BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) knocking when lifting off accelerator
      01-16-2024, 01:32 AM   #1
Alank
Drives: BMW x1
when i lift off accelerator at slow speed i get a light knock from front right corner, S/Drive 18D auto, any thoughts, thanks
      03-20-2024, 04:43 PM   #2
Alank
Drives: BMW x1
anyone got any ideas ???
      03-21-2024, 08:24 AM   #3
stefdeath
Drives: F48
Take a look at the right engine mount.
      04-17-2024, 06:25 AM   #4
br_318_d
Drives: X1 xDrive18 DA
Also inspect the middle engine mount.
Something like that was similar for me on the X1.
      04-17-2024, 10:18 PM   #5
saphirschwarz.f48
31
Drives: 2019 BMW F48 X1 sDrive
Do you hear/feel any other vibrations coming from the front right corner? Your issue is most likely due to a bad engine mount. It's a known problem on the F48/F39. Mine went at about 38k miles so if yours is already past the 40k mark chances are your mounts are gone. Might wanna try opening up the engine and taking a look at the mounts and see if they're done for. Mine went at around 40k miles and several other forum members had theirs gone at around 40k-60k too (one even had it go at just 18k on the thread I linked below!) so if yours is already past the 40k mark chances are your mounts are gone.
This is what a bad engine mount would look like: https://f48.bimmerpost.com/forums/sh...87&postcount=6
Hope you get your problems sorted and wish you many more happy miles in your X1
      04-17-2024, 10:23 PM   #6
saphirschwarz.f48
31
TBH, since you're gonna be replacing them anyways there's no point replacing one without doing the other. Its a matter of when rather than if the mounts will go so might as well do them all in one go and not worry about it again
