to 420whp?
07-05-2023, 10:35 PM | #41 |
2840
Rep 3,715
BM3 Stg 2+ 93 is 410whp. We’ll call it a 45whp difference.
I don’t mean to sound like a dick in all this, but me and several m2 track guys I know have been there done this years ago. When you add decent power to the OG and drive it hard on a fast track in >80F ambient, either IATs go to the moon and the car pulls power to prevent detonation or you put a larger IC on and coolant temps will overheat. I’ve said my piece, including creating a long separate thread about this, but hopefully it works out differently for you all. Last edited by ZM2; 07-05-2023 at 10:41 PM.. |
07-05-2023, 11:21 PM | #42 | |
437
Rep 753
07-06-2023, 10:43 AM | #43 |
2379
Rep 4,218
I was searching up about oil cooling - and I found a simpler solution that may work - an oil thermostat. It lowers the thermostat about 25F or more giving substantially more headroom.
I've been reading about the Mosselman unit all morning.
Mods: Yes.
07-06-2023, 11:30 AM | #44 |
4392
Rep 7,634
I raised this above. But if you are operating at the limit of the cooling system capacity, a lower t-stat will only buy you a little time. You will just be starting at a slightly lower temp but it doesnt add any cooling capacity.
