BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) X2 M sport exhaust tips to X1 f48?
      09-13-2018, 11:30 AM   #1
psven
12
Drives: X4 2021
Does anybody know if the new X2 m sport package 2.0i exhaust tips can fit the X1 same model?
I have the chrome ones that seem so small compared to the X2 version and would like to change them to bigger, nicer ones.
These black ones look so nice.
https://paultan.org/2017/10/26/f39-b...-m-sport-x-10/
or this one:
https://leasing.com/cms-images/BMW%20X2%20rear%20.jpg
Anything similar has anybody changed/fitted?
      10-14-2018, 06:12 AM   #2
SamF48
Drives: BMW G01
or this one:
or this one:
Yes it is possible, if you look on Realoem.com you will see that the rear silencer on the x2 and x1 are the same part number, which means the tail pipe finishers will be a direct fit. I have fitted satin black pipe finishers from the F20 M140i onto my F48
      10-17-2018, 05:51 AM   #3
Shipa
17
Drives: BMW X1 F48
Do you have any photo? And please share an exact part number of black pipe dinishers you've installed....thanks
      10-17-2018, 05:55 AM   #4
SamF48
Drives: BMW G01
[IMG][/IMG] part number 18307610633
      10-17-2018, 04:26 PM   #5
pandauk
28
Drives: BMW X1
On my old car I just "hammered" (using a bit of wood between) them onto the existing exhaust tips (or lack of, rather). Do the old ones need to be removed or do these slide over the top?
      10-22-2018, 03:07 AM   #6
Shipa
17
Drives: BMW X1 F48
Great! Thanks for the photos!
Would also highly appreciate your reply on the post above - how you removed the old finishers? Rubber hammer?
      12-12-2018, 08:15 AM   #7
Shipa
17
Drives: BMW X1 F48
or this one:
Hello! Have you finally tried to change the exhaust tips from X2?
      11-30-2021, 08:57 AM   #8
Wadadli Cooler
Drives: BMW X1 xdrive25d Msport F48
Hello, could I just double check the diameter of the exhaust system these will fit on before I order them? I have two system pipes, each being 52mm external diameter. The existing chrome tails are 75mm external diameter. Thanks.
      11-30-2021, 10:13 AM   #9
jrveron
jrveron's Avatar
Argentina
272
Drives: 2023 X3 m40i
The inlet and the outlet have different diameters. If I recall correctly, the inlet is 35mm and the outlet is 75mm, but please check it first.
To avoid doing all that, I bought a set of tips that 'slides' on top of existing ones, something like this: https://www.ebay.com/itm/14413839387...wAAOSwSzBhCdAA
IMO, they are great, they really transform the look and they are easy to install/uninstall. I'm attaching some pictures for your reference, and trust me, in person, they look even better. From the photos, you may say they are too long, but it's not the case.
Anyway, I just wanted to share my thoughts with you.
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD
      04-20-2024, 11:49 PM   #10
wcruzeiro
wcruzeiro's Avatar
Brazil
29
Drives: BMW X1 F48
2018 BMW X1 F48  [0.00]
Has anyone already installed the X2 m35i talpipe on the X1 25i xdrive? It is 100mm and I believe it will look very nice on my X1.
