BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) ACC Retrofit questions
      02-11-2019, 09:22 AM   #1
PurePulse64
52
Drives: 2017 BMW X1
Has anybody done a retrofit and added the ACC to their X1?
From what I was reading you need the camera and the switch on the steering wheel (and VO code)
I have the camera system already installed (collision, pedestrian, and Lane change). Before I spend the money getting those controls I wanted to see if anybody else has successfully done it.
      02-11-2019, 01:22 PM   #2
bimmerdriver2
bimmerdriver2's Avatar
180
Drives: 2020 M2C DCT
If you look in realoem.com, you will be able to find the parts that are included with the ACC option. I recall there are quite a few parts. I think it might be difficult or at least expensive to refit this option.
      02-11-2019, 04:59 PM   #3
xlr8it
xlr8it's Avatar
Australia
30
Drives: F48 X1 20d, SLK55AMG
I would not waste my money on the retrofit, my car has the ACC from factory and i switch it over to normal cruise 90% of the time, the camera based system doesn't like rain, sun, boats, bikes, trucks, trailers, fog , dirt or anything else that will interfere with a clear view if the car in front. It gets confused and disengages , becomes very annoying . I used to have an Audi Q7 that was 10 years old and had a radar guided system and worked 100% of the time, BMW system really sucks.
      02-12-2019, 09:28 AM   #4
PurePulse64
52
Drives: 2017 BMW X1
I wasn't sure if it was just replacing the steering wheels and code the car would suffice. Or if it more parts were involved
      02-13-2019, 07:43 PM   #5
PurePulse64
52
Drives: 2017 BMW X1
Update: I added 5FD to my VO and coded Kafas2, no errors and car showed references to ACC in the iDrive. I can't VO code the kombi module because it fails, mentioning multiple values.
I went and enabled a few ibrake options (in kombi) and got a frontal collision warning message in the idrive but my frontal collision warning is still active. I'm thinking it might throw that because I don't have the ACC switch installed, yet.
      02-21-2019, 02:30 PM   #6
MJE60
MJE60's Avatar
England
681
Hi
I thought VO changes would be to change 5ASA TO 5ATA and remove S544A.
On F48 I thought 5DFA is a subset of 5ATA , namely 5ATA is 5ASA+5DFA
      02-21-2019, 02:35 PM   #7
PurePulse64
52
Drives: 2017 BMW X1
Hi
Let me pull a full list of VO codes on my f48. I'll try and do it tonight
      02-22-2019, 08:13 PM   #8
PurePulse64
52
Drives: 2017 BMW X1
On my VO Codes I have:
1AG, 1CA, 205, 248, 249, 255, 258, 28A, 2VB, 2VG, 302, 313, 316, 319, 322, 3AG, 3AT, 3L8, 402, 420, 423, 430, 431, 459, 473, 488, 493, 494, 4F7, 4NE, 508, 534, 544, 563, 575, 5A4, 5AS, 5DP, 610, 645, 650, 655, 676, 697, 6AC, 6AE, 6AK, 6AM, 6AP, 6NS, 6UP, 775, 7HW, 823, 842, 845, 850, 853, 8KL, 8R9, 8S4, 8SL, 8SM, 8TN, 925, 927, 992, 9AA, 9C8
I added 5DF and left all others.
      02-23-2019, 11:11 PM   #9
PurePulse64
52
Drives: 2017 BMW X1
To provide an update to anybody following along... I received the steering wheel controls and finally was able to get them installed (Thanks for the help MJE60 )
I VO coded with 5DF but kept getting an error saying the Frontal collision warning and pedestrian warning was disabled. I tried to remove 544 and re-code, no luck. Tried to change 5AS to 5AT and recode with 5DF.. Still no luck
Tomorrow I'm going to try adding 541, maybe with 5DF and see if that helps any.
If anybody has any ideas please let me know
      02-24-2019, 02:56 AM   #10
MJE60
MJE60's Avatar
England
681
Looking at the VO codes in your FA adding 5DF (ACC) should not have touched underlying fdl within driver assist functions. FCW & Pedestrian warning imply driver assist fdl issues. In short I agree with your PM to me, namely update your psdzdata
Whilst I think this is not cause of the errors, if you add 5DF (ACC) then 544 (CC with brake function) should probably be removed to prevent duplicate coding. However this is my assumption, I have not checked.
Once psdzdata update done, imho
VO code changes to your original FA are just - > remove 5AS and 544 and add 5AT + 5DF
Good luck
      02-24-2019, 01:14 PM   #11
PurePulse64
52
Drives: 2017 BMW X1
So it's looking like ESys just doesn't have some mapping correct. I've been going thru the files and doing some comparison. So far I've gotten it so it'll say the fcw and ped is restricted not inactive. It says it won't auto brake. I'm thinking once I get that cleared up it should let me activate ACC.
      03-01-2019, 10:36 PM   #12
PurePulse64
52
Drives: 2017 BMW X1
For anybody possibly following along -- giving an update.
Even though my car has 5AS and 5DP (Pedestrian detection, FCW, LDW, Parking Assist) apparently there is another ECU that is used with ACC+ -- The ECU is SAS, it's installed next to the PMA ECU in the rear of the car.
If you don't have ACC+ then everything is handled by KAFAS and DSC2, if you have ACC+ (5AT) then it utilizes SAS and Kafas to calculate everything.
I'm going to check the wiring in the car tomorrow and see if its prewired or if a wire would need to be ran from the BDC_BODY/Kafas unit. If it's prewired I found the ECU for $250, if it has to be wired I'm not entirely sure how to handle it.
      03-11-2019, 09:36 PM   #13
PurePulse64
52
Drives: 2017 BMW X1
Final update
I ended up pulling the back lining out and checking for the SAS ECU, unfortunately it's not there nor is there wiring for it. I have no clue oh how to wire that so I'm pretty much DOA.
Taking apart the rear I did find some other wiring not hooked to anything that makes me wonder what it's for. Anybody know?
      03-11-2019, 09:37 PM   #14
PurePulse64
52
Drives: 2017 BMW X1
MJE60681.00
      03-12-2019, 05:12 PM   #15
MJE60
MJE60's Avatar
England
681
Great work, keep going. I think getting SAS module with lead and connector would solve the problem (one of those plugs is looking for a home). So,
Possibly factory tow bar electrics?, or
I suspect rear EDC would hook up into loom somewhere in that area (and then into SAS also). Park assist module in rear roof could possibly route through right hand trunk recess also. Looking at ISTA I think there is aux comms signal booster located in rear also (all these are options so would explain some empty plugs/connectors.
      03-12-2019, 08:43 PM   #16
PurePulse64
52
Drives: 2017 BMW X1
True, It would be weird there is a connector for tow bar electronics but nothing for the SAS module. I may reach out to some of the retrofit companies and see if maybe they have any experience installing a SAS module and wiring.
      03-14-2019, 01:08 PM   #17
Jonnad
Drives: 2018 f48
Just purchased a 2018 x1 with the drivers assistance package. I'm also looking into retrofitting. Any news? I was really hoping this would just be a code change since the optical system is already in there.
      03-14-2019, 01:27 PM   #18
MJE60
MJE60's Avatar
England
681
I assume you were hoping to retrofit ACC (active cruise control).
The short answer is that you would as a minimum require new steering wheel switches and if you do not have EDC (electronic damper control) you would also require a SAS control unit (and cabling to fit it). It appears BMW have routed ACC to work through a different (and rare) control unit to other functions served by the KAFAS camera. One can only suspect it was in order to make sure it was not just a simple code change. PulsePulse64 is investigating whether there is a socket lurking somewhere in the wiring loom into which a SAS module could be plugged. We await his findings, he is to be commended for his efforts.
      03-15-2019, 07:30 PM   #19
PurePulse64
52
Drives: 2017 BMW X1
If you have the SAS ECU, KAFAS camera you'd be set to go with the switch and coding. Unfortunately I'm at a standstill until I can find a way to get the SAS ECU added. The i3 SAS ECU would work and can be found for about $250. The issue is getting it wired in.
You can tell if you have SAS by hooking up e-sys and checking your ECU list or by removing your rear trim (on the right) and you'd see it bolted right under the rear window.
      03-15-2019, 07:33 PM   #20
PurePulse64
52
Drives: 2017 BMW X1
Yeah If you have the damper control chances you'd have the SAS ECU.
Unfortunately I don't have much extra to share I've looked to see if I could find wiring out of an F48 that had it but that's been next to impossible. I may end up looking to see if I could get the wiring from an i3 since it's similar.
      03-17-2019, 04:26 AM   #21
satz
Australia
338
Drives: 2019 BMW X3 M40i
Is 'normal' cruise control still fitted when ACC is optioned?
Hi,
I just ordered an X2 with ACC but haven't received it yet. Do you know if you can still use the normal cruise control with braking, instead of the camera-based ACC?
cheers
2019 X3 M40i, Sophisto grey, H/K, pano
Previous: 2019 BMW X2 Msport, Mineral Grey, Adaptive Suspension, H/K
Previous: 2009 335i LCI, Bluewater
      03-17-2019, 12:00 PM   #22
MJE60
MJE60's Avatar
England
681
Originally Posted by satz View Post
Hi,
cheers
Yes
