01-28-2021, 04:31 PM | #1 |
18
Rep 105
Battery Disconnect
I'm upgrading my HiFi amplifier and Subwoofers. In the F48 (2016 - 2020) Is there is a fuse dedicated to the amp, HiFi etc....and what number is it?
Where is the fuse box located in the 2016+X1 Disconnecting the Negative terminal of the battery looks to much like work lol. |
01-28-2021, 04:53 PM | #2 | |
204
Rep 818
Can't help ya on what/if there is one for the amp itself but curious because one of my next mods is upgrading amp (already did speakers) but in same boat as you, getting to battery is a b!tch lol |
01-28-2021, 04:56 PM | #3 |
60
Rep 173
Just "bite the bullet" and disconnect a battery terminal... for yours and the cars safety. The last thing that you want to have happen is an electrical "fault" that trashes a module or frys a cable. This ain't your mothers old Chevy. *Hint: Disconnect the negative cable where it connects to the car body stud and wrap this terminal with a rag or electrical tape. There will be a spark when you do - don't freak!
@Homersbud... have a look at this thread for an amp how-to: https://f48.bimmerpost.com/forums/sh....php?t=1610748 Last edited by Ridin'Dirty; 01-28-2021 at 05:07 PM.. |
01-29-2021, 11:45 AM | #4 |
303
Rep 1,089
I'd also much rather reach into the engine bay vs trying to pull a fuse in the glove box ... Even if it's empty it kills my back and neck to try to figure out which one it is and pull it.
01-29-2021, 06:41 PM | #5 | |
18
Rep 105
https://www.autotrader.co.za/cars/ne...-a-bmw-x1/6209 |
01-29-2021, 10:30 PM | #6 |
60
Rep 173
@ Bcborn59... Your location is correct; the other end of the battery negative cable is connected to the base of the negative jump-start terminal (silver post).
If you choose to disconnect at the battery, the negative lead has the IBS (intelligent battery sensor) electronic module attached at the terminal and requires care to avoid damage by mishandling. Last edited by Ridin'Dirty; 01-29-2021 at 10:40 PM.. Reason: added IBS diagram |
MJE60681.00 |
01-30-2021, 05:30 AM | #7 | |
681
Rep 913
Given the work you are doing especially under front seats, the risk of accidentally activating airbags or triggering module faults is too high. Please disconnect the battery. Last edited by MJE60; 01-30-2021 at 05:35 AM.. |
Ridin'Dirty59.50 |
01-30-2021, 07:26 AM | #8 |
Rep 12
Hi Bcborn59, it's much easier than you think it is.
I used the same blog you posted above and just went through steps 1-3 to get to the battery. I first removed the rubber sealing strip as shown in step 1. As said in the blog just "peel" it off. Then remove those 3 pins. There's an explanation in the blog on how to remove them, I didn't read this part and wanted to pull them out with force which I luckily didn't manage, and then I read the explanation on how easy it is to remove them, just if you know the right way. Finally I just removed the ventilation tray cover as described in step 3 (go easy with this part since it's a large one-piece plastic cover, and I did have a feeling it could easily break). It's a bit tricky to put this tray cover back once you're done, but just take your time. I didn't have the battery cover as described in step 4, so after step 3 I already saw the battery and just removed the negative terminal. This all took me around 2-3 minutes. Good luck! Last edited by Ivan_K; 01-30-2021 at 07:32 AM.. |
MJE60681.00 |
01-30-2021, 09:48 AM | #9 | |
681
Rep 913
01-30-2021, 11:36 AM | #10 |
18
Rep 105
Thanks all,
Looks pretty straight forward. I have a 2005 330Ci M that I have had to pull trim, know how detailed BMW is in fine fitting their parts. This is a great resource, no need talking more stuff apart than you have to. |
