View Poll Results: Which PSS size for the OEM 19" wheel | |||
255/35R19 - 275/35R19 (F8X specific) | 75 | 17.01% | |
255/35R19 - 275/35R19 (Generic) | 26 | 5.90% | |
265/35R19 - 285/35R19 | 109 | 24.72% | |
275/30R19 - 295/30R19 | 62 | 14.06% | |
275/35R19 - 295/35R19 (F8X-F1X specific) | 169 | 38.32% | |
Voters: 441. You may not vote on this poll |
05-17-2016, 03:39 PM | #265 |
General
21133
Rep 20,742
Drives: 2021 911 turbo
I have just gotten the 265/35R19 M0 spec PSS installed in the front.
I just came back from 2 track days at LCMT in semi-dry semi-wet (including snow ) conditions. So I mostly lapped with the PSS on the car. This exhausted whatever life was remaining on my front 275/35R19 PSS (the original rears). Interestingly, they corded on the inside first. I had already observed the inner shoulder wearing faster. Maybe this comes from the fact that these are intended as rear tires and have a squarer contact patch . First observation from the 265 is the the longitudinal channels in the tread are much wider than the 275/35R19 BMW star spec I had up front. This should reduce the increased aquaplaning sensitivity I had with the 275. The tire is also quite meaty, filling the fenders well. First impression from the short drive from the shop to my house is that there is less feedback coming through the steering wheel compared to the 275, I however cannot recall how it felt with the OE 255 though. There is also much less tram-lining going on, which is a good thing. I will wait for the tires to break-in before posting a more substantial review.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 05-17-2016 at 09:14 PM.. |
05-17-2016, 07:55 PM | #266 |
1596
Rep 3,945
Drives: 2015 M4 MG/SO
where did u buy and install them? Prix?
05-17-2016, 08:43 PM | #267 |
General
21133
Rep 20,742
Pneu Expert in Longueuil. $349ea.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
05-17-2016, 08:47 PM | #268 |
423
Rep 4,499
CanAutM3 any pics of the set up?
Have BT Tool professional, will scan and clear codes on your BMW. And now I am able to code my 2011 335is and M4
Link to my M4 euro delivery! http://f80.bimmerpost.com/forums/sho....php?t=1006526 |
05-17-2016, 08:49 PM | #269 |
1596
Rep 3,945
05-17-2016, 09:17 PM | #270 | |
General
21133
Rep 20,742
IIRC, the hunter force machine would help to cure a car that pulls to one side, but shouldn't affect vibrations...
05-17-2016, 09:34 PM | #271 | |
1596
Rep 3,945
But when it comes to changing my tires, I trust that you are quite content with that shop and will visit them! Thanks for the info. |
05-19-2016, 07:26 AM | #272 | ||
98
Rep 475
05-19-2016, 08:51 AM | #273 | |
General
21133
Rep 20,742
05-19-2016, 09:20 AM | #274 | |
General
21133
Rep 20,742
The measurement in blue from my freshly mounted M0 compared to the ones from Mark's M. I also added tread width as measured by TireRack in inches and extrapolated "rubber on the road" width. The latter is highly un-scientific and should be used as a ballpark figure only. OEM(not mounted) 8.5" - 1.5mm, 15mm, 15mm, 15mm = 169mm M01 (mounted) 9.4" - 6mm, 11mm, 13mm, 12mm = 197mm M0 (mounted) 9.3" - 3mm, 16mm, 18mm, 18mm = 181mm Pictures:
05-19-2016, 09:45 AM | #275 | ||
98
Rep 475
05-21-2016, 12:46 AM | #276 | |
617
Rep 1,820
2016 Individual Silverlake/Amaro M3 Conceived by ///M
06-07-2016, 06:53 AM | #277 |
Rep 33
06-07-2016, 08:42 AM | #278 | |
Rep 110
06-07-2016, 09:22 AM | #279 | |
General
21133
Rep 20,742
The tread of the generic 255 is almost as wide (9.2") as the 265 M0 spec (9.3"). However, I find the diameter a bit smallish to be paired with a rear 295. The 275 BMW spec has a 9.5" tread, but is not ideal when used as a front tire. The generic 255 would match great with the generic 275. I had this combo on my E92 and loved it .
07-13-2016, 10:29 AM | #280 |
Addicted to Speed.
714
Rep 2,375
i took the leap
295/35/19 star spec with 265/35/19 mo spec ordered i thank everyone for their contributions
2017 991.2s
2015 F15 35i 2017 Macan gts |
07-13-2016, 02:39 PM | #281 |
General
21133
Rep 20,742
You won't be disappointed . I love this combo .
07-16-2016, 08:32 AM | #282 | |
Addicted to Speed.
714
Rep 2,375
update on this; I am lowered on swift spec R 295/35/19 fit without a hitch, even was able to put my 12mm spacers on for a perfect flush look 265/35/19- not so great fit, the taller tire looks tucked, and I was unable to put my 15mm spacer up front because the taller tire rubbed the fender lining when the wheel was turned. The car feels great though, TONS of grip, really like how the car feels. I am thinking of trying a 5-10mm spacer just to get the tire closer to the fender wall. I will post pictures later to illustrate my point; If I have further rubbing issues I am wondering if i should go back to 255/35/19 up front.... i am wondering how adverse of an effect that would have on handling..
2017 991.2s
07-16-2016, 08:52 AM | #284 | |
General
21133
Rep 20,742
07-16-2016, 09:03 AM | #285 | |
Addicted to Speed.
714
Rep 2,375
2017 991.2s
07-25-2016, 03:46 PM | #286 |
91
Rep 260
sorry to bump a thread
but consensus is that the 265/35/19 M0 tire won't fit with lowered and 15 mm spacers up front correct? However the 295/35/19 does fit rears with 12mm Any good front tire that can fit with spacers? or just use the stock 255? |
