02-01-2021, 11:26 AM | #1 |
18
Rep 105
Run Flat Tool Components
I bought a 2016 X1 and it has the 19" Run Flat option.
There is no spare, no jack, no compressor. The only thing in the wheel storage area is a tow anchor and a screw driver in a foam holder Where is this stored? What else comes with the RFT Option in regards to tools and where is it stored? |
02-01-2021, 11:37 AM | #2 | |
681
Rep 913
Welcome to the forum. Sorry, that is it unless you have a security locked nut on each wheel in which case the small tool should be there also. Even new cars with non RFT no longer automatically carry a spare, instead you get a small electric tyre pump with screw in tyre/tire sealant. You may have a warning triangle in the trunk door (look up), although it is not supplied for all markets. It’s all about weight saving. I found the best option was to get a good electric tyre pump and a tyre repair kit (they are easy to use, loads of demos on YouTube). This is the type of thing.. https://www.amazon.ca/Tooluxe-50002L...s%2C265&sr=8-6 With the tyre pressure warning system you usually get plenty of time to find a safe place to pull over, I found repair took no more than 10 mins. If you get a can of foaming windshield cleaner it can help identify where puncture is. The kit has everything you need to remove nail, plug hole and then re-inflate tire (need pump). Way easier than trying to handle a jack, tire and wrench on a cold dark night. There are at least two forum threads of people fitting there own spare tire kit, what to buy, sizes, how to secure etc. I didn’t bother, happy with a repair kit. https://f48.bimmerpost.com/forums/sh...ght=Spare+tire Last edited by MJE60; 02-01-2021 at 11:55 AM.. |
grumpyguy12.00 |
02-01-2021, 12:11 PM | #3 | |
18
Rep 105
I do not have the air pump or the sealant, if I did not sure where it's hiding. I read something in the manual about a Mobility Kit. |
02-01-2021, 12:17 PM | #4 |
681
Rep 913
If you read my post, pump and tire sealant are only provided in new non-RFT cars. RFT option cars, for most markets, get no spare and the only tools were tow hook, screwdriver and possibly wheel nut adapter.
02-01-2021, 12:52 PM | #5 |
33
Rep 131
Three weeks in to my new X1, and I only just discovered this foam storage piece yesterday, 'hidden' way back in the cargo area. Had no idea it was there. The screw driver is handy. And now I know where to store the wheel lock key!
02-01-2021, 12:57 PM | #6 |
18
Rep 105
Does it attach the the velcro strap on the back wall
