BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Does anyone have 295 width tires on their xdrive? Noob seeking guidance.
      01-13-2024, 01:02 PM   #1
Leaftors
Drives: BMW x1 2017
Hi everyone,
Complete noob to the car world and have been doing a little reading on mods.
I recently acquired a 120k mile 2017 F48 m sport that came with 18'' oem m wheels and 225/50/18 (recently switched to extreme contacts from the P7's but I have a free exchange until Feb 8 incase I want to go with R19 or wider tires).
It's all stock but the front struts had to be replaced, and they were replaced with cheap $100 struts by my brother before I acquired it. It's such a bad ride, but I will be thinking of upgrading all 4 to Bilsteins in the future.
My main goal right now is to fill the gap between the tire and the fender and to have an aggressive looking rear tire because the 2017 F48 is lacking from the back point of view. To achieve this I am thinking of getting lowering springs as well as 19'' wheels and wider tires.
I am planning on getting H&R lowering springs.
https://www.ecstuning.com/b-h-and-r-...et/28790-3~hr/
I really like the look of how wide my brother's 295/40/20 are on his rears of his 2018 Macan turbo. I understand they're two different cars and the reason I want 295 on the rears is because it looks so good from the back on the Macan. I'm thinking that if I get 295 as well that it'll look similar - correct me if I am wrong.
However, I read that because the f48 xdrive is 4WD it is a bad idea to stagger because it stresses a major component of the car. I'm also wondering if 295 all around is a bad idea and if 295 will even fit without causing issues? If staggering is ok then I could also stagger but I am having a difficult time trying to research what front tire size would be compatible.
Another issue I find is that the stock wheels seem to be sunken into the fender. I would prefer if the wheel lined up with the fender. Do I need spacers for this? Does getting a new 19'' wheel effect how much the wheel lines up with the fender compared to the stock 18''? Is this called the offset?
I would appreciate any guidance and clarification on this matter!
      01-13-2024, 04:20 PM   #2
MJE60
MJE60's Avatar
England
678
Originally Posted by Leaftors View Post
Hi everyone,
Attachment 3364230
Attachment 3364231
Attachment 3364232
You may find the tool within this link helpful as it allows you to visualise changes to tyre size and profiles. https://www.willtheyfit.com/wheels/ factory stock size for F48 xdrive was 225/45 for 19” on 8j x 19 et47 rims
You might also try searching this forum as there are a number of threads about Tyre/tire and suspension set-ups people have fitted on their X1’s. As an example here is just one thread https://f48.bimmerpost.com/forums/sh...ht=Tire+set+up
      01-16-2024, 10:40 AM   #3
jrveron
jrveron's Avatar
Argentina
266
Drives: 2023 X3 m40i
I don't think it's possible to fit a 295 tire on the F48. It doesn't need to or even have the power to move them.
If you're looking for a flush look, I put 255/40r19 tires on custom wheels with lowering springs—great stand and driveability.
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD
      03-17-2024, 11:39 AM   #4
JGun
JGun's Avatar
Drives: 2021 X1 xdrive
2021 BMW X1  [0.00]
You could potentially install spacers to bump your current tire out and get a similar look. Haven't personally installed these but on the list of things I'm considering.
Something like this:
Wheel Accessories Parts 4 Pcs Hub Centric Billet Wheel Spacers 12mm Thickness 5 on 112mm Bolt Pattern (PCD) 66.56mm Vehicle & Wheel Hub Fits Mercedes & BMW https://a.co/d/crxP6lN
