03-07-2024, 03:09 PM | #89 |
191
Rep 631
Well there are 9 groups and every group consists of 8 bytes. 8 bytes can hold 64 zeroes and ones.
1 being show the error on the cluster, 0 suppres the error. Group 9 thus holds value 513 till 576. (Group 1: 1- 64, group 2: 65-128, group 3: 129-192, group 4: 193 - 256, group 5 257 - 320, group 6: 321-384, group 7: 385 - 448, group 8: 449 - 512, group 9: 513 - 576, group 10: 577 - 640) The ohne_533 turns off the 533 error. The calculation can be used to verify this. If you would choose the “aus” you would disable all CC-ID errors from 513 to 576, potentially supressing more errors than you would like to. Example FF in binary representation is 1 1 1 1 1 1 1 1 1 DF is 1 1 0 1 1 1 1 1 And you can guess 00 That is 0 0 0 0 0 0 0 0 0 If you would like to turn off error 513 The start of the series would need to look like 0 1 1 1 1 1 1 1 . … If you want to turn off 514, it should look like 1 0 1 1 1 1 1 1 … If you want to turn off both it would look like 0 0 1 1 1 1 1 1 … Using this site you can convert hex to binary and vice versa: https://www.rapidtables.com/convert/...ry-to-hex.html Meaning if you would like to disable 513 and 514 you need to fill in [3F, FF, FF, FF, FF, FF, FF, FF] Last edited by mrpingu; 03-07-2024 at 05:57 PM.. |
03-07-2024, 11:59 PM | #90 |
Rep 64
Maybe I can try choose the “aus” and see how it goes ?
Other than that I still can’t figure out how to pinpoint the error for “secure vehicle against rolling” code and turn it off. Or maybe I could try this [FF, FF, FF, FF, FF, 00, FF, FF] From the list on the website seems like there is not much error affecting the car other than gearbox malfunction. Time to test it out. Update : tried and error still pop out After coding to “aus” the error still pops out. Guess we can rule out the error didn’t come from group 9. Should I continue testing the rest? CC-ID 393 CC-ID 394 CC-ID 442 CC-ID 443 CC-ID 557 |
03-08-2024, 04:16 AM | #91 | ||
191
Rep 631
Here is a list of CC-ID: http://mr-fix.info/bmw-cc-id-codes-fault-warning-messages/ If you have ISTA you can find out CC-ID aswell. See also post below Quote:
03-09-2024, 01:15 AM | #92 |
Rep 3
repair service in Sydney, Australia
Check out - www.bmsense.com.au who offer a repair service for the secure vehicle against rolling transmission error
03-09-2024, 04:29 AM | #93 | |
191
Rep 631
The best solution is still to Replace the spring |
03-15-2024, 03:59 AM | #94 |
Rep 11
The fact is that coding does not remove the fault. And unfortunately, when you come to sell the vehicle most buyers and dealers now plug in diagnostic tools and will see the fault. Get the spring changed, it just makes a lot more sense -- and it is safer!
I offer coding and programming on BMW and MINI for certain things, but anything safety related and I just won't do it. So for this fault, I will only replace the spring. If you're in UK and need this repair then www.securevehicleagainstrolling.com |
03-15-2024, 04:33 AM | #95 | |
191
Rep 631
Yes it only surpresses the issue in cluster and iDrive, perfect as temporary solution while waiting to spring to come and waiting to install. I said the word temporary several times |
03-15-2024, 04:18 PM | #96 |
165
Rep 1,059
I have fixed tons of X1s and 2 series in London. Running with the broken spring is not a safety issue. You will not fail an MOT either.
I had people asking me about this and I honestly answered them rather then milking them. Car simply does not understand it is in park, thats all it is. On top of the annoyance at every start or switch off engine. Also it does not decrease the car value dramatically. Surely not thousands if the repair itself costs 1200 at the dealership. |
03-17-2024, 07:30 AM | #97 |
Rep 64
Really appreciate the shared YouTube video I just follow what he did and get the job done on my Sunday relaxing morning !
Although I’d like to explore on the cc id disable codes but I just fell asleep reading the codes and descriptions. But again it would be nice to learn all that. No more warning message. So happy today. On side note I just realized it was a glass tube magnetic contact switch that giving the P signal . I used to buy one of those switch for auto light on cabinet doors lol. |
03-17-2024, 10:24 PM | #98 |
Rep 64
The P light on gear knob not lit after all the works. No errors or anything. Everything works fine.
Sort of glad anyways because the hazard button light and the P light always on even when locked until the car goes to sleep. |
03-18-2024, 02:48 PM | #100 | |
Rep 11
Fact is - most customers having this repair are either sick of the noises or are selling, and the dealer they are p/x ing the car with or selling the car to has automatically deducted around £1500 from the value of the car. Because the dealers don't understand the issue and associate it with gearbox faults. I don't milk them either - simply give customers ALL the facts to make up their own mind. We always tell them it shouldn't be an MOT fail, yet customers have come to us having failed an MOT (incorrectly) and thus need it repaired in a hurry. Poor adjustment or damage to the linkage to the gearbox, does make it possible for the gearbox to be misaligned with the position of the selector. Simply why manufacturers put a belt and braces double check on the position of the selector as well as the gearbox. And whilst, the chances are very slim -- the reason we won't code out this problem is it is possible. People have been hurt or killed by rolling cars and the reason all manufacturers do everything they can to try and stop it happening. Plus the fault remains in the EGS - so when folks are selling the vehicle and somebody plugs in the diagnostic ... the fault is still there. Most of my customers don't want that. They want the issue resolved correctly. I've no problem coding out bulb warnings but some things - it just isn't worth doing, when you can change the spring so easily. No having to recode the vehicle the next time the software is updated either. The customers speak for themselves. |
03-18-2024, 02:50 PM | #101 | |
Rep 11
03-28-2024, 10:33 AM | #102 | |
Rep 64
Not the kind of led I had in mind. Well, closed it up and one less light up after I lock the car also made my day! |
04-08-2024, 06:46 PM | #103 |
Rep 10
Still Not a Recall - Potentially on Purpose?
Is this still not a recall for the F48 X1? And if not, how is this legal and/or acceptable to be such a known and repeated problem not recognized by the manufacturer?
Is there a possibility that BMW - IS - aware and are choosing not to address the issue because they themselves are profiting $2,000-$3,000 on each of these that they either fix or offer less on trade in for? This is a serious question, is there a larger issue here that may warrant a class action lawsuit? Very serious about this, if there are any internal communications about this repeated issue it could be serious damages against BMW |
04-08-2024, 06:54 PM | #104 | |
204
Rep 813
there is no reported accident and/or injury because of this. they are more than happy to make you pay $2k for a $10 spring fix. unless there are many reported accidents or even serious injuries, we are forced to deal with it and move on. good luck trying to get anywhere because you are simply just wasting your time. |
04-08-2024, 10:17 PM | #105 | |
Rep 10
What did you end up doing about it, did you order the spring and do the fix? I've read a few have turned the message off with BimmerLink and it's stayed off, I've heard some people did this and it turned back on, and some did the turn off but the main issue gets retained when scanned in the future It seems extremely sketchy that this error shows up exactly when the car comes off of warranty, from the manufacturer who offers a cheap "oil change and issue inspection" service for cars that's only available AFTER the warranty expires and issues like this arise Also this thread is proof that the repairs are extremely profitable considering how far people are willing to travel to do/get this fix done There's been an entire website made because of the profitability of this, literally www.securevehicleagainstrolling.com This needs to be brought to BMWs attention without just saying "we're screwed and they don't care" that's not ok This coming from a company that recently tried to charge a monthly subscription to turn seat warmers on |
04-08-2024, 10:22 PM | #106 | |
204
Rep 813
I do agree BMW needs to do something about this but i highly doubt they will do anything. Same with the motor mounts - that is another common problem but that’ll never get a recall either. Welcome to the bimmer world - we just have to deal with these poor design flaws. |
04-08-2024, 10:43 PM | #107 | |
Rep 10
Honestly this is a terrible attitude to have and position to take publicly especially as an BMW customer in this thread, you shouldn't be on the side of BMW not caring, the expense being on the consumers for manufacturer mistakes, and that just being something we need to accept That was the entire point of my post, no we don't need to accept that because it isn't acceptable If a suit can be brought and similar price gouging policies to the heated seat subscription (but in this case a potential safety risk and design/materials flaw) this can be very costly to BMW Like Boeing or Apple have recently experienced (unless of course people like you roll over and say things like you just have) |
04-09-2024, 07:07 AM | #108 | |
204
Rep 813
as i have stated, there have been no accidents, injuries or anything in regards to this issue, so why would BMW care to have a recall because you want them to? sell your x1 and move on if you are unhappy. good luck - but please don’t come to a forum complaining about a poor design when every other car company has similiar problems with their own cars and then expect everyone to jump onboard with your own complaining. the problem is easily fixable and takes a few hours - i’ll fix myself if/when it happens instead of getting nowhere with BMW but good luck to you. each to their own. |
04-18-2024, 09:46 PM | #109 |
213
Rep 610
I drive it. Ignore the errors for 3 years. Its a automatic tranny. Have a good day
2017 F86 X6M
2014 F10 M5 2015 F85 X5 M 2015 F86 X6 M (Retired) 2014 F10 M5 (Retired) 2010 E70 X5 M (Retired), 2010 E92 M3 MT (Retired) 2006 E60 M5 (Retired), 2000 E39 M5 MT (Retired) 1999 E39 328i (Retired), 1995 525i (Retired) 1987 325i (Totaled - that was fun!) |
04-20-2024, 12:14 AM | #110 |
Rep 10
I followed the video and did the fix, of course it worked no problem got rid of the warning completely. Didn't even need to remove the errors after.
I didn't buy a new spring, just unwound one ring of the old one, as soon as the car restarted the warning was gone. Very upset BMW doesn't care to do a recall on this or even offer to do it for anyone who wants it. This will almost certainly be my last BMW ever, I'm done. |
