BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Bimmercode Adventure
      08-13-2019, 06:10 PM   #199
kavatski
147
Drives: 2023 X3 30iX
Originally Posted by DARKMTTR View Post
Has anyone successfully coded trunk closing with the key fob? I activated the option on Bimmercode but it doesn't seem to work.
Works on ours - you have to hold the button on the fob down briefly, and then it closes.
DARKMTTR229.00
      08-14-2019, 02:56 PM   #200
SDriver18i
SDriver18i's Avatar
No_Country
80
Drives: BMW X1 s18i 2019
Originally Posted by Karabas View Post
Experts «What Car?»
Old news. Just get a faraday case to keep your key in so no signal gets out. No such thing as a “special” case.
Oh and don’t buy bullshit cheap ones that don’t block signals and then claim it didn’t work.
      08-18-2019, 11:47 AM   #201
MauroSte
MauroSte's Avatar
Croatia
Drives: BMW F48 X1
Originally Posted by MJE60 View Post
Originally Posted by iceman7 View Post
No connected services for us in Greece especially in older models with idrive 4.
Needs coding to have the office menu but then I am not sure if more than that can be done.
Anyway you really made me waiting with baited breath for your next project to "retrofit" the AutoHighBeam feature.
Are you sure that only the simple ActiveGuard camera is all that is needed in the existing spec of the car (ie before changing the lever and coding).
If so where did you find the lever and how can you install it?
Hi Iceman7
Here is my best guess at settings you need to change to enable office/email functions. All are in expert mode and please note you may not have all of them (some are options dependent on HU). Please note you will need to disconnect and reconnect phone and also make sure your phone "office connection" is ON and "phone notifications" is ON and notifications for text is ON. [in your phone settings menus]
Coding - please note I have not verified these and you will not have all of them. All are in expert mode. What is possible will depend on your car specification. I am told F48 without enhanced Bluetooth do not have a COMBOX and without COMBOX "office" activation is not possible. I cannot therefore advise on what functions it will actually be possible to activate! Perhaps limited functionality.
All these should be in HU . I would first search in expert mode for email, sms, office, contacts and make a list of everything you find and location. It would not hurt to also check in BDC Ecu and any other Ecu which might be relevant (you should not have separate BT or Comms boxes but make sure.
Finally here is my list ———>
You need to change setting from nicht to aktiv.
EMAIL_EIN_AUS
SMS_EIN_AUS
TASK_EIN_AUS
TEXT_NOTES_EIN_AUS
CONTACTS_EIN_AUS
CALENDAR_EIN_AUS
REMINDERS_TRIGGERS_EIN_AUS
PIM_BON_EMAIL
PIM_NEW_ELEMENT_EMAIL
PIM_NEW_ELEMENT_SMS
PIM_HTML_EMAIL_BROWSER
PIM_NEW_ELEMENT_VOICE_EMAIL
MACRO_PIM
PIM_BILDER_EIN_AUS
You may need to experiment. I would start enabling all the EIN/AUS first. καλή τύχη
For anyone else reading this post please note that easiest and best way for owners with Entrynav2 HU and connected drive services, is go into connected drive and enable functions!
Hi,
tried to enable the office functions on Entrynav2 HU...partially succeeded (visible in settings but mails are still grey).
Can you give me more informations how can I use it ?
Following codes can't be found:
PIM_BON_EMAIL
      12-21-2019, 04:13 PM   #202
SDriver18i
SDriver18i's Avatar
No_Country
80
An update on how to activate Fog lights with Welcome Lights with Bimmercode in the F48.
A quick reminder that this will turn on your fogs lights everytime you turn on your high beams!
That's the only way you're gonna get the fog lights to work with the welcome lights.
Bimmercode > BDC OR FEM > ExpertMode > LCELampMapping
Change the following:
MAPPING_SIDEMARKER_L_FUNCTION = 05 (High Beam)
MAPPING_SIDEMARKER_L_OUTPUT = 0B (Fog Lamp L)
MAPPING_SIDEMARKER_L_PWM_LEVEL_STANDARD = 89 (13.7V)
MAPPING_SIDEMARKER_L_FIXED_PWM = 00 (pwm)
MAPPING_SIDEMARKER_L_PRIORITY = 03 (bottom priority)
MAPPING_SIDEMARKER_R_FUNCTION = 05 (High Beam)
MAPPING_SIDEMARKER_R_OUTPUT = 0C (Fog Lamp R)
MAPPING_SIDEMARKER_R_PWM_LEVEL_STANDARD = 89 (13.7V)
MAPPING_SIDEMARKER_R_FIXED_PWM = 00 (pwm)
MAPPING_SIDEMARKER_R_PRIORITY = 03 (bottom priority)
Example:
x1noob3.00
      12-21-2019, 05:37 PM   #203
Takabo
Takabo's Avatar
Japan
49
Drives: G21 320d xDrive Touring MSport
Hello.
I realized the Welcome Lights in a different way.
BMW 320d xDrive Touring M Sport(G21)
Production Plant: Munich, Production Date: 2021-02-25
      12-22-2019, 04:06 AM   #204
SDriver18i
SDriver18i's Avatar
No_Country
80
Originally Posted by Takabo View Post
Hello.
Nice!! How? Would love to know your method.
Takabo49.00
      12-22-2019, 04:44 AM   #205
Takabo
Takabo's Avatar
Japan
49
Hello,
This is the format. For details, PM was sent.
Various Welcome Lights
BDC_BODY> 3062-3064 LceLampMapping… >
MAPPING_#_L/R_PART_OF = “custom number”
      12-22-2019, 12:27 PM   #206
miss
Drives: bmw x1
Hello,
could you explain this better, thanks: lol:
Takabo49.00
      12-22-2019, 02:27 PM   #207
Takabo
Takabo's Avatar
Japan
49
Replace # with German for Fog Lights (front), Turn Signal (front), Turn Signal (door mirror) and Turn Signal (rear) respectively.
I sent a PM.
      12-22-2019, 03:26 PM   #208
miss
Drives: bmw x1
どうもありがとうございま
Thanks a lot
muchas gracias
Takabo49.00
      12-23-2019, 02:57 PM   #209
SDriver18i
SDriver18i's Avatar
No_Country
80
Hello,
Thanks Takabo. It works perfectly!
Takabo49.00
      12-23-2019, 03:53 PM   #210
Takabo
Takabo's Avatar
Japan
49
どうもありがとうございます
Thanks a lot
muchas gracias
I am glad that the Welcome lights friends have increased.
Let's be careful about battery discharge! (^ _-)-☆
      12-26-2019, 01:39 AM   #211
euphoriaa
Drives: 2016 X1 20i
Hello,
Has anyone experienced one of the DRL looking dimmer than the other side? Is there a way to re-code or reset it back to original brightness?
      01-26-2020, 07:12 PM   #212
Takabo
Takabo's Avatar
Japan
49
Hello,
My car is F39. . .
It was made with information on the net.
Convert fog lights to cornering lights.
BDC_BODY> 3062 LceLampMapping1, C3>
MAPPING_ABBIEGEL_L_OUTPUT = nsw_l = 0B (default: off = 00)
OPTIONS (nsw_l = 0B, fl_l = 07, off = 00)
MAPPING_ABBIEGEL_L_FUNCTION = abbiegelicht_l = 09 (default)
OPTIONS (abbiegelicht_l = 09)
MAPPING_ABBIEGEL_L_PRIORITY = priority_1 = 01 (default)
OPTIONS (priority_1 = 01)
MAPPING_ABBIEGEL_R_OUTPUT = nsw_r = 0C (default: off = 00)
OPTIONS (nsw_r = 0C, fl_r = 08, off = 00)
MAPPING_ABBIEGEL_R_FUNCTION = abbiegelicht_r = 0A (default)
OPTIONS (abbiegelicht_r = 0A)
MAPPING_ABBIEGEL_R_PRIORITY = priority_1 = 01 (default)
BDC_BODY> 3066 LceTmsCoding1, FC
KL_ENABLE_LI = KL_Ein = 01 (default: KL_Aus = 00)
OPTIONS (KL_Aus = 00, KL_Ein = 01)
KL_ENABLE_RE = KL_Ein = 01 (default: KL_Aus = 00)
BDC_BODY> 3073 LaMaster1, FC>
C_BLC_ENA = F015_enable = 01 (default)
OPTIONS (F015_disable = 00, F015_enable = 01)
C_CLC_ENA = F015_enable = 01 (default)
Since my F39 fog light is LED, the following FDL items need to be added.
(This is what I analyzed.)
add to--------------------------------------------------------
MAPPING_ABBIEGEL_L_PWM_1 = 100% = 64 (default: 13.0V = 82)
OPTIONS (12.4V = 7C, 12.8V = 80, 13.0V = 82, 13.2V = 84, 13.4V = 86, 13.7V = 89, 100% = 64)
MAPPING_ABBIEGEL_L_FIXED_PWM = fixed = 01 (default: pwm = 00)
OPTIONS (pwm = 00, fixed = 01)
MAPPING_ABBIEGEL_L_DIMMED = not_active = 00 (default: active = 01)
OPTIONS (not_active = 00, active = 01)
MAPPING_ABBIEGEL_R_PWM_1 = 100% = 64 (default: 13.0V = 82)
MAPPING_ABBIEGEL_R_FIXED_PWM = fixed = 01 (default: pwm = 00)
MAPPING_ABBIEGEL_R_DIMMED = not_active = 00 (default: active = 01)
This allows you to use both the cornering light function and the fog light.
The fog light works as a cornering light with the headlight switch in the AUTO position.
1. When the left and right turn signals.
2. When turning the handle left and right.
3. When backing in reverse gear (both left and right lights).
What are the specifications in your country?
Appreciate 2
iceman7117.00
      02-21-2020, 05:25 AM   #213
Jorix
73
Drives: BMW 120d, BMW X1 xDrive20d
Hey. Maybe it has already been discussed somewhere in this topic, but it's too large so I'll ask again - is it possible to code additional ambient lightning colors for the pre-lci ?
      02-21-2020, 05:45 AM   #214
Gregh1
Drives: BMW X2 F39
Hi @Takabo,
Very impressive work !
Are you able to find me this kind of codes :
Activate High Beam Assist (i already have the camera for road sign)?
Activate the electric parking brake when cut off the engine?
Thanks for your help
      02-21-2020, 07:18 AM   #215
Takabo
Takabo's Avatar
Japan
49
Originally Posted by Gregh1 View Post
Hi @Takabo,
Hi Gregh1,
Japanese version F39 does not have high beam assist coding because it does not have a steering column switch for high beam assist.
I do not know the coding of the electric parking brake(>_<)
      02-21-2020, 07:56 AM   #216
Gregh1
Drives: BMW X2 F39
Thank you for your reply.
No problem. I have to find a way to do it
Takabo49.00
      02-21-2020, 06:00 PM   #217
Akachi
Drives: F48 X1
Any code to be able to have fog lights on with lights set to drl?
      02-21-2020, 07:34 PM   #218
Gregh1
Drives: BMW X2 F39
I have some questions.
- Is it possible to had the fog lights for welcome lights (with auto mode)?
I have seen that it is possible but it's also with High beam assist...
- I try to found a way to activate the electric parking brake when cut off the engine like auto hold do. I have seen this mode > "PfHandBrake". And then Handbremkontakt.
Do you think that it could be what i'm looking for?
Thanks
      03-04-2020, 05:56 PM   #219
MJE60
MJE60's Avatar
England
681
The short answer is NO. The long answer is that you can code in different colours but they will not work because the X1 Does not have multicolour LED fitted to make it work (higher series BMW have multicolour ambient lighting LED so many colours can be programmed whereas X1 has red/orange only (although I understand a few countries have a different single colour for legal reasons).
      03-04-2020, 06:00 PM   #220
MJE60
MJE60's Avatar
England
681
Hi @Takabo,
You can code but you will also need to fit steering column switch for it to work. Another project I need to finish but am reluctant to remove airbag module so it is still waiting.
