BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) 2019 X2 20i Oil filter leak
      02-11-2024, 10:25 AM   #1
Zaeem89
Drives: BMW X2 2019
Hi all.. I recently bought 2019 X2 20i.. The car had a recent oil change done and it has just done 13k miles. At the time i bought the car there were no oil leaks below it on the tray however once I drove back to myhome 200miles awayi noticed oil stains on the tray.. I checked and the oil filter was wet so I assumed it may be faulty oil filter seal or someone has over torqued it.. Got the oil changed along with new BMW oil filter and the oil filter seals however after 100 miles drive it is still leaking. Can it be due to faulty oil filter housing/cap as everything above the oil filter housing appears dry?
Thanks
https://photos.app.goo.gl/hEY2TjQQmBzEDj8r6
https://photos.app.goo.gl/H32fPuw6uMWhExAv9
https://photos.app.goo.gl/Nh4NCDdwmnbZyr4YA
https://photos.app.goo.gl/WwbAh7qACoNfP1tt5
      02-12-2024, 08:57 AM   #2
//TMT
//TMT's Avatar
129
Someone definitely tried to use the Torx socket on top - you can see the nicks in the *clockwise* direction. Would not take much to damage the plastic internally. Just look at the "5+2Nm" torque spec right on it!
If you can find the part, I'd just replace the whole cap. But you could maybe glue the insert.
      02-12-2024, 12:24 PM   #3
Zaeem89
Drives: BMW X2 2019
Thanks for the reply.. Yes that's what it looks like.. I have ordered the new cap from BMW so will be getting it installed on Wednesday.. Hopefully that should resolve
      02-18-2024, 09:27 PM   #4
knightarmor
855
Drives: 2017 M3
Did the place that did the oil change not look to see if there was actually an oil leak?
Just something to note if the oil filter cap doesn't fix it these things are notorious for the plastic housing cracking where it attaches to block. I believe the f48 and the x2 use the same oil filter housing. Just something else if the cap doesn't fix it cause one of your pictures looks like the oil is coming from up above.
