04-20-2024, 06:11 AM | #1 |
Rep 108
Service requiremants
Hi All ,
My 2018 now has 57k milage and is due next oil service in 5k miles , it had its spark plugs changed at 30K and I replaced the air filter last week as I replaced a broken air intake pipe. It will have done 63K when service is ready, does anybody know what else will be required please anything major required ? Thanks |
04-20-2024, 11:05 AM | #2 |
202
Rep 809
i’d do a transmission fluid change too as bmw recommends around 60k mark.
allwheelsdriven112.00 |
04-22-2024, 11:24 AM | #3 |
4486
Rep 7,529
Here's a chart that shows the BMW CBS (condition based services) by mileage.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
04-23-2024, 02:26 PM | #4 |
14
Rep 80
Here is the list I use, which came from the Owners Manual:
Standard operations for all maintenance activities:
Services not indicated by CBS (Conditions Based Service, ie the car's computer)
Services monitored by the CBS: (ie do it when the car tells you to) Engine oil Change the engine oil and oil filter. 5.3qt 0W-20, LL-14 FE+ Front brakes Replace brake pads, clean brake pad contact points in calipers. Brake discs: Check surface and thickness; replace as necessary. Rear brakes Replace brake pads, clean brake pad contact points in calipers. Brake discs: Check surface and thickness; replace as necessary. Parking brake: Repair or replace parking brake shoes/linings only if a reduction in the brake's effectiveness is noted. Vehicle check Upon Maintenance work:
Final Inspection after any maintenance work:
Putting all the faith in the digital systems, but that's BMW |
