09-12-2023, 04:02 AM | #1 |
Rep 18
Entrynav to Nbt Evo retrofit help
Hi my wife's car is 2016 f48 with entrynav, 8,8 screen and HUD, I want to upgrade HU to nbt evo for CarPlay
Im planning to buy used HU (attached pictures) I know that I have to buy wifi antenna cable, do I need anything else? I think that there is also DAB connector on the back is it possible to use it somehow in my F48? Im looking for someone who can code it for me with CarPlay upgrading unit to ID6 (I don't know which ID is already installed) I can mount it by myself looking for help with coding to my VIN |
10-04-2023, 01:18 PM | #3 |
1804
Rep 3,070
You require:
WiFi antenna, CID Voltage Converter (to 8-8.2V), turning 180 degrees USB Cable and in some cases wiring Ethernet is required (from Quadlock to OABR) That's hardware, from software - you require coding, proper software to support APIX1 screen which you'll be using (unless you swap to touchscreen which is APIX2) That's all P.S. can help with coding if needed
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
