BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Vibration during cold start-up
      09-02-2021, 11:54 AM   #1
jrveron
jrveron's Avatar
Argentina
266
Drives: 2023 X3 m40i
Question Vibration during cold start-up
Hi guys, how are you?
I'm experiencing a noticeable vibration along the entire car when doing a cold start-up. I can feel it in the steering wheel and on my body while seated, in the doors, etc. After a couple of seconds, you know, when the RPMs go lower and stabilize at around 900rpms, the vibration goes off and doesn't appear anymore.
Did someone experience anything like that? What could it be?
I also have a problem with jerking at low acceleration. I put my question in this thread: https://f48.bimmerpost.com/forums/sh...php?p=27978373
Could both problems be related?
Thanks,
JV.
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD
      09-08-2021, 08:10 PM   #2
jrveron
jrveron's Avatar
Argentina
266
Could someone please shed some light here? Thanks!
      09-09-2021, 07:22 AM   #3
rice_rocket88
No_Country
299
Drives: E60 F48 F39
I think you have that cold startup issue.. could be your spark plugs, could be that "programming" to fix idle startup. Happens once in a while to my wife when she starts the car and puts it into reverse right away. Good news is as soon as she gets rolling forward the rims go up and she hasn't had any lasting shaking.
      09-09-2021, 10:22 AM   #4
jrveron
jrveron's Avatar
Argentina
266
Thanks, rice_rocket88,
My concern is that it happens every single time I start the engine. And BMW changed the spark plugs less than 5,000 miles ago, so I would like to think that's not the issue here.
I just left my X1 with BMW to do a full update of all modules. I hope it helps with this issue and the jerking on low RPMs, but my gut tells me it's something else...
BTW, what do you mean by "that programming to fix idle startup"?
      09-09-2021, 10:50 AM   #5
rice_rocket88
No_Country
299
Drives: E60 F48 F39
There are a few people with these rough starts and they were told that BMW had a new program update for those starts. That and a PCV or EGR valve replaced, I can't remember it all. Hopefully since your car is at the dealer you can get the updates, whether it's directly related to your problem or not, they don't usually explain until you ask more.
      09-09-2021, 01:30 PM   #6
jrveron
jrveron's Avatar
Argentina
266
Oh, I see.
Yes, I read some users replaced the EGR valve, but you know, it's only for diesel engines.
And I also read about the PCV valve on older X1's versions (E84). Searching in realoem for my X1, I found the "Crankcase-Ventilation." I believe it's the same: https://www.realoem.com/bmw/enUS/sho...diagId=11_5887
Anyway, hopefully, it will get better with the system update. Otherwise, I will keep pushing BMW to diagnose properly, starting with the crankcase ventilation parts.
Thanks!
      09-21-2021, 09:43 AM   #7
jrveron
jrveron's Avatar
Argentina
266
Hi guys, just a quick update here.
Unfortunately, the system update didn't fix my issue. So I'm asking BMW to make a full diagnosis of several parts, such as the spark plugs, the acceleration body, the CCV/PCV (Crankcase-Ventilation), the fuel pump, the air sensor, the transmission and its mounting, etc.
As you know, it could be many things, and I have no guidelines here. So that's why I'm trying to list all parts that could be related to my problem. But it can't be a coincidence; it sounds like a common problem. And I still think it's related to the jerking on slow rpm's trouble I also have.
      09-21-2021, 09:52 AM   #8
rice_rocket88
No_Country
299
Drives: E60 F48 F39
Thanks for the update, hope they find the trouble parts and you can post it up in the future!
      08-11-2023, 09:11 AM   #9
dudezi
Drives: X5
SIB 12 21 17
https://static.nhtsa.gov/odi/tsbs/20...76362-9999.pdf
my car was out of warranty, I paid $510.54( long Island, NY) at dealership for code upgrade.
      11-29-2023, 09:43 AM   #10
andrelbc
Drives: BMW X1 2013
The same
Hi jrveron, finally what was the solution for your issue, can you share please, I'm having the same problem as you.
"I'm experiencing a noticeable vibration along the entire car when doing a cold start-up. I can feel it in the steering wheel and on my body while seated, in the doors, etc. After a couple of seconds, you know, when the RPMs go lower and stabilize at around 900rpms, the vibration goes off and doesn't appear anymore."
      12-06-2023, 09:55 AM   #11
jrveron
jrveron's Avatar
Argentina
266
Hi there! If you're only experiencing the vibration, I would start by checking the engine mounts.
On the other hand, if you're experiencing the RPM flutter, I'm afraid I didn't find the cause. The car runs just fine, so I stop looking for answers.
      04-09-2024, 03:40 PM   #12
lefamsta
Drives: BMW x1, x5, and 7series
Fixed vibration with the engine mount replacement
I would concur with the above diagnosis with engine mount. We had the rough at idle start, lower gear start off red light/stops, and at stop it sometimes would rattle like hell and had to stomp on the brake. The DTC shows first running lean/rich (so changed O2 and fuel rail sensors myself, fixed that). Then error with cylinder 3,4 misfires (changed all 4 sparks and 2 coils, fixed that). But the big kahuna fix (not really if you have the time and research how to hoist the engine) finally was when shop did vibration test and located the worn out engine mount, which cause extreme slanting of the engine with shifting and can get worse. You can visibly see it under hood as your helper can shift the gears for you.
Parts with mount brackets, and they wanted to change control arms too, cost @$800-$1000 (rip off) and labor @$1200 - $2000 (8 hours on shop estimate lookup). This was Dallas, TX but SF, CA prices probably 20% higher in our areas. Another rip off, youtube completion looks like half the time, but it is a lot of work.
