01-27-2020, 11:23 AM | #1 |
103
Rep 279
Sunroof Air Leak
On our 2016 X1, we have started to hear air coming in from the front of the sunroof even when it is closed. There is actually no air penetrating the car but you do hear it, especially at highway speeds. When we push up at the front of the sunroof, the sound disappears.
We went to the dealer and they said it is most likely the seal, and if it is, that is not covered under the extended warranty and they would have to charge me a one hour as a diagnostic fee. I guess I will have my indy BMW guy repair it for a much lower cost and save me this ridiculous diagnostic fee. Anyone ever have this sound in their X1 and is it the seal? Thanks Last edited by MichaelInChicago; 01-27-2020 at 11:30 AM.. |
01-27-2020, 01:20 PM | #2 |
303
Rep 1,089
I can't answer it for the X1, but on my e60 there is TONS of air noise as the car gets old and it is indeed the air seal. $50 and 1 hr of my time to rip it off and put it in.. and happy as a clam. I'm kind of surprised that something simple like that would not be under warranty for really a little under 4 yrs old. Honestly if that is the case I would certainly just do it myself if possible. You know what.. I suppose if it was the seal what you could do is literally put painters tape all over the outside seal and if it's quiet, then it is indeed wind noise from that seal. Painters tape will come off without leaving a sticky residue.
01-27-2020, 11:07 PM | #3 |
338
Rep 1,646
It's possible it's the seal...but you say the sounds goes when you push upwards on the sunroof. So based on that, it might be just an alignment issue.
Have you tried firstly, to 'reset' the sunroof? I think the manual usually outlines the procedure for that. I remember a BMW master tech telling me that to minimise the wind noise from the sunroof, the leading edge needs to be a little lower than the car body, and slightly higher at the trailing edge.. cheers
2019 X3 M40i, Sophisto grey, H/K, pano
Previous: 2019 BMW X2 Msport, Mineral Grey, Adaptive Suspension, H/K Previous: 2009 335i LCI, Bluewater |
02-15-2020, 03:44 PM | #5 |
103
Rep 279
I tried resetting the pano roof and the wind noise is still there.
As well, when I push up at the front of the closed roof glass when driving, the wind noise disappears. Would that lead you to think it is the seal? |
03-16-2020, 04:32 AM | #6 |
Rep 3
I have the issue with my roof. Dealer said because i bought the car in AZ and live in PA the weather variance from the heat to cold messed up the seal. Having replaced this week. Will let you know.
02-24-2024, 01:07 PM | #7 |
Rep 10
Wind noise from sunroof fix
I have dealt with wind noise from the sunroof of my wife's 2019 X1 since we got it with 50k miles on it. Its now at 75k and I finally fixed it. I did some measuring of the gaps between the roof and glass in the front and back of the sunroof. There was a decent difference in the front. To the point I could easily stick a credit card in the gap between the seal and the front glass. I thought I was going to need a new seal. Last night I got to inspecting the glass from inside the vehicle. I loosened the 4 T25 bolts (these would have to be removed if you replaced the seal) holding the rear glass in place ( this was with the front glass portion tilted up) and moved the back glass forward just a bit. I then tightened the back glass in place. I then closed the front glass and loosened the 6 T25 bolts and moved it forward a bit to where there was no gap between the glass and seal. I then tightened the bolts up and it is way better now. I did have to push down from the top and then tighten the bolts on the front and rear glasses. The job may be easier with 2 people but I was able to do it myself. Drove the vehicle this morning and it is 100% better. I hope this helps some of you!
