05-23-2007, 05:19 AM | #24 |
Never Lose
51
Rep 1,145
I graduated already my man...I am on Wall Street...hence why I am posting at 6:17am right now...you can ask Shiv he knows..
And as for the whole DTC thing you guys are scaring me...read the manual...you are not activating DTC when you press it...you are leaving DSC on and turning DTC off. If you hold the button you are taking both DSC and DTC off hence why you can drive like a maniac. This was the same on my E46 330 as well.
'11 Melbourne Red Metallic / Black/Fox/Fox 6MT E92 ///M3
ZCP | Convenience Package | Premium Package 2 | Heated Seats | Enhanced Premium Sound l BMW Apps |
05-23-2007, 05:37 AM | #25 |
Never Lose
51
Rep 1,145
Willing to bet anyone on the forum that thinks I am wrong about the DTC thing $100 via Paypal lol...PM Me and I will make a video tonight explaining DTC
05-23-2007, 06:10 AM | #26 |
182
Rep 2,916
im with the OP, i really thought the RS4 would take the 335i w/procede !
and what a great result man! the 335i is truely a beast! waiting for the videos
19" velocity CSL replicas staggured // Continental sport contact 2: rear: 255/35/19, Front: 235/35/19 // Blacklines // rear OEM spoiler // y-connector // 30% v-kool tint all around // Black Roof/Mirrors // H&R Sport springs // H&R TRAK+ 15mm spacers // BMW never makes ordinary cars . . . |
05-23-2007, 07:23 AM | #27 | |
Never Lose
51
Rep 1,145
Why would it SAY in the manual that if you are going through snow to hit the button? I drove my E46 330 in the snow. I couldnt go up my driveway. What did I do? I hit the DTC button once...it lets the tires spin but keeps the car straight. I was able to drive up my driveway gradually. I am not by my car right now but here's what you do if you do not wanna wait for my videos tonight. Go inside your car. Press the DTC button. READ what it says. It says DTC inactive DSC active. This means the STABILITY control will keep you straight yet TRACTION control is inactive, letting you spin the tires. I will post a video of 3 different launches with my car tonight. What you will see will be this...1) Car bogging and traction light flashing slowing the car down. 2) Tapping the DTC button - Car will let the tires spin and you can launch harder but the car will kick in if you move sideways. 3) Holding DTC - This will make the car inactive and fully non intrusive. You can spin the tires, go sideways etc. If you are by your car right now go OUTSIDE and let me know. It's not like I haven't done this.
05-23-2007, 07:29 AM | #28 |
164
Rep 5,389
That is correct; the '08 M3 will weigh a little less than the 335i; BMW has already released the weight...it's like 3,4xx lbs. I believe, due to the light V8 engine and CF roof, and other CF parts, etc.
|2009 RENNtech MB C63 AMG | Black/Black Leather/Black Maple | Premium II | MultiMedia | iPod | | TeleAid | Charcoal Filter Delete | BMC High-Flow Air Filters | High-Flow Secondary Cats | Clear Side Markers | |
05-23-2007, 07:33 AM | #29 | |
164
Rep 5,389
btw -- in regards to #4, I guess you haven't driven a PROcede-equipped 335i, have you? :rocks:
05-23-2007, 07:42 AM | #30 | |
Never Lose
51
Rep 1,145
:rocks: :rocks:
05-23-2007, 07:53 AM | #31 | |
164
Rep 5,389
"DTC Dynamic Traction Control DTC is a version of DSC in which the drive output is optimized for particular road conditions, e.g. unplowed snow-covered roads. The system assures the maximal drive output, but with reduced driving stability. It is therefore necessary to drive with appropriate caution. You may find it useful to briefly activate DTC under the following special circumstances: > When driving uphill on snow-covered roads, in slush or on unplowed, snow-covered roads > When rocking a stuck vehicle free or starting off in deep snow or on loose ground > When driving with snow chains Activating DTC Press the button; the indicator lamps for DTC in the instrument cluster come on. To control If the indicator lamp flashes: DTC controls the drive forces and brake forces. If the indicator lamps are on: DTC has been activated. Deactivating DTC Press the button again; the DTC indicator lamps in the instrument cluster go out." Now, you may "think" what you're doing by quickly pushing the DTC button, you're turning DTC off, but in fact you're actually turning DTC on...that's why when you did this and tried to go up your driveway in the snow, you could get up there since it gave you better traction and left DSC on (so you don't slide around sideways). You may have still had a little wheel/tires spin, but you would've just be spinning your wheels; without activating DTC, you wouldn't have been able to go up your snowy driveway at all, or at the very least, it would've been more of a struggle. The only thing we all agree about (and that's true according to the manual) is if you push and hold the DTC button for at least 3 sec., it will in fact turn OFF both DTC and DSC...traction control and stability control are deactivated...not recommended btw. Also, when the indicator light flashes (not the DTC lamp, but the triangle indicator lamp), it means that DTC is intervening and doing its job...yes, it applies brake forces and drive forces, but ultimately what it's doing is giving you better traction. This is why ppl with PROcede 335i's (including myself) get the best 0-60mph and 1/4 mi. times from a launch by activating DTC (1 quick push of the DTC button), b/c it aids in traction from a standstill and helps you hook up and go, go, go!
05-23-2007, 07:55 AM | #32 |
Never Lose
51
Rep 1,145
I understand and in no means am I trying to argue with a fellow 335er but why when you tap DTC does it let you launch and spin tires? What are you turning on? You have Idrive right? Go outside and tap DTC...read me what it says...I forget off hand
05-23-2007, 08:05 AM | #33 | |
164
Rep 5,389
Also, don't forget that if you do nothing (do not push the DTC button), both DTC and DSC are in standby or automatic mode, and will automatically activate briefly when the car sense wheel slippage or fishtailing, or whatever.
05-23-2007, 08:10 AM | #34 |
Never Lose
51
Rep 1,145
Even before I had PROcede, I would launch aggressively after I tapped the DTC button which would let me spin the tires but keep the car straight.
Turning DSC off completely is definately not safe lol...especially with PROcede
05-23-2007, 08:17 AM | #35 |
Expert Road Racer
59
Rep 1,329
DTC On for BMW (1 fast push of button followed by warning triangle and DTC light on) = Traction Control Off (or reduced) for many other makes.
I guess BMW considers full intervention traction control just standard mode, DYNAMIC traction control allowing more wheel spin a selectable option, and DSC/DTC OFF a rarely selected option. From Autospies: "Activation of DTC raises the threshold for intervention by the brakes, enabling the driver of a BMW 3 Series Coupe to set off smoothly on low friction surfaces such as snow. A benefit of DTC for the enthusiast is that it allows slight, easily controllable slip on the drive wheels even on a dry surface." The question, has anyone figured out how to make the default mode DTC ON? Other than getting into the habit of pressing the button each time. |
05-23-2007, 08:24 AM | #36 |
Never Lose
51
Rep 1,145
So am I right or wrong that pressing the DTC button quickly enables better wheel spin to launch? I have to be or I am on crack when I drive...one or the other lol
05-23-2007, 08:38 AM | #37 | |
164
Rep 5,389
I like the explanation that AutoSpies gave (as noted by sdiver68)... From Autospies: "Activation of DTC raises the threshold for intervention by the brakes, enabling the driver of a BMW 3 Series Coupe to set off smoothly on low friction surfaces such as snow. A benefit of DTC for the enthusiast is that it allows slight, easily controllable slip on the drive wheels even on a dry surface." So, in other words, activating DTC manually (so it's not in dynamic or automatic mode) doesn't allow the car to apply braking forces at the same point as it would if it were on auto or dynamic mode; yes, your tires will still spin a bit, but actually less b/c it's NOT applying the brakes quite so soon...it hooks up faster b/c DTC is actually activated and put into a different mode. As sdiver said, many ppl wish that DTC would default in this activated mode upon car start, but unfortunately, it's defaulted in the Dynamic or Auto mode, just like DSC. In order to put it into this mode, you always have to push the DTC button to turn DTC on. For me, I just leave it in the auto mode, unless I've been challenged at a light or something...that's when I give the DTC button 1 quick push, b/c I know I'll get a better launch that way.
|2009 RENNtech MB C63 AMG | Black/Black Leather/Black Maple | Premium II | MultiMedia | iPod | | TeleAid | Charcoal Filter Delete | BMC High-Flow Air Filters | High-Flow Secondary Cats | Clear Side Markers | Last edited by sflgator; 05-23-2007 at 08:55 AM.. |
05-23-2007, 08:54 AM | #38 | |
Never Lose
51
Rep 1,145
05-23-2007, 09:01 AM | #39 |
164
Rep 5,389
In Auto (or "Dynamic" DTC mode), it will apply braking force when it encounters wheel/tire spin sooner than when you manually activate DTC. The flashing triangle indicator light you see is when it's in this auto mode and it's telling you that DTC came on to counteract your wheel/tire spin...it's probably applying brake and drive forces to control the wheel spin. I'm not sure that activating DTC would help much from a roll; it seems to aid mainly from a launch.
05-23-2007, 11:22 AM | #40 |
460
Rep 1,301
The new RS5 is going to own...whether it be the e92 m3 or a proceded 335
'16 ///M4 GTS
'11.75 ///E90 M3 ZCP | DCT '06 ///M5 | SMG - Gone '98 ///M3 | 5MT - Gone '07 ///M Coupe | 6MT - Gone |
05-23-2007, 11:31 AM | #41 |
Never Lose
51
Rep 1,145
If it makes it to the US
05-23-2007, 12:20 PM | #43 | |
211
Rep 2,002
DTC is a subprogram of DSC. By pressing DTC once you are restricting DSC by allowing more tire spin. More tire spin means more traction... so now you are more likely to get more traction....Get it now?
05-23-2007, 12:25 PM | #44 |
Never Lose
51
Rep 1,145
My point more or less was that the car interferes LESS when you tap the DTC button, which it does
