BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) X1 and other BMWs Speaker/Amplifier compatibility and recommandations
      10-10-2018, 09:39 PM   #1
bmwmotorrad46
51
Drives: BMW X1
Hi All,
I have 2017 X1 with Hi-Fi. I've been thinking to upgrade.
There are couple of junk yards where I live, I stopped by there to see what I can get from old BMWs to make my audio system better.
Those are the models below that I can remove speakers and amplifier from
E90 3 series Harman Kardon
2005 5 series Harman Kardon
2008 7 series Harman Kardon or other high level brand
I wonder which amplifier should be compatible with - like plug and play?
All BMWs mostly use 4" speakers, I don't think it won't be a problem.
Speakers are $25 each.
Which speakers from models above would you recommend me to get?
Thanks!
      10-11-2018, 06:11 AM   #2
scostu
scostu's Avatar
1623
Drives: 2016 F25
Originally Posted by bmwmotorrad46 View Post
Hi All,
Thanks!
HK speakers are not compatible with HiFi stereo.
The amplifiers are completely different and ohms of speakers are different.
Keep your stock Hifi and add the Bimmertech DSP/AMP.
      10-11-2018, 07:47 AM   #3
Mushy007
56
Drives: X3 2D MH M Sport 2021
X1 has three levels of system, base has 6 speakers, HiFi has 7 and the HK has 12.
I wouldn't bother with any of them and look for after market, even people with the HK setup say its poor! Plus you cant just swap one to the other.
If you replace the subs, they will go from 6'' to 8'' with a better sound output, lots of plu and play versions out.
      10-11-2018, 06:49 PM   #4
bmwmotorrad46
51
Drives: BMW X1
Bimmertech amp is around $900 - used X1 HK or Mini Cooper F56 HK amp is less than $300 -
Can I at least replace my HIFI amp with original X1 HK amp and HK speakers without a problem ?
      10-11-2018, 06:51 PM   #5
bmwmotorrad46
51
Drives: BMW X1
Mini Cooper F 56 sub woofers are same as X1 (same product code as well) so subs are around $100 each but not sure how good they can be with HIFI amp.
      10-11-2018, 06:59 PM   #6
scostu
scostu's Avatar
1623
Drives: 2016 F25
You can find them used for roughly $600.
      10-11-2018, 07:00 PM   #7
scostu
scostu's Avatar
1623
Drives: 2016 F25
I don't know that answer.....check the F30 forums.
      10-11-2018, 08:01 PM   #8
bmwmotorrad46
51
Drives: BMW X1
Thanks!
      10-12-2018, 06:53 AM   #9
Mushy007
56
I've read and watched multiple pages and videos. It appears manufactures know a lot of people want plug and play upgrade units and charge a premium for it.
I've ordered two vibe 8'' subs and two plug convertors, so if I need or want to remove them, I can. My wife has the F55 Cooper, so if all go's well and the gains have been worth while, the mini is getting a pair too.
I'm going to take some videos of before and after, to see if the difference is captured. My system doesn't have an amp, so your results should be better.
      10-12-2018, 02:17 PM   #10
hart4bmw
hart4bmw's Avatar
Netherlands
80
Drives: BMW X1 Sdrive20i (2016)
      10-18-2018, 10:31 PM   #11
Encanto
Encanto's Avatar
1166
Drives: 2021 X3 M40i
The HiFi(676) OEM amp can be swapped directly with an HK(674) OEM amp -205W vs. 360W. HK(674) is stable at 2ohms (HiFi woofers are 2ohms).
It will improve the sound of HiFi OEM speakers some for the cost, just do not expect a radical improvement. A good upgrade is swapping the OEM amps and replacing the HiFi OEM tweeters with aftermarket/filters, nothing else.
      01-02-2019, 10:38 AM   #12
feirstein
Drives: 2017 X1 F48
I changed out my oem non hi-fi speakers for Focal co-ax speakers and love the upgrade. Oem amp has plenty of power to drive these and the subs. Not too expensive.
      01-11-2019, 01:24 PM   #13
Boulderguy10
Drives: 2017 X1 (F48)
^^ Which Focal's did you use & where did you source them? Their BMW-specific stuff is hard to find in the states. And I'm a total slut for their sound quality
      03-13-2019, 03:58 PM   #14
dBManiac
Drives: 2017 BMW X1
Would these work?
Has anyone tried using an adapter? If these work then we should be able to install any speakers, right? (Within the allowed mounting depth)
Adapter
      05-05-2019, 06:36 PM   #15
bmwmotorrad46
51
Drives: BMW X1
I've just replaced HIFI amp with HK amp - It makes a big difference!
      05-07-2019, 11:49 PM   #16
StefanJ
StefanJ's Avatar
68
Drives: BMW X3 G01 xDrive 20d
I have replaced the standard speakers with an aftermarket solution, specially designed for X1 F48 and the results are excellent. The sound is great, even without an amplifier.
The speakers are called MATCH.
The cost of the replacement for front is around 250 €, for 6 speakers (twitter, middle and bass).
I retrofitted the speakers myself, mounting the tweeter in the corner where the original speaker should be, but without buying the expensive original frame. The design is much better than the original, in my opinion.
I'll get back with some pictures soon.
      05-10-2019, 01:23 PM   #17
bmwmotorrad46
51
Drives: BMW X1
How did you install those Twitter with the current trim? I guess you have drilled on it
M3_160.00
      05-17-2019, 02:29 PM   #18
StefanJ
StefanJ's Avatar
68
Yes, i drill round holes.
Also, I made an adapter between the twitter and the trim, using a door stopper in a form of a half sphere. It was very difficult to achieve the shape for the adapter, in order to have a right angle for the twitter.
Then I connected the parts using hot melt plastic.
I'll try to find some pictures for the post.
      05-17-2019, 02:53 PM   #19
StefanJ
StefanJ's Avatar
68
Here are the pictures.
MJE60678.00
      06-24-2019, 12:47 PM   #20
halcyon026
Drives: 2011 E70 35i
Hello.
Can you give some more details, mainly the part number to the HK amp that fits the x1 F48 HiFi system and the source you purchased from?
Thanks!
      06-25-2019, 06:29 PM   #21
bmwmotorrad46
51
Drives: BMW X1
Originally Posted by halcyon026 View Post
Hello.
Thanks!
I bought from eBay as used for f56 Mini Cooper model (same product and product number ) I don’t have the part number at the moment but you can get from Real oem web site
      07-01-2019, 10:27 AM   #22
TygerBright
28
Drives: X1 20d Sport
Adapter
Those seem to fit E48 X1 only ... well I think so at least as F48 is not called out specifically.
