BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Steering Wheel Change
      09-27-2020, 11:41 PM   #1
31 Express
Drives: 2018 X1
Has anyone changed the steering wheel on their F48 X1? Mine came with the standard plastic wheel and I'd love to put the sport steering wheel on but not sure fit's possible?
      10-06-2020, 02:27 PM   #2
StefanJ
StefanJ's Avatar
68
Drives: BMW X3 G01 xDrive 20d
Yes, it's possible and it's not so hard to change it.
Check the airbag of the new steering wheel to be a 2-stage type.
If the short steering wheel has paddles, this will require coding.
Good luck.
      10-06-2020, 09:57 PM   #3
31 Express
Drives: 2018 X1
Good luck.
Thank you Stefan. No Paddles but I'd love to have them on the new SW. I'd imagine it would be a difficult job (if it's even possible).
      10-07-2020, 02:18 PM   #4
StefanJ
StefanJ's Avatar
68
I have retrofitted the steering wheel with pads, but I didn't used them so often. So this is possible, because the original steering didn't have them.
It is not so difficult to code them, as I understood from the guy who make the install for me.
      10-07-2020, 08:19 PM   #5
ventjock
65
Drives: 2020 M340i
You could always wrap it as well. I got a custom steering wheel from AliExpress for like $50
      10-08-2020, 07:10 PM   #6
31 Express
Drives: 2018 X1
Good to know. I'm not sure if I'd use them a lot either but if I'm going to change the wheel, I thought it would be nice to have the pads.
      10-08-2020, 07:13 PM   #7
31 Express
Drives: 2018 X1
Thanks ventjock. Can you post a picture? The wheel I would like is this:
https://thumbs-eu-west-1.myalbum.io/...04cbafb5de.jpg
      10-08-2020, 09:43 PM   #8
ventjock
65
Drives: 2020 M340i
See if this works
https://ibb.co/jbP8Xyf
I got it from the Mewant Official Store on AliExpress. You can customize it. So if you see a steering wheel cover for an F80 you should be able to have it customized for your M-Sport.
      10-08-2020, 10:45 PM   #9
31 Express
Drives: 2018 X1
See if this works
Looks good! I think I want to get factory with paddles though.
Thanks!
      10-12-2020, 08:40 AM   #10
Ivan_K
Drives: X1 F48
Good luck.
Hi StefanJ, how did you remove the steering wheel?
I did this on my previous BMW F31, but there you had two tiny slits on the back of the steering wheel and all you had to do was to insert a thin but long screwdriver and move the U-shaped clips holding the airbag a bit to the side and the airbag just pops out, the rest is easy.
The problem with X1 is that I don't see these slits anywhere on the steering wheel, so how do you remove the airbag?
      10-17-2020, 02:47 AM   #11
Ivan_K
Drives: X1 F48
Just a quick update. I found this F46 blog where it's explained, including photos, how to remove the same steering wheel found in a X1.
So, for anyone looking to replace their sport steering wheel with a M sport steering wheel, or simply wants to replace the leather as I do, then this blog offers more than enough info:
http://*********f46.blogspot.com/201...-retrofit.html
      10-21-2020, 07:55 PM   #12
31 Express
Drives: 2018 X1
Hey Ivan, I can't get the link to open. I tried copy and pasting in a browser but it brought me to the original thread where I guess you found it. I'd love to be able to read the information though.
Thanks
      10-21-2020, 08:21 PM   #13
trnguyen
76
Drives: BMW X2
Try this http://shorturl.at/hoNUY
      10-23-2020, 11:11 AM   #14
Ivan_K
Drives: X1 F48
Hi,
I hope this works: www.shorturl.at/gGWY4
Thanks trnguyen
      10-28-2022, 09:03 AM   #15
FrenchCdric
No_Country
Drives: BMW X1
Is the airbag of a standard wheel compatible with an M sport Wheel ?
