BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Panoramic Sunroof Shade Blind
      02-11-2019, 04:59 AM   #1
BMW-X1MAN
14
Drives: X1 Sdrive 18d SE
Hi,
I have a problem with my panoramic sunroof shade blind it came loose on one side after leaving the sunroof opened (one click slide) during a cold frosty night (no rain though).
Has anyone got an idea how to fix the blind back into the track?
      02-24-2019, 08:19 PM   #2
thebillionheir
Drives: 2021 G05 M50i
I have this same issue. Bumping for hopeful answers.
      03-14-2019, 07:54 AM   #3
how0425
Drives: 2016 X1 F48
I had the same issue with the passenger side sagging and the whole headliner was taken apart and took the dealer almost five days to get the parts ordered and (the whole assembly had to be) replaced under warranty...felt like a big job.
      05-30-2020, 06:13 PM   #4
Sapstar1
Drives: X1
Hi - me too. Did you or anyone else manage to get this fixed ?
It’s as though there isn’t enough tension in the blind to pull it taut enough.
      06-24-2020, 03:05 PM   #5
eddiegarciap
Drives: 2016 X1 xDrive28i
Same issue here, happened out of nowhere. Dealer wants to charge $2,500 for the repair, as it’s not covered by CPO warranty. I think it’s ridiculous. Opened a case with BMW customer relations to see if they can get it covered.
      06-25-2020, 08:00 AM   #6
iceman7
iceman7's Avatar
Greece
117
Drives: X1 LCI sDrive 18i
Seems to be a common problem.
People are leaving the shade open all the time!
My BMWs
02/2017 - 10/2019: X1 F48 18i sDrive X-Line Platinum Silver with Android 10,25 Aftermarket Screen
11/2019 - Present: X1 F48 LCI 18i sDrive Connected Advanced Mineral White
      06-25-2020, 09:12 AM   #7
spatel88
Drives: 2016 BMW X1
I dont have this problem but i want to be precautious so is it better to have the shade pulled out or retracted in. We normally keep it pulled out at all times to keep the sun out.
      06-25-2020, 09:24 AM   #8
jmhumr
49
Drives: 2017 BMW X1
+1
How is this happening? Are people tilting the window open with the shade closed or something?
      06-25-2020, 09:59 AM   #9
Shagohod
18
Drives: F48 X1
Also curious how often people who have this issue use the shade. I leave mine closed at work and in my driveway, and open it almost every time I drive. So far no problems on my 2016 and it's been through blizzards and heat waves alike.
      06-25-2020, 05:02 PM   #10
Zookol
Drives: 2018 BMW X1 S drive
I usually leave mine open. Having been closing from time to time when temp over 85. No problems with mine.
      07-01-2020, 02:49 PM   #11
eddiegarciap
I reported my issue to the NHTSA. Recommend others do the same to force a recall on this: https://www-odi.nhtsa.dot.gov/VehicleComplaint/
x1noob3.00
      07-09-2020, 05:43 PM   #12
2013fusionva
Drives: BMW X1
Failures caused by related electronic parts are covered
The "Shade Blind" itself is not covered, but the electronic / electrical components are... So if you can point to a failure among those components having caused the overall issue you may have the repair covered.
The "shade blind" is listed as one part, #54-10-7-391-798, but is actually a system of sub-parts that include a motor and relay, the shade itself, small plastic pieces that provide structure, and two metal strips that line either side of the blind that coil in and out and provide tension (prevent sagging).
The issue is that these metal strips are attached to the blind only via two very thin lines of adhesive (i.e. destined to fail with normal use). Arguably, opening/closing the shade blind in extreme temperatures (i.e. direct summer heat, unmitigated winter cold) could make failure of this adhesive more likely.
Any malfunction of the motor or blockage of the "track", or any issue causing uneven retraction, could also cause the adhesive to fail in part or completely (i.e. partial sagging or complete elimination of the shade function). Any failure of the related electrical components could also cause these issues and, in this case, the repairs should be covered.
It is also possible that the motor fails to extract/retract fully, causing a lack of front-to-back tension.
Unfortunately, the entire sunroof system has to be removed to replace the shade blind (or any of the constituent pieces that make up part # 54-10-7-391-798). Lots of labor hours and alternatively, an extremely tedious and ill-advised DIY job.
Reporting to NHTSA is certainly a good idea, as an untimely failure of the shade blind can leave it sagging/hanging and blocking the view of the driver while operating the vehicle.
      07-13-2020, 03:11 PM   #13
billnchristy
1604
Drives: 2022 M440xi GC
Mine failed in this way and it was probably opened 12 times in 3 years. Don't miss it at all in my x2.
      02-07-2021, 12:21 PM   #14
ikhan
Drives: 2018 BMW X3 M40i
found a affordable part.
we just had ours fail. heard a crackling noise turned around and it was all bundled up. this really sucks. We basically cut the shade blind out.
in a lot of ways, it's pointless to have the shade blind I found it didn't keep the cold or heat out.
I am in Vancouver, bc Canada. I found a part on ali express which is much much cheaper than BMW. I bet it's manufactured there like most things are and slapped on with extra $$ and a BMW logo.
https://www.aliexpress.com/item/4001...%2315609%23260
does anyone know how to install this? i am willing to pay
      08-11-2021, 12:55 AM   #15
dewonguy
Drives: 2016 X1 xdrive28i
were you ever able to resolve yours?
      08-11-2021, 05:58 AM   #16
dbtraveler x1
Drives: 2016 bmw x1 x drive
I have 2016 x1 cpo and the exact same thing happened , I have 95,000 on my x1
the sagging and pulling away from sides.
I am wondering if I should try to power the sunshield all the way back and leave it recoiled with no screen .Has anyone tried it
      09-11-2021, 03:36 PM   #17
mpmav1
Drives: BMW X1 2016
Angry YES!
Exact same thing happened to me. One side is ripped. Would love to see something done about this!
      09-11-2021, 05:55 PM   #18
ikhan
We just pulled the crappy cloth on the shade blind and left it as is.
I really didn't make a difference in the summer or winter. The costs
To replace it is not worth the little to no protection is provided.
If you are concerned consider tinting the window is a cheaper alternative
Reefy38.00
      11-18-2021, 06:51 AM   #19
ChetArora
Drives: BMW X1
Hi
I got a similar issue. Please share if you found a solution to this.
Thank You
      02-07-2022, 10:58 AM   #20
initialM
initialM's Avatar
28
Drives: F10 535i M-sport
I have a similar issue. My left side of the screen came off and a bit dangly in the middle now
      02-09-2022, 12:21 PM   #21
spatel88
Drives: 2016 BMW X1
this one scares me. Has anyone that had an issue gotten it fixed and if so how much did cost.
      02-22-2022, 08:31 PM   #22
Le510roy
Drives: BMW X1
I have a 2016 X1 with 70000 miles mine came off track after 66000 miles. Dealer said it wasn't covered.
