05-03-2023, 12:58 PM | #1 |
Rep 1
Cruise control not turning off
Hey, I have BMWX1xDrive20i. When I press the cruise button it sets me to the speed but when I hit the brake pedal the car brakes but the cruise control sign still appears on the speedometer display.
Can someone suggest why this is happening or am I doing something wrong |
05-03-2023, 02:56 PM | #2 |
40
Rep 85
You activate the CC then set it. When you brake, it turns off the set speed. The CC is still 'ready' so you can resume. You have to turn CC on to use it at all.
05-04-2023, 09:56 AM | #3 |
4537
Rep 7,586
Ditto...you can hit the resume button and it will return to the last set speed.
This should also be explained in the owners manual...and if you have iDrive...there should be an embedded owners manual that has multiple ways of searching. You could simply start to type CRUISE into the keyword search and you should get a list of topics to select that will explain how the feature works on your BMW. Example (except OIL was the keyword):
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 05-04-2023 at 10:07 AM.. |
