BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) BMW X1 2017 - jerking on slow acceleratio / low rpm's
      09-18-2021, 07:35 AM   #45
Monkeyjoe
Drives: BMW X1
BMW X1 2018 drivetrain problem
Hi all,
First time posting here
I have just bought my first BMW, an X1 automatic with 36000mls on the clock about 3 months ago, I’ve done around 4000mls on it, love it, but now also have the jerky gear change problem (sometimes a big jerk) which started last week, going from 2nd to 3rd it seems, went away next day, and started yesterday and now won’t go away… I’ve tried the hold down the gas pedal for 5 secs thing mentioned here, but the orange engine management light still coming on… also about an hour ago, it struggled to get into reverse.
Typical it would happen at the weekend when the garages are closed
I’m due to go a trip on Monday for 3 days but thinking of cancelling it now till I get it seen to.
Any help, ideas, thoughts etc very much appreciated…
Cheers,
      09-20-2021, 11:48 AM   #46
jrveron
jrveron's Avatar
Argentina
272
Drives: 2023 X3 m40i
Hi there,
As you read, I have the same issue. So yours is also a petrol engine?
I did a full system update, but the problem persists. So I'm asking BMW to make a full diagnosis of several parts, such as the spark plugs, the acceleration body, the CCV/PCV (Crankcase-Ventilation), the fuel pump, the air sensor, the transmission and its mounting, etc.
As you know, it could be many things, and I have no guidelines here. So that's why I'm trying to list all parts that could be related to my problem. But it can't be a coincidence; it sounds like a common problem. We just need to narrow the search.
Originally Posted by Monkeyjoe View Post
Hi all,
Cheers,
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD
      09-23-2021, 05:07 PM   #47
Monkeyjoe
Drives: BMW X1
Originally Posted by jrveron View Post
Hi there,
Hi, no it’s a diesel engine
      09-23-2021, 08:41 PM   #48
jrveron
jrveron's Avatar
Argentina
272
Hi, no it's a diesel engine
Oh, I see. So you may have an EGR issue. You should read the thread again because they talked a lot about diesel engines.
This only applies to petrol engines and, as Peter_R mentioned, is more like a placebo effect than a real solution.
      04-23-2023, 05:44 PM   #49
leeF48
leeF48's Avatar
Drives: BMW x1
2017 bmw x1  [0.00]
Originally Posted by SirMoxie View Post
I had a similar problem with my 2017 28i and it turned out that the oxygen sensor needed replacing. Once that was done it was back to normal.
Hi, my car is needing a new sensor but I’m pretty new to BMW, do you know where the 02 sensor is located?
Thanks 👍
      07-13-2023, 02:26 PM   #50
bytecho
Drives: F48 X1 xDrive20i
so the EGR issue is only for Diesel engines?
I recently got drivetrain error and jerking at low speed from 1st to 2nd and reverse gear. no error codes F48 X1 xDrive20i. could this be an EGR issue?
      07-13-2023, 03:34 PM   #51
jrveron
jrveron's Avatar
Argentina
272
Thanks 👍
Basically, you have 2 lambda sensors: before and after the catalytic converter. See attached picture for more info, or go to https://www.realoem.com/bmw/enUS/sho...14#11788604889
To change them, you need to disassemble the clean air intake (from the air filter to the turbo), and then use a special BMW tool to remove and install it, at least according to ISTA manuals. See attached pdfs for more info.
      07-13-2023, 03:45 PM   #52
jrveron
jrveron's Avatar
Argentina
272
As far as I know, the EGR is only on F48 diesel engines.
      07-13-2023, 04:20 PM   #53
bytecho
Have you got the issue of your car sorted?
Regards,
      07-14-2023, 11:12 AM   #54
jrveron
jrveron's Avatar
Argentina
272
Regards,
Unfortunately, no. I had a similar discussion here: https://f48.bimmerpost.com/forums/sh....php?t=2031617
Another user's X1, was diagnosed with excessive (negative) pressure on the crankcase.
What's next to me is replacing the O2 sensors; then vacuum leak test; then crankcase pressure test.
      07-26-2023, 07:43 AM   #55
Gaijinphil X1
Drives: BMW X1
Thespido,
I shall be interested to hear how this goes for you. Presumably your dealer will run diagnostics on the transmission. My 2016 F48 1.8D M Sport with 60k miles was diagnosed as failed gearbox and is currently in for overhaul - not by BMW I hasten to add.
