BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) BMW E-sys coding for the f48 x1
      06-04-2017, 01:29 PM   #353
Almaretto
Almaretto's Avatar
2391
Drives: Test Vehicles
Originally Posted by hongkongloftus View Post
Hi
Can I code to show the gear number for driving in D position (D1, D2....) on idrive CID or instrument cluster?
Thank you.
Coding is in EGS. Whether you can on the F048, I know not.
      06-04-2017, 07:45 PM   #354
hongkongloftus
hongkongloftus's Avatar
Hong Kong
17
Drives: 09/2016 X1 F48 18d
Hi
Thank you.
Thank you Almaretto. Will try.
      06-06-2017, 01:55 AM   #355
hongkongloftus
Hong Kong
17
Hi Almaretto
I don't know which function in EGS. I find a forum said the function name in EGS is "Sportschalter" for display the gear position, but I can't find it as per attachment. Do you know which function in EGS need to code?
Thank you.
      06-06-2017, 01:13 PM   #356
Almaretto
Almaretto's Avatar
2391
Hi Almaretto
Thank you.
Not sure. On an F010, you want Sportschalter & Sportschalter_alt.
      06-12-2017, 06:04 AM   #357
makpowa
Spain
Drives: X1 F48 xLINE 18sDrive
@Almaretto can I get the latest download link ?
Thanks in advanced!
      06-12-2017, 12:37 PM   #358
Almaretto
Almaretto's Avatar
2391
Thanks in advanced!
Fxx, Ixx, & Gxx Series Coding: (No Request) Latest Software Links
      06-16-2017, 11:01 AM   #359
RckX1/F48
Drives: F48/X1
Automatic window roll up upon locking car
Hi.. I'd like to know if it is possible to automatically roll up all windows upon locking the car?
Really appreciate for any guidance and help on this matter.
Thanks
X1/F48
      06-17-2017, 12:26 AM   #360
Almaretto
Almaretto's Avatar
2391
Thanks
X1/F48
If you drive a G30. Otherwise, you have your automatic switch.
      06-18-2017, 03:37 AM   #361
RckX1/F48
Drives: F48/X1
Thank you for taking the time to response
Car is X1/f48 20D
If I press long enough using the comfort access on the door handle to lock the door or press the fob bottom also long enough, it will close all the windows and also fold both side mirrors.
Is there by coding a way to change the window roll up to instant instead of long press?
Thanks again
      06-18-2017, 05:47 PM   #362
Almaretto
Almaretto's Avatar
2391
Car is X1/f48 20D
Thanks again
KOMFORT_SCHLIESSEN is the initiation delay, but you still have to hold CA or keyFOB during window movement until desired level reached.
Personally, I use interior switch if windows are completely down and CA if only slightly cracked.
      06-18-2017, 10:09 PM   #363
RckX1/F48
Drives: F48/X1
Car is X1/f48 20D
Thanks again
Thanks a lot Almaretto! Your a great help to all of us in this forum.
Normally, I use the interior switch to close the windows. Unfortunately, the windows will stop closing once you open the driver side door and it happened one time when I was in a hurry and went out. I didn't notice that one of the rear passenger window was only partially closed when I locked the doors. .
      06-19-2017, 12:46 AM   #364
Almaretto
Almaretto's Avatar
2391
So disable window safety and then you can continue to roll up with doors opened.
      06-19-2017, 01:47 AM   #365
RckX1/F48
Drives: F48/X1
Sorry to ask again. But can it be disabled also by coding?
Thanks thanks thank you.
      06-19-2017, 01:31 PM   #366
Almaretto
Almaretto's Avatar
2391
Yes; I would not have suggested if not possible.
      06-23-2017, 06:37 AM   #367
pedro mtech
pedro mtech's Avatar
30
Drives: BMW X1 F48
Hi. I can't find this in my car. I've read that I should update the Launcher. Do I?
Soft Blink = 5 Times
3069>PIA_DEFAULT_TIPPBLINKEN = tippblinken_fuenfmal werte set to: 02
      06-23-2017, 02:43 PM   #368
Almaretto
Almaretto's Avatar
2391
Are you using 2.7.1? How about latest Cheat Codes?
      06-29-2017, 07:50 AM   #369
pedro mtech
30
Drives: BMW X1 F48
What's exactly the the thing I should upgrade? Esys premium Launcher?
Do I have to uninstall everything in the laptop and start from the beginning?
      06-29-2017, 11:36 AM   #370
hongkongloftus
Hong Kong
17
I use launcher v2.6.2, e-sys 3.28.1, psdzdata 60.3, and I can find that function to code as 5 blink.
      06-29-2017, 01:58 PM   #371
Almaretto
Almaretto's Avatar
2391
  1. E-sys Launcher can be updated without first uninstalling.
  2. PSdZ should be deleted and replaced (if you are getting "not found [C012]" read errors)
  3. I would stick with E-sys 3.27.1 rather than updating to 3.28 or 3.29 to avoid Java runtime errors.
2.6.x was when mapping was updated to P3.59.4. You can update to latest for additional optimization, but I would avoid if using virtualization until Tokenmaster returns.
      07-03-2017, 01:18 AM   #372
DG20
DG20's Avatar
977
Drives: 2011 E92 M3
Hey guys, my car was coded before i took it into the dealer and now everything got erased. Plugged my computer in to code it again and it's not letting me code the BDC BODY module and it keeps saying that it isn't found. Any ideas on this?
EDIT: Figured it out! Needed to update my files
Instagram: @zcp.spec
      07-04-2017, 03:19 AM   #373
ramonE90-NL
Netherlands
36
Drives: bmw F30 320iA
Hi, i'm new to coding the f48, what target do i have to select?
For my f30 i have to select the f20 model
      07-04-2017, 10:57 PM   #374
stefan
stefan's Avatar
No_Country
2375
Drives: M2 Comp
F056
///M Power
