BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Center speaker installation - Base audio EU
      04-06-2021, 08:49 AM   #23
Wermuth
16
Drives: BMW iX3 LCI
Hi
Thanks a lot for the this. Agree, a lot of prep-work needs to go into this before just running out and buying a wiring harness, amp and some speakers. I'm quite sure the base head unit would be able to support HK as in the BMW optional list it doesn't require upgrade of the headunit.
The big thing is running and wiring backwards and forwards in the car. So again, big thanks for the wiring diagrams. I don't have access to ISTA myself yet, so getting them here really helped a lot.
I have asked both bimmer-tech and Bavsound. Let see what they come back with.
Big thanks again!
      04-06-2021, 10:27 AM   #24
Bcborn59
18
Drives: BMW X1
Wermuth have you contacted Audiotec Fischer? The harness link was specifically for the Std BMW Head Unit.
Have you also checked out the following European Forum?
https://www.motor-talk.de/forum/bmw-b4.html
Good Luck
https://www.eton-gmbh.com/produkte/c...e/product/bak/
      04-06-2021, 01:27 PM   #25
Bcborn59
18
Drives: BMW X1
Originally Posted by wcs2229 View Post
There are only 4 pairs of wires because the front door speakers are connected to the respective woofers, like in 2-way speakers, with or without simple crossovers (capacitors).
I do not disagree that a wiring harness may work, as long as all the correct connections including the amplifier signal wire. The 12V power cabling should to be checked to see if it is already in place in the rear compartment, or needs to be installed.
I do not disagree that the head units may be the same for Base audio and HiFi audio, only that this should to be checked.
I am not sure bimmer-tech and bavsound would support their amplifiers with the HK speakers he has already bought, instead of their own matched speakers. Custom equalization may be necessary for really good sound.
I hope that Wermuth now has more information and points to consider before spending a lot of money, time and frustration. Unfortunately, I have gone through a lot of DIY experiences in previous cars during my younger days, which is why I now leave my X1 as stock.
Found this on a UK Site;
The speakers under the seats are driven from the radio, no amplification, no crossovers; there is just a capacitor on the back of the mid range in the doors to get rid of the low frequencies.
      04-08-2021, 12:15 AM   #26
Wermuth
16
Drives: BMW iX3 LCI
Good Luck
Yes - have also reached out to Eton in Germany to hear if they have any solutions.
Yes - but the European forum has some good stuff, but not so much on this subject. There is a guy in Germany who specializes in retrofitting. But we the current restrictions it difficult to have him support me with the wiring.
Thanks a lot
      04-08-2021, 02:06 PM   #27
Bcborn59
18
Drives: BMW X1
Good Day Wermuth,
Sounds like you have it in order. You will be the source for all Europeans once your through here.
      04-11-2021, 07:19 AM   #28
Wermuth
16
Drives: BMW iX3 LCI
Good Day Wermuth,
Well don稚 know if I have it order. I got some very good insight from you guys. I also got an answer from Audio fisher.
I attached per below. That痴 a quite good solution, so I need to contact the local dealer to see what is the price-range
With factory standard STEREO system we can recommend the following concept:
-amplifier Match M5DSP MKII - https://www.audiotec-fischer.de/matc...ker/m-5dsp-mk2
-Subwoofer Match MW 8BMW-D - https://www.audiotec-fischer.de/matc...cher/mw-8bmw-d
-adapter PP-MQS 1,4 - https://www.audiotec-fischer.de/matc...bel/pp-mqs-1.4
This system can be connected directly to your radio and can also be removed without leaving any residue. The two under-seat subwoofers must be wired directly to the M5. However, requires expertise and should therefore be installed by a specialist dealer. We therefore do not have installation instructions for this.
More information about our BMW Sound Upgrades can be found online at:
https://www.audiotec-fischer.de/en/car-concepts/bmw/
If you have any questions about prices and installation, please contact one of our car hifi dealers. Through their daily experience on the vehicle, they have the necessary knowledge and can create a tailor-made concept for you
      04-11-2021, 01:28 PM   #29
Bcborn59
18
Drives: BMW X1
That's a start for sure.
That looks to separate the subs from the doors and adding new wiring from the Amp to power the subs.
My question would be how do you provide more power to the door and dash speakers rather than be powered by the head unit.
      04-11-2021, 08:48 PM   #30
wcs2229
wcs2229's Avatar
171
Drives: 2018 BMW X1 F48 xDrive28i
The Match M5DSP MKII is a 5-channel amp: 4 door speakers, 1 subwoofer.
There is no center speaker output. The existing under-seat woofers (not really subwoofers) should be replaced, so wiring to the M5 can be installed at that time. The single subwoofer output would drive both.
      05-07-2021, 07:16 AM   #31
Humpus
Drives: BMW X1 F48 16d
I would hold off on the subwoofers. The standard ones are more than capable. If you really want an upgrade in the lower bass department, you'll need to install a separate subwoofer in the trunk. The standard subwoofer enclosures don't allow enough space for deep bass.
      05-07-2021, 02:43 PM   #32
wcs2229
wcs2229's Avatar
171
I don't think the woofers in the base audio system are the same as the subwoofers in the Hifi and HK systems.
      07-01-2021, 07:50 AM   #33
luca.x1.f48
Drives: x1 F48
Here is speaker wiring diagram for HiFi audio:
Attachment 2570167
Hello,
From this diagram, as I remember how to read it from the school, it seems that the fron central speaker [number 10] is connected.
I bought this https://it.aliexpress.com/item/40013...40344c4dlBMssx and I have connected to the cable that I found under the dashboard but it does not sound.
Anyone can help me ?
Thanks.
      07-01-2021, 12:54 PM   #34
wcs2229
wcs2229's Avatar
171
Which audio system do you have (base, hifi, HK) ? If there is no existing center speaker, then you have the base audio system that does not have an amplifier nor center speaker output.
This is what the op @wermuth tried to do and there was no signal:
https://f48.bimmerpost.com/forums/sh...17&postcount=3
      07-01-2021, 02:59 PM   #35
Bcborn59
18
Drives: BMW X1
Hi Bcborn59
Thank you very much for the reply and help
I was both lucky and unlucky this weekend. When I disassembled the dashboard I found the wire for the center speaker. I plugged in a HK speaker but there were no signal to it. A bit of measuring with an Ohm-meter found there was no connecting either. So things are not looking good.
My understanding is that the base audio in the EU version don’t even have an amplifier ? So everything is “driven” from the headunit. Do you have any idea on that.
I have upgrade the front doors with HK tweeter and mid-tone. Major difference ����
The rear doors are with fabric liner so I’m not up for a drilling a hole in fabric. So can it help just updating to HK mid-tone without tweeters ?
All the best, Christian
If their are speakers in the rear door just buy 2 way coax speakers to replace them.
Follow WCS2229's feedback, his input will assist.
      07-20-2022, 05:09 AM   #36
Wermuth
16
Drives: BMW iX3 LCI
Thanks a lot for all the feedback and input to the project. I ended up making a very simple solution just replacing the speaker in the back doors too with HK. I know they are made to be paired with tweeters but sound-wise was still a massive upgrade from the base speakers.
      08-03-2022, 12:01 AM   #37
instalher
25cent millionaire
instalher's Avatar
253
Drives: 2020 m4 comp vert
2020 bmw  [0.00]
  [9.00]
  [0.00]
  [9.50]
2018 bmw 230i xdrive  [8.50]
i just pulled the amp out of my 2016 x1 with the hk system and i see no fiberoptic cables... does this mean that i can just take that amp out of the system and add aftermarket amps and a dsp without a mobridge peice??
      03-27-2023, 02:31 AM   #38
Pepppie
Pepppie's Avatar
Netherlands
83
Drives: i20
Wermuth did you find out where the center speaker cable was leading to? I'm asking this because I'm upgrading a base F48 with an Audison AP8.9 bit and have a channel available for a center speaker!
      05-28-2023, 03:02 PM   #39
Wermuth
16
Drives: BMW iX3 LCI
Unfortunately not - I知 quite sure that the center cable runs to the amp in back/trunk. As F48 only have center speaker if there is an amp. A
Appreciate 2
      09-26-2023, 11:15 AM   #40
limsheng
Drives: BMW X1
2016 BMW X1  [9.00]
Just want to say thank you for the details on upgrading the sound system and ways to go over them. Just gotten the F48 myself with base audio and the sound system was just overall lousy that I plug my earpiece and drive.
I should go for the door window tweeter first. Too bad the center speaker couldn稚 work for base audio.
      09-27-2023, 06:07 AM   #41
limsheng
Drives: BMW X1
2016 BMW X1  [9.00]
Hi I went to ask some china sellers about how to connect the center speaker. One was giving me a logical answer which is to connect to passenger side mid range speaker with the extension wire provided.
Another one is quite interesting, they have an instruction video to show you and connect to the red/white and brown/white wires at the back of HU main connector.
I just snapshot the part where you slot in the center speaker wires. Wonder it it works.
      11-07-2023, 02:44 AM   #42
Alphashock
Drives: BMW X1
Do you have any luck in connecting the center speaker as described in the video?
Thanks!
      11-12-2023, 10:42 PM   #43
limsheng
Drives: BMW X1
2016 BMW X1  [9.00]
Thanks!
Not yet as I have to do the maintenance parts first like transmission cooler, oils , shock struts, tires before moving on to speakers and entertainment system. But I知 sure I値l be adding that center speaker in the future.
      12-14-2023, 07:59 PM   #44
chanlmjohn
Drives: X1 F48
Hey guys,
i am new to the forum, usually reading and getting information for the mod I plan to do on my F48 X1 2021. In case anyone still want to add Center speaker or tweeter on the base model, here are some useful wire mapping on the main plug as described in the Chinese video from limsheng. The white red and white brown essentially are the +&-ve output from Head unit (HU) to rear right speaker RR (i.e. pin 1 and 5 of the main plug mapping shown in one of the uploaded photos)
For the spare speaker cable (Black/white & black purple) found at the empty slot, no signal at all and it doesn't connected to the HU. I originally planned to trace the other end of that spare cable and hopefully make use of it but haven't done so.
So, i finally followed what the Chinese video suggested, connecting extra cables to the HU via sharing signal from pin 1 & 5, as shown in one of the photos. The final setup looks good aesthetically but may not be so for the overall sound stage since that is just a shared channel with the RR. Two questions left unanswered: 1. Without adding any amp or complicated rewiring works, which channel should we use for the Center speaker for the best result (as you can just join one of the four channel FL, FR, RL and RR) and 2. Where does that spare cable connected on the other end. Hope someone could shed some light on these. Thanks!
