02-21-2024, 06:11 PM | #1 |
Rep 12
Coding for wipers, parking break and upgrade
Hi, anyone knows if the AUTO wipers button can be coded to always be on?
Also I'm looking for a way to parking breaks automatically on when the engines go off and nothing yet. I've found a guy in YT that upgrade F30 I-Step and get the CarPlay fullscreen. Due my still limited knowledge in coding I'll study a little bit more but this give me hope! Any contribution or help will be very appreciated! |
02-21-2024, 08:20 PM | #2 |
57
Rep 154
Drives: 2018, F48 28i
You will find out more information about Carplay coding on some thread on this forum.
Kubax86 from Bimmer remote coding is the guy you might want to ask. He did the coding on my f48. |
02-21-2024, 09:05 PM | #3 |
Rep 12
[QUOTE=X1604M;30924072]You will find out more information about Carplay coding on some thread on this forum.
Kubax86 from Bimmer remote coding is the guy you might want to ask. He did the coding on my f48. I was hoping that I can make the coding on my own. Although, the auto wipers and the parking break are more urgent codings for now. |
02-22-2024, 03:14 AM | #4 | |
192
Rep 648
[QUOTE=Quimeric;30924177]
Or pay a coder around 80-125$ for CarPlay. Wiper and Parking brake I haven’t found a FDL-value for. You could try poking around in all the values of the BDC Ecu (aka bimmercode expert mode) Edit: you could try C_FUNCTION_AUTOP_aktiv in DSC ECU, don’t know what it does though. There is also a mention of autoP in SAS ecu: LDM_variante_feststellbremse Last edited by mrpingu; 02-22-2024 at 03:32 AM.. |
02-22-2024, 05:57 PM | #5 |
4513
Rep 7,565
Do you have an AUTO-H switch? When COVID came…and there were long lines for services (aka drive thru pickup)…that was the only time I found any use for it. When it was activated, when I came to a stop and turned the engine off…the parking B R A K E (red LED would illuminate indicating the parking brake was activated) would always turn on & would still be on at the next start up.
EDIT: never mind…just read a thread below that mentions that the X1 didn’t get AUTO-H (auto-hold).
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 02-22-2024 at 06:04 PM.. |
02-23-2024, 01:23 AM | #6 | |
192
Rep 648
02-23-2024, 03:34 PM | #7 | |
4513
Rep 7,565
Auto-H is a feature that will initiate the brakes when you come to a stop and you can lift your foot off the accelerator. You don't need to be on an incline. When you need to move forward again, simply press on the gas pedal and the brakes are released and you can move forward. Some owners use it all the time...I never found a use for it until COVID when standing in line for long length of time was common. It made crawling in a drive-thru line tolerable in that you could let off the brake pedal...then creep forward when needed. And it also worked well with ASS (another feature I didn't like and turned off). If you had Auto-H and ASS activated, not only would the car brake...the engine would also shut down as you sat in a long line. To move forward, simply press on the accelerator and the engine would start, and the brakes would release as you creeped forward in line. When you came to another stop...the car would brake, and the engine would shut down.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 02-23-2024 at 03:52 PM.. |
