BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) DAB retrofit
      05-25-2019, 04:55 PM   #1
Pepppie
Pepppie's Avatar
Netherlands
83
Drives: i20
DAB retrofit
Hi all, I’ve recently bought a X2 without the DAB(+) option. Is it possible to retrofit this option? If so; is it only coding or do I need extra parts (which parts)?
Nb; I have the Navigation Plus and the Hifi-upgrade.
      07-10-2019, 10:57 AM   #2
xcelir8bmw
xcelir8bmw's Avatar
406
Drives: 2022 BMW M240ix
Doubt it. We've been talking about this elsewhere on the forum.
      07-16-2019, 02:45 PM   #3
Pepppie
Pepppie's Avatar
Netherlands
83
Drives: i20
Got a link?
      09-30-2023, 10:29 PM   #4
wcruzeiro
wcruzeiro's Avatar
Brazil
29
Drives: BMW X1 F48
2018 BMW X1 F48  [0.00]
Hello,
The path of the DAB module antena is quite intuitive. I have made the installation today, but I haven't coded the headunit yet.
First you need verify if the current module and headunit have the DAB connection.
The antena enter the rubber passage that connects the trunk to the car. It is necessary to disassemble the plastic cover on the inner side of the trunk and fix the antena attaching it to the body metal inside.
Then pass the wire antena with the other wires on the left side of the vehicle.
Arriving at the driver side, the antena passes in front of the seat, close to the subwoofer and climbs up the side of the center console. (unfortunately I forgot to take a photo).
Connect to the heaunit (yellow conector) and assemble everything back, then code.
mrpingu190.50
      01-13-2024, 02:57 PM   #5
wcruzeiro
wcruzeiro's Avatar
Brazil
29
Drives: BMW X1 F48
DAB module installed, theoretically just coding was missing.
It took me a while to program due to the rush at the end of the year.
I added SA 654, but no station appears.
What could I be doing wrong?
mrpingu190.50
      04-17-2024, 05:19 AM   #6
wcruzeiro
wcruzeiro's Avatar
Brazil
29
Drives: BMW X1 F48
Quick update here.
Even after installing the antenna that comes from the signal amplifier and coding, no digital radio station is still found.
I believe I will also have to change the roof antenna module. But I'm not sure.
