05-06-2016, 12:35 PM | #1 |
80
Rep 111
Upgrade my X1 with Harman Kardon Tweeter
I drive my X1 with full satisfaction for the past 2 months
I ordered the "Hifi Upgrade" with the amplifier and center speaker. The sound is very good, good bass and full mid, but I missed the sparkling high. The "Hifi Upgrade" missing the tweeters ( EU Packages ) I ordered separately tweeters (HK) in parts from the BMW dealer. They are grids with a complete door frame, the tweeters are standard in the grid ( 60,- dollar each ) Installation time about 20 minutes per door, and it fits perfectly. Solder the wires on the midrange speaker. The tweeters have standard filters in the connecting wires. It sounds great now! Sparkling high ! |
05-06-2016, 12:56 PM | #2 |
268
Rep 1,597
Great mod
Current: VW Transporter Sportline, F48 X1 20i M Sport. Previous: F10 530d M Sport, W176 A200 CDI AMG Evolution, E70 X5 3.0 SD M Sport, F20 120d M Sport, E81 120d M Sport, E46 325i M Sport, E46 318ci & Many Others...
05-06-2016, 01:17 PM | #3 |
1583
Rep 4,587
Nice!
Current: 2021 ///M3 Competition Isle of Man Green
Ordered: 2024 ///M2 Zandvoort Blue Past: 2018 X3 ///M40i | 2012 328i | 2009 335i | 2007 335i Coupe | 2005 545i | 2001 325i |
05-06-2016, 03:10 PM | #4 | |
Rep 24
Could you please post the Left and Right part Id ? Thanks in advance |
05-06-2016, 06:51 PM | #5 |
2006
Rep 2,154
Drives: F80 and G80
Great work. Nice idea. Do you know if the standard audio system has floor mounted subs?
05-07-2016, 03:28 AM | #6 | |
93
Rep 251
Must say that while there's not a lot of bass, it's pretty punchy with the right track. |
05-07-2016, 10:42 AM | #8 |
80
Rep 111
The serial numbers are the top labels (left and right) 51 33.......
http://www.bmwpartsshop.com/parts-sh...+51+51+3194_en |
05-10-2016, 07:42 AM | #9 | |
46
Rep 131
I called my local BMW and they said that part numbers "51337435817 & 51337435818" are just the trim pieces. You would need to buy the speakers as well Part number: 65139226357 https://www.ecstuning.com/b-genuine-...r/65139226357/ Please confirm, I would like to do the same upgrade as you! Thanks in advance! |
05-10-2016, 09:53 AM | #10 | |
80
Rep 111
I also ordered two separate tweeters and two separate grids But when the stuff came in, the tweeters were already incorporated in the grids. (Total 4 tweeters were delivered, 2 in the grids + 2 separately) The BMW dealer did so two tweeters loose on .... |
05-10-2016, 10:15 AM | #11 |
46
Rep 131
hart4bmw, thanks for the quick reply!
To my understanding, all I would need for this to work are: 51337435817 & 51337435818 Those pieces have the speakers already integrated? Correct? Thanks! |
05-10-2016, 03:39 PM | #12 |
80
Rep 111
05-13-2016, 04:40 AM | #14 |
Rep 8
05-13-2016, 05:48 AM | #15 |
282
Rep 1,491
My Australian spec 25i has the floor subs, too.
Peugeot T9 308 GTi 270 Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182. |
05-13-2016, 07:49 AM | #16 |
37
Rep 126
05-19-2016, 08:36 AM | #17 |
46
Rep 131
05-19-2016, 10:26 AM | #18 |
80
Rep 111
stuff inside?
I did not do the installation myself, I saw that they have removed 3 or 4 screws in handle and bottom panel Then you need to detach the panel from the click brackets to the underside of the door Then hang the top of the panel to the window frame, and then you raise it gently from the door. The wiring of the LED lighting is still well attached to your panel, which you do not disconnect, is not necessary. You have plenty of space, see the photos. Just try careful! Good luck! |
05-19-2016, 10:42 AM | #19 | |
46
Rep 131
Gotcha thanks for the info! Will try tonight super excited!
06-01-2016, 08:44 AM | #20 |
37
Rep 126
I did this yesterday myself to my 28i M Sport. It does make a big different in soundstage and detail. If anyone has questions on technique, let me know. I would recommend a blanket on the ground so that the door card doesn't get marred (not comfortable with what's shown in the pics here). Thanks to everyone in this thread for the help!!!!!
06-01-2016, 10:49 AM | #21 |
17
Rep 83
Very cool! Definitely miss the depth of the sound from the HK system in my old E92. My X1 is leased but may be a worthwhile investment anyway. Will have to look more into what involved with removing the door. That scares me a bit. I don't want any squeaks or rattles after.
Current: 2016 X1 xDrive28i
Past: 2011 328i Coupe Past: 2003 325i Sedan Past: 1999 328i Sedan |
06-02-2016, 07:46 PM | #22 | |
18
Rep 266
