BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Upgrade my X1 with Harman Kardon Tweeter
      03-05-2017, 10:49 AM   #67
F30 SA
Drives: 2013 320i Modern Line
Originally Posted by josephmk View Post
Brought the Focal IFBMW-S and I just received my F48 18d. May I reconfirm how many screws are holding the door trim to the door? Reading the posts there are 2 behind the door handle and 2 at the door trim bottom.
Want to do the mod tomorrow but don't want to break my brand new car. Thanks!!
Hi. How do these sound? Did you encounter any difficulties?
Any suggestions for me.. I am seriously considering these.
Tx
      05-05-2019, 06:40 PM   #68
bmwmotorrad46
55
Drives: BMW X1
I've found those trims for $90 each
https://www.bmwminipartssource.com/o...ng-51337435817
      05-06-2019, 06:49 AM   #69
MJE60
MJE60's Avatar
England
678
Hi
Just be aware that these do not come with the HK speaker (separate part number) and obviously left hand and right hand side are different parts also.
      05-06-2019, 06:54 AM   #70
MJE60
MJE60's Avatar
England
678
@josephmk door panel removal to fit speakers
Hi,
There are two screws hidden in the door handle, if you remove the cover strip on the handle itself you will see the torx screws. I believe there are 3 screws along the bottom of the door panel, if you lie down under the door you can see the recesses. To remove the door, after removing screw, it is easiest to start at a bottom corner and work up along edge using a prise tool (or large plastic trim removal tool) once bottom and side studs are released the panel will hang from top edge so you need to lift up and away.
      05-06-2019, 08:12 PM   #71
bmwmotorrad46
55
Drives: BMW X1
Is there any other way to install those tweeters? Like drilling this plastic part?
      05-07-2019, 03:11 PM   #72
MJE60
MJE60's Avatar
England
678
You can use mini F56 dash mounted tweeters which can be surface mounted onto the existing window trim, some aftermarket F48/F39 upgrades use similar approach. IMO it would still be advisable to remove the trim in order to get a professional fit as it is in a prominent position. I have two mini HK tweeters which I bought before deciding to go the full HK trim route, I will check the part numbers and update this post with some pics tomorrow. I didn’t use them because I just did not like the finished look compared to HK mesh trim but it certainly would be a cheaper option although I do not think it would be necessarily an easier fit.
      10-23-2019, 01:51 AM   #73
Fuzzzy
Romania
Drives: BMW X1 F48 20d
Hey, I have upgraded with the HK tweeters and HK front speakers plus the center speaker, but I have a hissing noise in the tweeters and I don't understand why. I can hear it only if I'm close enough to the tweeter.
The noise is present with the Idrive on mute and with it on volume and it is there no-matter the source of sound.
I have a Hi-FI OEM system so I have the non-HK amplifier.
Does any of you encountered this problem with the hissing noise?
Sorry for my spelling errors, but I hope I made my self clear.
Thanks in advance for your interest.
      03-15-2021, 09:19 AM   #74
Lee999
Drives: BMW X1
I am looking to add tweeters in my 2016 X1 as well. 51337435817/18 will come with speaker grid, like what is your photo?
I tried to get some answers from BMW, only got this reply:
Good afternoon,
Regrettably, it is company policy not to give out part numbers and we do not list a retrofit kit for a speaker upgrade so we’re unable to advise I’m afraid
Kind Regards
BMW / MINI eCommerce Store
      03-15-2021, 09:59 AM   #75
Homersbud
202
Drives: BMW X1
Good afternoon,
Kind Regards
Those are just the moulding trim. You'll need to buy the tweeters separately (65139226357)
Depending on your door speakers, you may need a y-cable to power the tweeters. I got focal door speakers & when I added this moulding with HK tweeters, i was able to p-n-p the connection.
      03-16-2021, 10:12 AM   #76
LGARCIA2
Drives: BMW
This is a great add on for sure, more pics on the splice pls!
      03-21-2021, 10:45 AM   #77
malelee21
Drives: 18 X1
Can you just drill a hole in the existing plastic piece and install aftermarket tweeter? I can’t justify spending $300+ for both moldings with tweeters integrated.
      03-21-2021, 12:01 PM   #78
Homersbud
202
Drives: BMW X1
Yeah - some folks have installed aftermarket tweeters & drilled through existing basic moulding. You'll have to rig up something yourself for a clean look but i've seen some pics posted around here & look good.
      03-22-2021, 03:01 PM   #79
Bcborn59
18
Drives: BMW X1
As you will notice the non H/K trim is not flat (rounded) and drilling to accept a surface mount tweeter will leave a gap which you will have to fill ti look decent. I have to agree the OEM H/K body moldings are the way to go.
51-33-7-435-817
51-33-7-435-818
If you get tweeters in them, your a luck guy. Seems today, the tweeters are not included and available separately.
      03-26-2021, 01:03 PM   #80
Ktjaru9
Drives: BMW X1
Nice mod
      03-26-2021, 07:34 PM   #81
Shaquanjamal
Drives: BMW X1
Originally Posted by skunkd View Post
Originally Posted by ForkLiter
I did this yesterday myself to my 28i M Sport. It does make a big different in soundstage and detail. If anyone has questions on technique, let me know. I would recommend a blanket on the ground so that the door card doesn't get marred (not comfortable with what's shown in the pics here). Thanks to everyone in this thread for the help!!!!!
Please post more instructions for us I'm totally interested in this!
Same, just ordered. Seems like an inexpensive quick easy upgrade with good results. Not to mention it definitely looks better than stock
      10-07-2021, 09:59 AM   #82
Garal
Drives: Bmw X1
Hi, did you solve it?
I'm planning on adding the tweeters to my regular sound system using a Y splitter, and wonder if this is the source of trouble (and hence I'd need to change the mid-range speakers too? or worse, it is due to the amp)
      10-12-2021, 05:10 AM   #83
The_OneBMW
Drives: BMW X1
Thanks for the information, trying to order new trim for my tweeters ( base audio system), do hope it will be ok
      10-13-2021, 04:06 PM   #84
bmw x1 f48 lci
Drives: bmw x1
Thanks a lot for your info. I've added tweeter to my system. Unfortunately BMW Hi-Fi doesn't have tweeter. At least I've one in center(dashboard) now.
