BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) How reliable has your X1 been?
      02-24-2019, 04:26 PM   #1
pmc123
26
Drives: 2021 330i
Looking to buy a used X1. I really like this vehicle.
Just wondering how reliable your X1 has been for you. (also if you could mention what year yours is...)
I don't see a lot of complaints in this forum about reliability issues.
      02-24-2019, 04:46 PM   #2
Bob in IL
794
Drives: 2024 G01 X3, 2019 G30 5 Series
We had our 2017 for nearly 2 years (20 months) and no issues all. No warranty work or service bulletins.
      02-24-2019, 10:29 PM   #3
jmhumr
49
Drives: 2017 BMW X1
I have a 2017 with 17k miles. Nearly perfect so far. Been meaning to take it in to have some mild low speed jerkiness looked at, but my understanding is that it’s a quick fix under warranty (there’s a long thread about it).
I’d recommend.
      02-25-2019, 04:40 AM   #4
simon.
923
Drives: F48 25D mSport
Oct 16 25D Msport with 35K on it now. Bar servicing & EGR replacement & a turbo hose pipe, both under warranty, it's been trouble free.
Averaged 38 mpg over the distance but I don't hang about & lot of roundabouts where I live with national speed limits between them.
      02-25-2019, 09:30 AM   #5
MJE60
MJE60's Avatar
England
681
Often the case that those with a problem complain and those that are happy just get on with life. I have 12/2017 xdrive 2.0d (so diesel not petrol). I have had no problem and am getting 41mpg (so for US gallons that is 32.8mpg).
I would say they are good cars but some of the driver assist features (not std vehicle FCW) but optional pedestrian collision and ACC active Cruise Control rather than standard CC (found in most X1’s ) can be flaky. General safety is good. My main niggles are the paint is thin and the basic HiFi (not optional HK system) speakers/system are the poorest I have had the displeasure to listen to. In the U.K. the nav mapping is about 5 years out of date for some areas. Otherwise good fun to drive.
      02-25-2019, 09:51 AM   #6
Jorix
73
Drives: BMW 120d, BMW X1 xDrive20d
Originally Posted by MJE60 View Post
the basic HiFi (not optional HK system) speakers/system are the poorest I have had the displassure to listen to.
By basic HiFi, do you mean most basic, or the mid-level "Loudspeaker system - BMW Advanced" speakers? Because there are two optional sound systems over the basic one.
      02-25-2019, 10:20 AM   #7
dianebrat
110
Drives: 2019 orange x2 xDrive28i
remember this is a global forum, different countries have different options, i.e. in the us the options are only "Hi-Fi" and the h/k, I odn't know about the UK options.
      02-25-2019, 11:49 AM   #8
jsdh89j9ijkL
65
Drives: motorcycle
25d / 67K miles
warranty repairs:
EGR replaced, which I believe is the re-designed part.
LED tailgate inner lights x3
      02-25-2019, 11:57 AM   #9
MJE60
MJE60's Avatar
England
681
Hello
In U.K. ,
there is basic,
there is bmw advanced which may have a separate amp with extra speaker (mid dash) but are same poor quality paper cone speakers which sound flat and poor.
and there is HK. Which is good.
I improved my car by fitting HK tweeters in the front and swapping front mid range for HK also. Will probably change two base speakers next.
      02-25-2019, 12:06 PM   #10
YellowCone
24
Drives: 2016 BMW 340i MSport
My April 2018 XDrive20i has been 100% reliable from day 1.
Not one error message, fault, interior rattle or warranty item to speak of! My previous 3 Series had been back to BMW three times in its first year.
      02-25-2019, 01:22 PM   #11
Beemerbuster
15
Drives: X1 2.5D
My 2016 2.5D MSport has had the iDrive head unit replaced due to complete failure. Drivers seat sub base (metallic bits) replaced to cure slide side movements. Engine/ transmission rear mounting replaced to cure clunk noise. This didn't cure problem so front wishbones replaced which has now cured the intermittent noise.
After the front wishbones had been replaced there was a very slight mis alignment of the steering wheel.
Return visit to dealership for a full alignment check has cured this and also found the rear wheel alignment, camber, castor angles etc to be outside limits. This has all been corrected.
Thankfully all work covered under warranty. On dealers invitation my car is going back next week for a full end of manufacturers warranty check. Having its first MOT same day so if any issues warranty should cover?
On paper not the most reliable car but I am a fussy sod and possibly many owners would have lived with issues such as slight clunk noise and seat movement but for me it's like the annoying rattle or creak in the trim.
      02-25-2019, 01:39 PM   #12
Toddy2018
Drives: X1 f48 25d msport
What were the symptoms of the turbo hose needing to be replaced
I also Have the 25d and it's had 2 new eggs and software update
I mentioned to the dealer when it went in for the second egr that I
Could hear a ticking noise when I accelerate hard, have you experienced
Anything similar
Dealer said there was no other issues other than egr
Thanks
      02-25-2019, 06:41 PM   #13
ttimbo
ttimbo's Avatar
282
Drives: F48 X1 25i AW; F20 M135i AW
Overall reliable, with a couple of caveats:
The first, a broken engine mount (fixed under warranty — no significant off-road or rough road driving). Others have had this, too
The second, a recall for tie rods, IIRC
Good car and I certainly buy again for our use case
Peugeot T9 308 GTi 270
Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182.
      02-26-2019, 03:47 AM   #14
Jorix
73
So I paid 350 euros for an option, and I still get bad sound? Damn.
      02-26-2019, 08:01 AM   #15
simon.
923
Anything similar
Thanks
Tbh, I didn't notice anything untoward, it was picked up when in for new pads & discs. (Front Pads 17K, both 36K, told you roundabouts not good lol).
Was just a small split by all accounts so not failed.
      02-26-2019, 11:18 AM   #16
Mushy007
56
Drives: X3 2D MH M Sport 2021
42k rear engine mount, didnt notice it and spotted on a service. EGR valve as it failed. Apart from that great car and doing 55mpg
      02-26-2019, 08:57 PM   #17
knightarmor
858
Drives: 2017 M3
We have a 2018 XDrive MSport with 11K miles. So far so good. Been on a few long trips already. No complaints. Might end up upgrading to something else though as it gets tight with three adults and one infant.
Here are some of the things I find are big plus's-
Great in snow (with winter tires)
Decent ground clearance (although an S60 Cross Country has better ground clearance by over an inch)
Nice comfortable interior and roomy for the size of the vehicle
Great LED headlamps
Great visibility
Looks good (subjective I know)
      03-04-2019, 08:59 AM   #18
MJE60
MJE60's Avatar
England
681
Sorry. If you are happy with sound then that is all that matters. I am sure most X1 owners are happy with the system and equally most audiophiles will probably be critical.
      03-04-2019, 02:24 PM   #19
gnx
Όλα ρόδες
gnx's Avatar
760
Drives: BMW
Same car 56K kms, that turbo pipe just happened to me as well.
Engine oil dripping onto the steering rack, lots of it.
      03-04-2019, 07:34 PM   #20
Dotchick
10
Drives: 2016 bmw x1
I still love my X1... I just hate the run flats.. I will be ditching them soon, but keeping my car. It has been great... Aside from the runflats, I have no complaints
      03-05-2019, 02:56 AM   #21
RobinLegin
37
Drives: BMW X1 Xline 2i petrol
So far after 18,400 miles no mechanical or electrical issues on my 2 litre petrol X1 x drive.
Beagler74.50
      03-05-2019, 04:13 AM   #22
Hashrizvi
Drives: 2018 BMW X1sDrive18i
2018 sdrive 18i with 11000 km. No issues here. Loving the car.
