12-11-2019, 02:14 PM | #1 |
Rep 23
Stock Tail Lights to LCI
Question I have is has anyone swaped out the stock tail lights housing for the LCI / LED tail lights and if so did you run into any troubles. Much thanks for any information on this.
12-12-2019, 03:58 AM | #3 |
117
Rep 212
Pre lci are not full led!
Brake, flash and reverse are bulb! You can easily swap them with leds though plus some coding to avoid flickering and errors, but lci are full led... LCI: Pre LCI non led pack with aftermarket leds: Pre LCI led pack with aftermarket leds: |
12-12-2019, 05:59 AM | #4 |
Rep 23
Yes I was talking about pre lci. I have a 2018 X1 without led headlights and would like to switch the tails lights out to the ones that come with the led head lights. Thank you for the responses.
12-20-2019, 11:37 AM | #6 |
19
Rep 130
Mine has LED headlights, so the taillights of mine are LED. The brake, reverse, indicator lights are not LED though. It's an easy swap with LED bulbs, and afterward there's not much visual difference between this and the new LCI. I actually prefer the position of the pre-LCI reverse light, and the taillights look better on the pre-LCI.
07-03-2020, 10:16 AM | #7 |
69
Rep 250
Current: 2018 X1 F48 & 2014 F20 116i. Before: 2009 BMW E90 320d LCI, 2008 E92 M3 &
07-03-2020, 10:47 AM | #8 | |
73
Rep 155
07-03-2020, 01:46 PM | #9 | |
1487
Rep 1,404
07-19-2020, 07:59 PM | #12 |
73
Rep 155
07-19-2020, 09:02 PM | #13 |
73
Rep 155
This will apply to pre-LCI LED tail lights. I have no experience with the LCI version, which seems to have a different bulb configuration. Someone else will have to chime in on that application.
Part #s for LED outer and inner taillights: 63-21-7-488-547 - Left Outer 63-21-7-488-548 - Right Outer 63-21-7-350-697 - Left Inner 63-21-7-350-698 - Right Inner While you're at it, might as well pick up LED bulbs for the brake lights, turn signals and reverse lights: 1156 Brake lights and turn signals: https://www.amazon.com/gp/product/B07H6VLWX2 1156 Reverse light: https://www.amazon.com/gp/product/B07H6WSL4R Remove the outer brake light housing and detach the factory plug. There's a purple retainer clip that you will need to slide out using a small screwdriver. This will allow you to depin the wires. To depin a wire, using a small screwdriver, gently press down onto the catch of the wire you want to remove. This doesn't require much pressure. Once released, you can pull the wire out. Now using your small screwdriver, gently reposition the catch to it's locking position. This will now be ready to repin. There are small rubber grommets inside of the unused wire slots. You will need to remove this. I used a small pin to slide it upwards out of the plug. Try to keep it intact, and reuse to plug the new slot that will be left open after your repin. This is the configuration of your final setup. Light Blue Purple Open Brown Open Yellow/Black Be sure to replace the purple retaining clip when you're done. There is no repinning needed on the inner tail lights. Simply remove the old light, grab the new one, swap the halogen bulbs for LED, bolt it on and you're good to go. Next, go into BimmerCode. There are two sections you will need to make adjustments, all in Simple Mode. Everything is located under BDC. The first section is for the rear daytime running lights. You need to change all of these to active. Next will be under bulb types and bulb monitoring. If you're changing everything to LED, just scroll through the list and adjust everything that pertains to the rear lights to LED, and turn off all monitoring. Check you out. |
07-20-2020, 01:51 AM | #14 |
Rep 51
07-20-2020, 05:18 AM | #15 |
Rep 28
LED rear turn signal bulb swap
I tried swapping to LED yellow or clear turn signal bulbs (I have the Euro market rear lights with yellow turn signal). I discovered that the LEDs were too bright in the dark, and could distract/annoy the driver behind the car. Has anyone had this problem, and found LED that are not super bright? Thanks.
07-20-2020, 06:48 AM | #16 | |
73
Rep 155
07-20-2020, 06:57 AM | #17 | |
73
Rep 155
Something like this: https://www.amazon.com/SYLVANIA-Ambe.../dp/B01A77QQTE |
07-20-2020, 09:31 AM | #18 |
Rep 28
Good suggestion
Thanks for the link to the LEDs that don't have top mounted chips. I will try that type of bulb. The mechanics that did the bulb swap for me noticed the problem of the lights being too bright. I agreed.
07-20-2020, 09:52 AM | #19 | |
73
Rep 155
https://www.amazon.com/Alla-Lighting.../dp/B07HL6BLTQ https://www.amazon.com/SYLVANIA-1156.../dp/B01CO1FE4E https://www.amazon.com/MAXGTRS-Extre.../dp/B07NYPLF98 https://www.amazon.com/AUXITO-Bright.../dp/B07H76TD2P |
07-20-2020, 10:39 AM | #20 | ||
Rep 51
07-20-2020, 12:01 PM | #21 | |
18
Rep 59
07-20-2020, 03:34 PM | #22 | |
73
Rep 155
