05-08-2024, 09:29 PM | #1 |
Rep 1
Help with tyre pressure and idrive
So I replaced my head unit with an android unit from AliExpress my tire was low and I’m not able to reset the light because my idrive is no longer working. I tried to reset using the infotainment system but it says tyre pressure init like it is initializing but it is not. Please help
05-10-2024, 09:13 AM | #2 |
204
Rep 818
what do you mean your idrive is not working? that is where you need to reset the tire pressure through idrive.
go back to the seller and tell them your problem as you should be able to use idrive (oem) you can also look or post your question in the thread below. https://f30.bimmerpost.com/forums/sh....php?t=1832178 |
