BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) How reliable has your X1 been?
      08-24-2020, 12:30 PM   #67
gnx
Όλα ρόδες
gnx's Avatar
760
Drives: BMW
Top engine mount replaced at 97,000 kms.
      08-29-2020, 09:30 AM   #68
StefanJ
StefanJ's Avatar
68
Drives: BMW X3 G01 xDrive 20d
BMW F48 18d 07.2016
Gear stick lever replaced at 145k km.
Air input manifold replaced at 148k km.
Factory battery dead after 3,5 years / 152k km.
EGR cooler stifled (awaiting to be replaced) at 140-145k km.
Disk brake rotors replaced at 150k km.
      08-29-2020, 12:14 PM   #69
jmhumr
49
Drives: 2017 BMW X1
First unexpected repair on my car: Water pump replaced at 3 years / 33,000 miles under warranty.
      09-07-2020, 02:30 PM   #70
BillyCuth
Drives: 2020 BMW X1
200 miles driven on my 2020 X1. So far, no repairs. So far, so good.
      09-07-2020, 03:33 PM   #71
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
Two Hundred miles?
2012 BMW 320d Sport (F31).
2013 BMW X3 xDrive 30d M Sport (F25).
2020 BMW X1 xDrive 2.0i MSport (F48).
2022 MB EQB 300 4MATIC AMG Line Premium
      09-07-2020, 05:31 PM   #72
ttimbo
ttimbo's Avatar
282
Drives: F48 X1 25i AW; F20 M135i AW
Two Hundred miles?
You may laugh....but many years ago, I bought a new Alfa...and it failed well before 200 miles 😢
And continued thereafter
A Friday afternoon car!😭
Peugeot T9 308 GTi 270
Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182.
      09-08-2020, 05:47 AM   #73
Bill_P
95
Drives: X1 xDrive 20i xLine MW
I bought a new Vectra many years ago from main dealer in Southampton. Picked it up about 4.30pm. Drove about 5 miles and then stopped to fill to top with Fuel. Half way through the chap on the next pump said "Hey Mate - your car's on fire" and pointed to front. Smoke was billowing out of the wheel arches. Carefully popped the bonnet (hood) and much smoke but could not see any flames, and no flames underneath.
Decided best bet was to get off the forecourt just in case and as only 1 mile to home set off. Parked on drive at home and once again vast amounts of smoke. Phoned dealer but everyone had gone home and was advised to call RAC out. RAC man impressed with fact that car had less than 10 miles on the clock - took it round the block and same again but not quite so much smoke.
Turned out that the dealer had not removed all the gunk protecting the exhaust properly and it was gradually burning off. Took about two weeks for it all to burn off.
So first problem at 7 miles
      09-09-2020, 03:25 PM   #74
BillyCuth
Drives: 2020 BMW X1
Two Hundred miles?
I jest of course... But I've been down the BMW road before and I know that they're great when they work but expensive when they don't. I owned a 1997 328i and a 2003 Mini Cooper S, which in fairness were both longer in the tooth (not extremely high miles, but high enough). Both cost me a lot of money in maintenance, but I also got them both for relatively cheap.
This 2020 X1 is my first "new" BMW (it was a service loaner with low miles). So I'm just hoping that I've got a few years until trouble starts finding me.
I know it's built on a Mini chassis, so technically it's not a full on BMW, but I really love the car overall so far. Now over 300 miles in.
      09-09-2020, 09:01 PM   #75
CajunBMW
CajunBMW's Avatar
1291
Drives: BMW 340i and X1, Chrysler Van
Two Hundred miles?
Is the 2 series on the same chassis too?
      09-10-2020, 01:14 AM   #76
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
Yes!
Also the latest 1 series!
      09-10-2020, 06:28 AM   #77
CajunBMW
CajunBMW's Avatar
1291
Yes!
Has the X1 always been on the same chassis with the mini and 2 series? I have always had bmw sedans. We bought a used 2016 X1 last fall. We needed an extra car that my teen could drive to work and sports activities and use to ferry the other kids to their activities. And of course a vehicle that works well for trips to the hardware store, etc.
Thanks
      09-10-2020, 08:41 AM   #78
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
Thanks
The latest version (F48) (2015 onwards) is based on the Mini chassis (2 series and latest 1 series)and a lot of the running gear.
The previous version (F84) 2009 -2015 was based on the same platform used in the E91 3 Series Touring.
CajunBMW1290.50
      09-10-2020, 07:11 PM   #79
lonegun
Drives: BMW X1 F48
As long as you properly break in the engine before 5000 miles, keep the oils changed every 5000 miles ideally (including transfer case, differentials, and transmissions every few ten thousands miles), it should last a long time based on the reliability reports I've seen. It might be one of the most reliable cars BMW has built in the past 10 years.
      09-11-2020, 02:54 AM   #80
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
This is old thinking and old methodology and not necessary because production methods have moved on where machining tolerances have improved to the point where there is no gain or benefit at all by breaking engines in. You just have to follow the manufacturers guide lines in the early life of the components.
Similarly oil technology has moved on where oils are completely synthetic (man made) rather than refined oil from a refinery with just a few additives.
I know all this because for many years I headed a laboratory (using different spectrometry methods to check for wear metals in oil see note below) for the RAF and we monitored all lubricants used in engines and transmissions in vehicles and piston engine aircraft.
I agree with the reliability to some extent, but other manufacturers are just as reliable. The BMW X1 now accounts for 12% of all BMWs production.
Note. Spectrometric Oil Analysis Program. Commonly abbreviated to SOAP.
      09-11-2020, 04:54 AM   #81
dbtraveler x1
Drives: 2016 bmw x1 x drive
fluid changes
I have a 2016 x1 closing in on 100K miles .I read NOT to changes transmission fluid (lifetime ) What is lifetime ? should fluids be changed
I managed almost 200k miles on a 325ic .
Too keep or not to Keep past warranty .............
      09-11-2020, 05:10 AM   #82
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
If no one gives you a cast iron answer, perhaps email Bimmertech...
https://www.bimmer-tech.net/
      09-11-2020, 07:19 AM   #83
landrumdh
14
Drives: F48
I was happy but now just shy of 35,000mi and just over 4yrs old I've had 2 major issues in < 60 days.
I'm out ... car will be sold shortly.
      09-11-2020, 11:18 AM   #84
lonegun
Drives: BMW X1 F48
Honestly it can't hurt. I'm planning to change mine around 60k mark as I have been putting the transmission through extra wears due to modifications. You don't necessary need a full flush, a partial change is good too. That way you get to see how dirty the fluid is and is cheaper to do.
I've recently changed my transfer case fluids, it's quite dirty at just around 30k miles. Been checking out the VM forum as they have the similar haldex gen 5 cars. They've been changing their oil at around that interval too. Felt the difference right away after.
      09-11-2020, 11:26 AM   #85
lonegun
Drives: BMW X1 F48
Absolutely wrong. Unless you are running a NSX that is factory "broken in", an improperly broken in engine can cause oil burning and leak and lowered power output. Had a friend who rode his new mercedes A class hard out of the door. Now his engine is burning oil like crazy after just a few thousand miles. But hey, if you are leasing or just don't care about the longevity of the engine, go on ahead! In fact, it says it right inside your X1's manual.
Comparing an airplane engine that's constantly running to a car's engine that goes through countless start/stop cycle which cause oil degradations at turbo? No that's a terrible analogy.
      09-11-2020, 11:48 AM   #86
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
Please read what I said. I quoted vehicles as well, so my statement is completely correct. Anyway you do what you like, you are wasting your money. Industry has a lot more data to go on than you do and ever will have, and we do not see masses of worn out engines across all manufacturers because they did not break engines in (called running in) and carry out engine oil changes at 5000 mile intervals. I know because I did a lot of the testing work on oils for industry.
Anyway....you carry on with your good advice, I can see a lot of users heeding it.
      09-11-2020, 12:08 PM   #87
lonegun
Drives: BMW X1 F48
If you do a lot of testing on lubrication oil, then you should know the temperature when that oil will start breaking down. What temperature do you think your turbo is usually at?
Again, this all depends on how hard you drive your X1. I drive mine hard, thus my onboard computers usually tell me to change around 6000 miles mark. I'd like to go in a bit earlier as my dealership let me do that.
As for the transfer case and differential oils, it depends on how hard you drive as well. At 30k miles it's dirty on mine, and most GTI owners with gen 5 haldex.
      09-11-2020, 04:28 PM   #88
Troy2245
Drives: BMW X1 F48
Bought 2016 X1 xdrive at 55000 kms
So took extended warranty. My first X1 experience and so far so good.
Enjoying every bit.
Hopefully not many issues
