01-15-2024, 01:54 PM | #243 | |
83
Rep 338
01-15-2024, 02:30 PM | #244 |
18
Rep 43
HS
Having it retain more heat is what you want. Same pricinple as wrapping things or using a blanket to keep the heat in. More heat on the exhaust gas side increase gas velocity.
01-15-2024, 02:55 PM | #245 |
83
Rep 338
Oh, maybe I should pick up one of these today. Lol! Thanks! You know how much it weighs approximately? The one I have is super thin but effective for what it is. I'm hoping no more than a half a pound. No additional weight wanted.
01-15-2024, 05:14 PM | #246 |
18
Rep 43
HS
Yeah I had the exact same thing and believe me when I tell you that it's WAY different in terms of performance. I would also suggest to put some DEI Reflect-a-Gold on the back. Don't use the China knock off version of the reflective tape either. It doesn't work nearly as well (This has been tested numerous times).
The piece is made from a precision bent sheet of coated alumninum. It's a few pounds for sure and has way more heat blocking potential than the Ross Racing one. It also covers the top area of the downpipe which the RR does not. The OEM heatshield will be completely removed once this one is installed and it's a way cleaner appearance with dramatically better performance. |
01-15-2024, 05:31 PM | #247 | |
83
Rep 338
04-13-2024, 11:03 AM | #248 | |
1651
Rep 2,286
04-16-2024, 09:03 AM | #249 |
18
Rep 43
Zero issues with the DEI reflect-a-gold on the back of the heatshield. It really does a fantastic job of keeping the turbo and manifold heat contained. The better blocking potential of the larger heat shield paired with the tapes ability to block large amounts of radiant heat keeps the entire engine bay noticeably cooler. Don't skimp on the tape though. The knock-off brands do not work as well as the DEI tape does.
05-19-2024, 04:25 PM | #251 | |
Rep 52
Stock intake is perfectly fine with the flow max or any others hybrid turbos |
05-19-2024, 04:29 PM | #252 | |
Rep 52
Air will flow through the engine bay during driving so heat is evacuate without any problem. And before your answer : I know you don’t have data and now one provide any data for months because there isn’t any gain. |
