08-21-2017, 04:50 PM | #23 | |
General
13127
Rep 18,795
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com Memorial Day SALE!! 05/24 - 06/03 • Coupon Code: "MEMORIAL" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
09-03-2017, 09:48 PM | #24 | ||
Rep 9
09-03-2017, 10:30 PM | #25 | |||
General
13127
Rep 18,795
PM me your address and I'll quote you for it shipped.
09-06-2017, 02:47 AM | #26 |
26
Rep 79
I've had my G30 since May. In the beginning the sound was nowhere near where is it now. Give it a couple of months. I'm happy with my HK, but I'm coming from F30 HS. So for me it is a big improvement.
09-12-2017, 03:14 PM | #28 |
186
Rep 235
I wasn't able to try the HK before I placed my order, I'm hoping it's going to sound good and go as low as I like. The one I demo'd had the level down from the HK, and it sounded ok, so I'm expecting it to be better than that.
I upgraded the audio in my C class Mercedes because the sound system was so poor, particularly the bass, so I could install the sub and amp from that if required. Has anyone here installed a proper sub on their G30? |
09-13-2017, 10:38 AM | #30 | |
1120
Rep 2,087
If its like all previous BMW's with HK it will be fairly easy - battery in boot, factory amp in boot so all the connections required are nearby. Just a case of which wires need to be tapped. |
09-14-2017, 03:45 AM | #31 |
119
Rep 565
I've had aftermarket systems in other cars before, mostly Alpine amps and JL Audio components and subs. I'm happy with the G30 factory HK woofers for now. Something like "Angel" by Massive Attack sounds clean and goes low enough, at any normal listening volume.
Definitely run the system in and play with the EQ before throwing more money at the bass. And IMHO it's the mids and tweeters that need attention before the amp or subs, unless you are a 17 year old hoping to impress your mates in a cold wet McDonalds car park on a Saturday night |
09-14-2017, 04:14 AM | #32 |
1120
Rep 2,087
09-14-2017, 04:23 AM | #33 |
119
Rep 565
It's not that they're bad in absolute terms, but they are the weakest point - slightly aggressive, make you want to scrunch your ears up a bit as you crank up the volume. Probably cheap components in the crossover plus classic "bright" sounding metallic dome tweeters. Bavsound units really improve things, not sure what other mids and tweeters you could source that are well matched to the factory amp and the other speakers.
09-14-2017, 05:21 AM | #34 | |
186
Rep 235
Do you know what impedance the HK mids and tweets are? I have focal 100krs components in my c class ATM which initially sounded really bright and I had to adjust the crossovers and turn the treble way down on the head unit to get them sounding good. The clarity they give is amazing, and being 4's they should fit the G30.. I was hoping specing the HK would save me doing another install, but I'll wait and see (or hear) what it's like when it arrives |
09-14-2017, 09:42 AM | #35 |
119
Rep 565
I think they're 4 ohms and the underseat woofers are 8 ohms but don't quote me.
The HK amp is rated at 50w to each mid+tweeter and 125w to each woofer, but I'm not sure that's RMS @12v. The Bavsound units are easy to drive and their response curve is ideal: after careful listening I have genuinely decided they sound best with the equaliser set flat all the way across on my G30.... |
04-29-2018, 01:26 PM | #36 |
45
Rep 107
04-29-2018, 01:29 PM | #37 |
General
13127
Rep 18,795
PM'ed
04-30-2018, 03:57 AM | #38 |
10
Rep 25
04-30-2018, 11:56 AM | #39 | |
General
13127
Rep 18,795
We do ship internationally.
05-08-2018, 11:59 PM | #40 |
2376
Rep 8,364
05-09-2018, 08:46 AM | #41 | |
General
13127
Rep 18,795
I have a few set coming in, I may just give it a try.
Almaretto2376.00 THEX5BEAST13.50 |
05-10-2018, 03:18 AM | #42 |
10
Rep 25
r33_RGSport13126.50 |
05-10-2018, 12:56 PM | #43 | |
448
Rep 1,963
Drives: I20 IX M60 Oxide Grey
I'd say the bass in the HK is mellow not harsh. Fits the persona of the 5 series I think...
Running: G30 530d M Sport (B57) Mediterranean Blue
Running: I20 IX M60 Oxide Grey Gone: F15 X5 40d M Sport (N57) Glacier Silver, E61 520d SE Auto (N47D20) Titanium Silver, F31 330d M Sport (N57D30A) Estoril Blue, E87 120d SE Auto (M47TU2D20) Sparkling Graphite |
05-23-2018, 02:53 PM | #44 |
General
13127
Rep 18,795
I just found out that I have the V2 already.
It just the newer shipment have that silver aluminum plate cover on top.
