10-01-2020, 10:01 PM | #199 | |
550
Rep 949
The other log running a 1-2psi additive looks good. I'd drop Terry an email if you're working with him and ask him to check your boost scaling in the app. I see some indication the app may be reporting more boost than you're actually running here. |
10-01-2020, 10:05 PM | #200 |
303
Rep 1,089
Thanks for the quick look.. I thought the boost safety was only applied for the custom map6, not globally. So both map 1 and map 2 hit way past it.. but the map6 with a +1 boost value manages to stay right at that 27 threshold which sounds fair. But again, if I remove that plug, then that 27psi limit no longer is applied (and I can't get any datalogging).
10-01-2020, 10:12 PM | #201 | |
550
Rep 949
10-02-2020, 02:30 AM | #202 |
107
Rep 284
Fuel-It! I cannot connect the app to the car using the OBDII port, rather can only connect using the BT app, but that gives me an extremely limited range of what I can and cannot do - I can change the map and it displays the map and that's it.
I was told that version 18 of the firmware would protect the car in the event that the failsafe threshold is surpassed, although I don't have either version 17 or 18 of the firmware as I have the CARB version. Please take a look at what I am running and let me know please, as you seem to be connected to BMS in some way, if the firmware I am running will protect me should I decide to run map 2 and trigger the failsafe parameters as for whatever reason unbeknownst to me my OBDII cable is not at all working, although the OBDII port itself is as I can connect to bimmercode quite easily. While the image below states that I am set to map 2, I am currently set to map 1 as I don't trust the software alone without confirmation from someone who knows what the hell CARB version this is will do once I reach unsafe parameters. Thanks in advance!
Alpine White BMW X2 M35i
10-02-2020, 08:07 AM | #204 |
227
Rep 346
10-02-2020, 08:15 AM | #205 |
107
Rep 284
okay, question - so when i'm logging, how long am i supposed to log for as i've been asked to log using map 1 by BMS as my OBDII cord isn't working at all to connect the unit, the car, and the app...?
10-02-2020, 10:23 AM | #206 | |
550
Rep 949
Main thing though is to contact BMS for support. I just happened to be passing through here, but this is all straight forward stuff. |
21M235IXGC79.00 |
10-02-2020, 10:52 AM | #207 |
303
Rep 1,089
Sorry what do you mean by that? You can't load my log.. or can't see anything? You do need it as a regular CSV file but what I posted was a zipped folder (in order to post it).
Fuel-it! Just posted a screenshot of my map2 log further up. |
10-02-2020, 10:58 AM | #208 | |
303
Rep 1,089
Back to map 0 to be safe since everything got rescrambled in the firmware attempt. Map 0 feels fine on the highway, but pretty sluggish going up my parking garage ramps. I have been so used to map 6 now I can tell the difference. Map2 still is a ton nicer, we just have to figure out the right combo to make this JB4 work!. Xcelir8BMW I hope your TDI maps work.. but at the same time I would love you to start playing with this JB4 I'm most curious how the regular driving behavior will be. |
10-02-2020, 12:17 PM | #210 | |
107
Rep 284
10-02-2020, 01:33 PM | #211 |
107
Rep 284
i cannot get the goddamn help that i need - the unit is not working correctly and damn bms support is not responding. this is incredibly frustrating.
i'm supposed to update to a version of firmware that's not available to me and that's supposed to solve all of my problems except i cant and no one is respondinggggggggggggg.
10-02-2020, 01:42 PM | #212 | |
406
Rep 1,104
10-02-2020, 01:55 PM | #213 |
107
Rep 284
ugh, i swear someone better respond.
10-02-2020, 02:31 PM | #214 |
107
Rep 284
bam! my problem is solved - failsafe is in place, firmware is updated, car is running fantastically! convoluted solution to a rather simple problem, but it was solved nonetheless. woo hoo!
bms wants me to log in map1 to see where my car stands, but i don't quite understand why as my car should respond exactly the way every other car with this engine stands using map1. i mean, i'll do it, but i don't quite get why.
10-02-2020, 04:37 PM | #215 |
550
Rep 949
Why do doctors make you take a physical every year when most people are just fine and not going to keel over anytime soon?
Davy Jordi107.00 |
10-02-2020, 04:46 PM | #216 |
406
Rep 1,104
10-02-2020, 04:54 PM | #217 | |
406
Rep 1,104
10-02-2020, 04:56 PM | #218 |
107
Rep 284
welp, you have the jb4, don't you? because you don't have to worry about a limitless amount of boost blowing up your engine if you install the jb4 unit.
10-02-2020, 04:57 PM | #219 |
107
Rep 284
yes, it surely is. i was not going anywhere without that failsafe mechanism in place. totally a backup as i have v 18 of the firmware now installed which in itself will prevent boost spikes like you're experiencing, but peace of mind nonetheless.
10-02-2020, 05:03 PM | #220 |
406
Rep 1,104
Limitless? Huh? I have, for now, 7 modes of max which has a ceiling programmed not to go above it. And spikes I have are not bad and predictable. It is all about the tooling and what reads and compares to what. In stock mode I challenge you if the JB4 can do it to see what instrumentation it reads versus actual vacuum tap.
