BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) Coding out SOS error on F39
      12-22-2023, 09:48 AM   #1
jehill
Drives: 2019 X2
I found this solution by Mark333032 in Bimmerpost, used for a different BMW model. Many thanks.
"Open the Bimmercode app and go to Instrument Cluster/Expert Mode/3301 CC_ID_Sperre/CC_ACTIVIERUNG_5/Custom Value. You should see 'FF' listed in Bytes 0 to 7. Scroll to Byte 5 and change it from FF to F7 and press 'Done'.
Then back out to the 'Instrument Cluster' menu and hit 'Code'. The 'SOS Call System Failure' message is now gone. The only thing the car asked me to do was reset time."
This worked perfectly on my F39 to eliminate the very annoying "Emergency call malfunction" error message on the dashboard. This is most often caused by a dying TCM battery which is located under the shark fin and extremely hard to replace because you need to remove panels and lower the headliner. The replacement battery costs about 65 USD but the BMW dealer charges an additional 400+ USD for service to replace it. Batteries last 3 - 4 years (or less depending on climate) and you will then need to replace again.
This was my first use of Bimmercode but it ended up being easy, only a one byte code change. I used the Vgate iCar Pro Bluetooth OBD2 Code Scanner to connect Bimmercode to my car, about 32 USD on Amazon. Only scary part was the dashboard went black after coding and rebooting the ECU. I waited a couple of minutes, turned the ignition off and back on, and everything came back. Just had to redo the time and date in the menu settings.
Appreciate 2
Rich80766.00
mrpingu180.50
      12-22-2023, 07:04 PM   #2
chowser51
chowser51's Avatar
2025
Drives: F33 430 and F39 M35i
lolz. that's what i told you in the other thread as well.
But have you tried a dealership to replace the battery? I thought it was covered. They did mine for free.
      12-22-2023, 07:48 PM   #3
jehill
Drives: 2019 X2
Not covered when off warranty. Dealer wanted 480 USD. That's why I reposted. Many F39 owowners have or will have this problem
Rich80766.00
      12-27-2023, 08:52 AM   #4
Ryan Emad
Drives: BMW X2 18i
Does this affect any functionality other than the SOS call being disabled?
      12-27-2023, 12:04 PM   #5
jehill
Drives: 2019 X2
Nothing else affected that I have seen.
      12-27-2023, 03:18 PM   #6
//TMT
//TMT's Avatar
129
Does the telemetry use the same antenna? Navigation update downloads?
      12-27-2023, 04:57 PM   #7
jehill
Drives: 2019 X2
Don't know. In the past navigation updates have been done while the car was in for service. Since I am off warranty and would have to pay for the updates, it is not worth it to me. Maybe someone who has made this change can comment about whether the antenna comes into play.
      01-09-2024, 03:45 PM   #8
jehill
Drives: 2019 X2
I was able to successfully update my maps using only a USB key so I still have not seen any downside from not replacing the TCU battery.
      01-09-2024, 06:55 PM   #9
//TMT
//TMT's Avatar
129
My 2020 gets them over the air, or at least it has been as recently as December. I didn't know they could be updated offline. Is there a page for that?
      01-09-2024, 09:39 PM   #10
jehill
Drives: 2019 X2
I got my maps from a site called bimmerscene. Google "bimmerscene maps" and you will find it. You need to go into the settings of your nav system to determine what maps are installed. Mine are "North America Way" and I was able to get map updates for 2021-4. Have not found the more recent versions online yet but it varies depending on map type. For example, they just posted "North America Premium" 2023 so if that's what your 2020 M35i uses, you are in luck. If you browse through their forum you can read about requirements for size and format of the USB key you need and other requirements that various BMW models may have.
      01-10-2024, 07:20 AM   #11
chowser51
chowser51's Avatar
2025
Yeah, that's the last map update I could find online as well. 2021-4. I installed it August of 2022. My car did update for my region in 2023.
