06-19-2019, 09:51 PM | #1 |
Rep 4
F48 cold start rough idle
1 out of 10 times my '17 F48 sdrive28i will idle rough on first start when I need to reverse from garage. Sometimes shifting back to park straightens it out. Mentioned to my dealer. They'd have to keep overnight and see a code to address it. Too far, no time.
I can get an error through iCarly:"ignition timing idle, cold start. firing angle too early." Anything that I can address myself? |
08-27-2019, 12:58 PM | #3 |
Rep 5
Guys i have a similar problem i hope i am not completely off topic here.. but there is a rough idle sound maybe clutch related to my brand new bmw x1 f48 s18i automatic getrag DCT 7 speed and i need people to hear it so that i can be sure if it's normal or not. Tomorrow i will try to check the test drive car to see it it has similar problem.
my car has a rough engine idle sound more of a rattle when idle but only when HOT when in neutral and when in gear but pressing the brake. The sound goes completely away if i try this when the engine is cold.. please check this out if you can help 1.rattle idle sound when engine hot: 2.normal engine sound when cold: |
09-03-2019, 06:34 AM | #4 |
121
Rep 352
Drives: G20 330ix M Sport
There is a service bulletin regarding this. Take it in to your local
service center for a software update. Last edited by mikeyb74; 09-03-2019 at 10:38 AM.. |
09-03-2019, 07:30 AM | #5 | ||
21
Rep 204
Could you please share more info on this? |
09-03-2019, 09:19 AM | #6 |
121
Rep 352
SIB 12 21 17
DME FAULT 151001: IGNITION TIMING ADJUSTMENT 2017-10-01 MODEL F48 (X1 sDrive 28i or xDrive 28i) SITUATION The engine is running with reduced power and the Malfunction Indicator Lamp (MIL) is illuminated. The following fault is stored in the Digital Motor Electronics (DME) fault memory: 151001 – “Ignition timing adjustment during idle operation, cold start: Ignition timing too early”. CAUSE Software error in the DME CORRECTION ISTA Next 4.04.1x PROCEDURE For conditions that are similar to the situation described: Perform diagnosis with the latest version of ISTA. Program the vehicle using ISTA Next 4.04.1x or higher to appropriate level shown below: Model Target integration level F48 (X1 sDrive 28i) F056-17-03-500 F48 (X1 xDrive 28i) Note that ISTA Next will automatically reprogram and code all programmable control modules that do not have the latest software. Always connect a BMW-approved battery charger/power supply (SI For information on programming and coding with ISTA, refer to CenterNet / TIS / Technical Documentation / Programming and Diagnostics / Programming Documentation. WARRANTY INFORMATION Covered under the terms of the BMW New Vehicle Limited Warranty for Passenger Cars and Light Trucks or the BMW Certified Pre-Owned Program. |
09-03-2019, 09:20 AM | #7 |
121
Rep 352
Mine runs rough on a cold start. When the engine first starts it shakes the whole car.
09-03-2019, 12:00 PM | #8 | ||
21
Rep 204
09-03-2019, 12:24 PM | #9 |
121
Rep 352
09-27-2021, 06:43 PM | #10 |
273
Rep 657
Hi mikeyb74,
Sorry to revive this old thread, but I'm having the same issue on my 2017 X1 2.0i M-Sport. I also created a thread: https://f48.bimmerpost.com/forums/sh....php?t=1855388 Did you manage to solve the problem? It's driving me crazy , and BMW doesn't know what it is. I really appreciate any help you can provide.
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD |
12-15-2021, 06:35 AM | #11 |
Rep 1
Cold start
My car has the same cold start issue. Bmw recommends the software fix. My motor mount has faied 41,000 mikes. Could the rough vibrations when stalling cause the motor mount to fail?
DL |
12-15-2021, 08:11 AM | #12 | |
137
Rep 310
Motor mounts going bad is a common problem with Minis that share the same platform as our generation X1. I've also seen a couple other forum members mention having their motor mounts replaced. |
12-16-2021, 08:45 PM | #13 |
858
Rep 1,562
Dropped our 2018 X-Drive off for this today. I told them about the Service Bulletin and they found it. Supposedly applied "a" fix. Kept vehicle overnight to verify the problem is gone tomorrow. Will share info. when we get the X1 back.
12-17-2021, 12:34 PM | #15 |
273
Rep 657
In my case, that I have also a problem with revs going high and then low in cold start, the dealer found a service bulletin and replaced the MAF sensor. However, it didn't solve the problem.
I put a stand-by on this because the dealer didn't seem to find an answer . So, I will wait for your insight guys and probably go to an indy shop with specific directions haha.
12-20-2021, 12:20 PM | #17 | |
273
Rep 657
If yours hold steady ~1000RPM and then goes down, that's normal, because you know the engine is cold.
12-20-2021, 09:46 PM | #18 | |
80
Rep 139
12-21-2021, 02:29 PM | #19 | |
273
Rep 657
In my head, it's more related to the CCV/PCV or oxygen sensors, but they all look good, according to BMW. Now I bought some gasoline additives to clean the fuel system because here in Mexico, the gasoline sucks, man. I'm trying this one from Liqui-Moly: https://products.liqui-moly.com/gaso...cleaner-6.html
12-21-2021, 04:56 PM | #20 |
858
Rep 1,562
So our X1 rough idle in reverse at cold start issue has been fixed. Pic attached of Service Bulletin they applied. They reflashed all the modules which wiped all of my coding but this did not lock me out of the vehicle. I was able to recode everything (Rear foglights, seatbelt chimes, disclaimers etc..) using Bimmercode.
02-22-2022, 08:50 AM | #21 |
413
Rep 1,975
Just realized I posted this question on the X2 board but probably more fitting here...
Did anyone that experienced this issue also have some smoking coming from the exhaust? We’re looking for a 2017ish x1 for our teenage daughter. Test drove one yesterday and it drove great except on startup, it seemed to idle rough and felt like it was struggling to stay running. I didn’t spend enough time with it to see if it would go away after a while. We were pretty turned off so just left. I had a similar issue with my f30 (minus the smoking) which was resolved with new plugs and coils. Originally I was thinking to run from this vehicle but now that I’ve slept on it, I’m wondering if it could be reasonable for me to manage and maintain myself. It’s a pretty good deal so that’s why I’m considering.
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
02-24-2022, 10:56 AM | #22 |
Rep 30
I have experienced this near identical issue - "1 out of 10 times my '17 F48 sdrive28i will idle rough on first start when I need to reverse from garage." I have a '18 Xdrive that will stall out maybe 1 out of 20 times on a cold start when I put it in reverse. Surprisingly, ever since I installed my aFe cold air intake I have not had the problem. Maybe the car just needed to breath better?
