BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Finding my X1 uncomfortable
      06-19-2016, 04:35 PM   #23
Colin DF753
10
Drives: X1 xline 20d
Originally Posted by sdb123 View Post
I'm sure you'll be fine.
I'm sure you'll be fine too, I drove along that same Cambridge/Peterborough route last week and it was dreadful especially where there were expansion joints in the road, so if you are OK, then your build should be great.
Appreciate 2
      06-19-2016, 08:26 PM   #24
ttimbo
ttimbo's Avatar
282
Drives: F48 X1 25i AW; F20 M135i AW
I think it's been said before, but just check your tyre pressures before you do anything -- if you've not already done so! In my experience, dealers are not averse to adding 10psi to the recommended inflation pressure, and that's a big problem when you have low profile RFTs fitted.
My car was delivered with between 42 and 44 psi ....insanity!!
Peugeot T9 308 GTi 270
Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182.
      06-20-2016, 01:11 AM   #25
Colin DF753
10
Thanks - I saw an earlier post about this, but when I checked dealer had them spot on
      06-20-2016, 02:50 AM   #26
jsdh89j9ijkL
65
Drives: motorcycle
re: tyre pressures.
Mine came 1 BAR too high as well.
      06-20-2016, 09:02 PM   #27
ando
ando's Avatar
2002
Drives: i5 eDr40, G80 and F80
2024 BMW i5 eDr40  [10.00]
2022 BMW M3  [7.50]
2015 BMW M3  [0.00]
I don't find the standard seat are uncomfortable even after an eleven hour drive. That being said if at the time if I could I would have ordered sport seats.
      06-21-2016, 02:21 AM   #28
KPD
KPD's Avatar
171
Drives: F48 xDrive 20i xLine
Same here. I'd go for sport seats next time for their bigger side bolsters. But haven't had any issues with my standard seats.
      06-21-2016, 10:46 AM   #29
DJ Orange
Drives: VW Golf GTI
That's encouraging to hear Ando and KPD. I didn't upgrade to Sports seats either for my 20d xLine although I went for 18" alloys and EDC so hopefully will be comfy enough. He comments above have worried me a bit but I hope to find out in 2/3 weeks time. Test drove a 25d xLine with 19" alloys with standard seats and no EDC which was really uncomfortable.
      06-21-2016, 12:34 PM   #30
Bill_P
95
Drives: X1 xDrive 20i xLine MW
I have 20i xLine with 18" 566 alloys, non-runflat tyres, Dynamic Damper Control, Seat Adjustm., Electr. W. Memory, Lumbar Support Driver/front Passenger and Standard Seats. I have not done more than 4 hours driving in a single day but have to say I am more than happy with the standard seats.
      06-22-2016, 08:59 AM   #31
hanizh
26
Drives: BMW F48 X1 (ordered)
I have 19" run flat with sport seats.
Previously I had F30 (3 series), 17" RFT, no sport seats.
No adaptive suspension in both.
The F30 is way comfortable compared to the the X1 as the ride is less stiff. This is noticeable in long rides (more than one hour),
But ! The X1 wheels is much nicer this way and the ride is much fun ! I do not regret it
      06-22-2016, 09:38 AM   #32
Colin DF753
10
Good to see everyone's experience and opinions. I finally went on a long test drive today, in car with 18" non run-flats, sports seats and std suspension - seemed more comfortable, as expected, but by the time I got out my back still ached a bit so I'm beginning to wonder if it might be me rather than the car, I don't think the seats are the problem in my case, I had a bit of time hanging around in the showroom waiting to get the test car ready and was able to compare sport and std seats. Essentially both seats have exactly the same basic geometry and hardness in the base and the back, so should be equally comfortable, providing that is that you have relatively short legs, as I do, and you don't drive very rapidly on twisty roads. So I've decided to keep the car at least a few more months, and then consider buying some new wheels, or changing the car. At the moment X1s seem in short supply, so the only suitable alternative the dealer could offer at the moment, without ordering from the factory would have been an extra £8k - too much if I'm not sure it'll solve the problem. The salespeople I spoke to didn't seem to acknowledge the problem with 19" wheels + runflat, although as someone mentioned it's widely reported.
      06-22-2016, 12:35 PM   #33
simon.
922
Drives: F48 25D mSport
If you decide to swap out to 18's then I'm sure someone on here would do a swap with you.
Might even be interested myself come delivery in September.
      06-22-2016, 03:12 PM   #34
Colin DF753
10
Let me know in Sept, unlikely I'll get the chance to do anything before then
      06-22-2016, 08:21 PM   #35
swifter
Drives: 2016 BMW X1
I have experienced pain in the right knee due to the seating positions after going on a longer drive. I tried different combinations by adjusting the height and other settings but could not find a comfortable position and I might have to buy an extra car cushion to increase the height of the seat. I was used to sitting at a higher position than the maximum height on the new X1. Not sure if the cushion can fix the problem but my knee really hurts in the current setup.
      06-23-2016, 01:57 AM   #36
AusF20/F48
AusF20/F48's Avatar
Australia
176
Drives: F20 125i MS, F48 XD25i
There are several things that you could consider to increase the seating height and cushioning.
1 Replace the standard seats with the sport seats.
2 Get an upholsterer to modify the seat base by adding a spacer plate under the seat frame to raise it, and have the front swab/bolster of the seat made deeper and/or longer.
      06-24-2016, 10:53 PM   #37
DHS
43
Drives: '16 X1, '15 435i & '98 Z3
X1 seats are terrible. Standard or sport neither compare to other BMW models. They are almost as bad as the transmission.
      06-25-2016, 02:58 AM   #38
Thq
Netherlands
Drives: BMW and Fiat
Picked up my car yesterday. Including leather sport seats, sport steering wheel with paddles, dynamic damper control, 511 19 inch wheels with Bridgestone Potenza (S001).
About the comfort/noise. During my testdrive (Xdrive) in February the car was noisy and not feeling comfortable at all. Don't know what happen but things have certainly changed.
First impression: Very comfortable, quiet and oh so nice to drive. I think due to the DDC and the leather seats. My big worry about the comfort with the 19 inch wheels disappeared. Don't have to change wheels...pffff! A happy owner here.
      06-25-2016, 03:22 AM   #39
simon.
922
You speak from current experience as a lot of posts are saying the opposite?
      06-25-2016, 04:11 AM   #40
jsdh89j9ijkL
65
Drives: motorcycle
He's right though, the sport seats are not the same nor is the transmission. This has been said on here many times before.
      06-26-2016, 09:11 PM   #41
AusF20/F48
AusF20/F48's Avatar
Australia
176
Nor is the price when you compare the X1 to the far more expensive X5, 5 series etc
You have to consider that it is built to a price to compete in a market segment. If it had the best seats, transmission etc, why would anyone buy the more expensive BMW models.
Yes, the Gearbox in the X1 is not as smooth or dynamic as the 125i F20, and the seats are a little small for larger bodies, but for me (average size) overall it is a really good package. I am sure that the all the comments find their way to the relevant teams within BMW, so time will tell. The good thing is most items like seats can be fixed to suit the individual.
      06-26-2016, 09:54 PM   #42
ttimbo
ttimbo's Avatar
282
...and the Aisin transmission, while not as good as the ZF employed elsewhere in the BMW range, is still far better than the DSG transmissions employed by Audi/VW, and M-B. I'm surprised people think the seats are "smaller" than the sports seats in other BMWs. They seem larger to me than those in my F20 M135i. Maybe it is the shape?!
      06-27-2016, 02:54 AM   #43
sdb123
45
Drives: F48 X1 M-Sport
The sports seats in both of the demo X1's I had (Sport Line and x-Line) were both narrower and slightly less deep than the sports seats in my F30 M-Sport...still very comfortable though and no complaints from me.
      06-29-2016, 02:31 AM   #44
Saintsman
Saintsman's Avatar
39
Drives: X1 2.0i x-drive Sport AW
I mentioned the seats to my wife when I first saw this post.
Last night when she came in from work the first thing she said was.....
Christian says, "If it's uncomfortable come down to the factory and we'll mould a custom cushion"
Turns out she mentioned it to a friend at work who's husband works for Red Bull at Milton Keynes and the Christian is Mr Horner himself.
I've been promised a factory tour for some time now, and I've been invited down at the end of the year after the current season ends.
Now about that carbon fibre mobility scooter Mr Horner..............
Tags
comfortable, ride
