04-29-2019, 04:23 PM | #177 |
30
Rep 83
Just tried it in mine, works like it should with the little flag coming on in the dash, the car is a 2016 20D Xdrive
Viltronian9.50 |
05-07-2019, 07:44 AM | #178 |
49
Rep 69
Hello everyone.
The F20 iDrive (ID4) was able to display the GPS trajectories. However, the F39(F48) iDrive (ID6, Professional) can not display GPS trajectories. Do you know the setting for displaying the GPS trajectories of ID6? Thank you. Last edited by Takabo; 05-08-2019 at 06:54 AM.. |
05-17-2019, 03:55 PM | #179 |
68
Rep 240
Hello everyone!
I want to share with you a small coding that I discovered. For me it is useful. The coding is for "Bord computer autoreset time interval". On my car (F48 sDrive 18d 2016), this default time interval was 4 hours and there was no option to change it. So, here it is: Instrument Cluster ->> change to Expert mode ->> 3000 Anzeige_Konfiguration ->> search for BC_AUTORESET_ZEIT ->> press CUSTOM VALUE ->> enter the time interval you wish, like this: 02 = 2 h; 08 = 8 h; or whatever you want. Then choose this new added option and CODE . The new time interval will be used from now on. |
05-26-2019, 10:54 PM | #180 |
68
Rep 240
Hello!
I own an X1 sDrive 2016, manufactured for European market. The car came with only one central locking button, on the driver door (left) and with a blanking plate in the similar position on the right door. I installed a central locking button on the right door, but it is not working. The only thing that it is working on the button is the illumination light. The car has already the necessary wiring, factory installed. Maybe it is a coding that can be made/ modified, in order to make functional both door buttons. Does anyone know? Regards! |
05-27-2019, 02:36 AM | #181 |
80
Rep 139
Fog lights with welcome lights would be nice. Does anyone knows how to do it on the X1?
Edit: P.S: If anyone wants code their rear lights and their blinkers, go here > https://f48.bimmerpost.com/forums/sh....php?t=1618231 Last edited by SDriver18i; 05-27-2019 at 12:00 PM.. |
X1604M57.00 |
05-27-2019, 12:18 PM | #182 |
94
Rep 287
[QUOTE=Neworgri;24836092]Fog lights with welcome lights would be nice. Does anyone knows how to do it on the X1?
Edit: P.S: If anyone wants code their rear lights and their blinkers, go here > https://f48.bimmerpost.com/forums/sh....php?t=1618231[/QUOTE If you have bimmercode app under FEM there is an option to select fog lights to enable with welcome lights. |
05-27-2019, 02:16 PM | #183 |
80
Rep 139
Its not there. I have BDC not FEM. I tried to modify the settings from the F30 sheet in expert mode> MAPPING_NEBELSCHW_R_PART_OF > Didn't do anything at all.
07-17-2019, 09:40 PM | #184 | |
147
Rep 304
I've checked and double-checked and all the settings seem right, but I can't get it to fold the mirrors (and nothing else!) with just a touch of the ridges. Can anyone who's done this coding confirm how theirs actually works? If I'm trying to do something that isn't possible it'd be nice to know. |
longtons220.00 |
07-20-2019, 07:30 AM | #185 | |
30
Rep 83
07-20-2019, 11:05 AM | #186 |
147
Rep 304
07-20-2019, 02:15 PM | #187 |
163
Rep 334
I'm not sure if it's the same with Bimmercode, but when I set the delay to zero in eSys, I lost the ability to lock the car and disable the interior sensors (pushing the lock button on the fob a second time within a couple of seconds of the first press). I need this for the odd occasion when we leave the dogs in the car to run to the shops or whatever. This might be worth checking if it's a feature you use, otherwise you might not know until your alarm goes off when you think the interior movement sensors are disabled, and they're not...
07-22-2019, 11:58 AM | #188 |
147
Rep 304
Thanks for pointing that out. Disabling the interior sensors isn't something I'll likely need to do, but it never hurts to be aware of unexpected side effects of coding changes!
07-23-2019, 03:25 PM | #189 |
Rep 119
Does anyone know if it's possible to get enable a gear indicator? I'm using Carly to code and there are options to enable it, but even with it enabled nothing shows.
It doesn't even seem like the cluster has a space to display the gear. Not even D, N, R. |
07-24-2019, 12:48 AM | #190 |
30
Rep 83
Mine shows the gear in the tacho section
08-04-2019, 07:56 PM | #192 | |
94
Rep 287
Not sure if it's MY, country specific, car options, ...? |
08-12-2019, 11:31 AM | #193 |
Rep 7
I think there is a gear indicator only when you use the sport position with manual operating (automatic gear lever on the left position)...
BMW X1 F48 xDrive 20i xLine 06/2018
Indian Motorcycle Chief Vintage 03/2014 |
08-12-2019, 11:43 AM | #194 |
Rep 7
Since about 3 weeks, I have 5 instead of 3 flashes on the turn indicators without doing anything new.
I don't understand why, because I did a coding change for that in september of 2018 that done no change (always 3 flashes). I'm using my car since 2018/06/30 and there was only 3 flashes for a year and one day there was 5 flashes... I don't understand why or how the change came, but I'm very happy with this !
08-12-2019, 04:24 PM | #195 | |
94
Rep 287
Bringing to dealer to diagnose. |
08-12-2019, 05:08 PM | #196 | |
137
Rep 310
No complaints here either! |
ccIndianRider3.00 |
08-12-2019, 05:46 PM | #197 |
147
Rep 304
Interesting. Just checked our 03/19 build 2019 and the choices are 1 and 3 flashes, no option for 5. I prefer 3 so I'm not complaining, but I wonder if I coded it for 5 now, the option for 5 would appear.
08-13-2019, 08:28 AM | #198 |
229
Rep 218
Drives: '20 M2 Competition & '18 X1
Has anyone successfully coded trunk closing with the key fob? I activated the option on Bimmercode but it doesn't seem to work.
